Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > BMW M3 Discussions > M3 Frequently Asked Questions > E36 FAQ
Closed Thread
Old Wed, Jul-16-2003, 04:44:22 PM   #1
PurpleM3Pursuit
E36 on the way out... E92 on the way in..
PurpleM3Pursuit's Avatar
Reputation: 578 PurpleM3Pursuit has a reputation beyond reputePurpleM3Pursuit has a reputation beyond reputePurpleM3Pursuit has a reputation beyond reputePurpleM3Pursuit has a reputation beyond reputePurpleM3Pursuit has a reputation beyond reputePurpleM3Pursuit has a reputation beyond repute
Default Intake information
ok guys.. i wanna get everyones ideas on the intake they have so i can put them into the FAQ area so we don't have to keep answer ?'s.. jus tbe honest on whatever u think was tough with install, the sound, etc.. then we can get it all compiled and have info for the newbies.. thanks
MANUFACTURER - Jim Conforti
STYLE - Short ram with heatshield
ADVANTAGES - lets engine breathe easier giving more power, nice grunting sound, easy install because no removal of bumper , easy to clean ITG foam filter with greasing element, carbon fiber piping, fiberglass heatshield, will still fit with euro ellipsoids unlike dinan.
DISADVANTAGES - pricetag (400$), had to cut part of heatshield so it would fit under hood and adjust hood properly..
list any problems u had in the DISADVAN section and we can try and compile it all.. this will be reformed into a single thread and then placed in the FAQ section.. thanks guys..
alex
Alex... or PM3P... being a good Leader for YOU!
E92 M3 AW/BL Competition
BMWCCA# 368302
Also in the fleet:
'75 Porsche 911 Carrera
'85 Chevrolet Camaro Z28
'87 Porsche 951
'95 BMW 325i DM #422
'15 F150 EB SCrew
Jump to top PurpleM3Pursuit is offline
Old Thu, Jul-17-2003, 04:08:39 AM   #2
97BLKM3COUPE
Reputation: 0 97BLKM3COUPE has a reputation beyond repute97BLKM3COUPE has a reputation beyond repute97BLKM3COUPE has a reputation beyond repute97BLKM3COUPE has a reputation beyond repute97BLKM3COUPE has a reputation beyond repute97BLKM3COUPE has a reputation beyond repute
Intake: Benfer 3-piece design with AEM bypass valve and K&N filter.
Style: DINAN style True CAI that sits in the bumper above the brake duct.
Advantages: Gets a slightly better source of fresh clean air if you cut holes in the brake duct. Filter is completely out of the engine bay where the hot air is and does not require a heatshield. Under $200 for the three piece unit so price is great. It cleans up the engine bay a bit more as the filter is not seen. Great sound.
Disadvantages: Installation and Maintenance. You have to remove the bumper to install and remove the bumper again about once a year or so to clean. If you are good, the bumper can be removed in about 20 minutes, but takes slightly more to put back on and line everything up. Potential Hydro-Lock if you happen to get caught in a flash flood. If filter becomes submerged in water, it will ingest it into the engine. Your bumper pretty much has to be underwater for this to happen, but it has happened for DINAN owners. The AEM bypass valve solves this problem. Finally, without a little modification to the Euro lights, they are a very tight squeeze. It works fine with the US lights.
Upcoming changes: The 3-piece unit will be discontinued and a once piece aluminum one is coming out with a better bracket and small heatshield to completely isolate the filter from the engine. Price will be a bit more. Also a one piece carbon fiber unit is coming out that will be cheaper than DINAN and priced around $350. Nice eye candy.
http://www.benferperformance.com/
Jump to top 97BLKM3COUPE is offline
Old Thu, Jul-17-2003, 06:57:07 PM   #3
PurpleM3Pursuit
any info from the ECIS guys.. or AA guys.. PAR? come on.. i know that there are more guys out there just wanting to get involved with this.. help a brotha out
BMWCCA# 368302
Also in the fleet:
'87 Porsche 951
'15 F150 EB SCrew
Old Thu, Jul-17-2003, 09:46:23 PM   #4
AMPowerJ
One mod leads to another ...
AMPowerJ's Avatar
Reputation: 0 AMPowerJ is on a distinguished road
Intake: Pham Air Research (PAR) Cold Air Intake http://www.phamairresearch.com/index.php
Advantages: Very similiar to the Jim Conforti intake but half the cost! The installation is very easy and straightforward.
Disadvantages: None that I know of other than the fact that it is not as proven as the Dinan or Jim Conforti intakes.
2009 E90 M3 - LeMans Blue - Speed Cloth - 6 speed
ESS Tune - BMW Performance Exhaust - StopTech Trophy BBK - KW Clubsport Suspension - TE37SL Wheels
Jump to top AMPowerJ is offline
Old Thu, Jul-17-2003, 10:10:21 PM   #5
97BLKM3COUPE
By the way, even though the PAR intake will probably have identical gains as the JC, it will not look quite as nice in the engine bay. However, if price is a major consideration, you can't go wrong with the PAR. If you have the $, the JC will look much better than the PAR.
Old Fri, Jul-18-2003, 04:15:39 AM   #6
xochytl
Reputation: 0 xochytl is on a distinguished road
I have the AA and love it. Costly, but beautiful. Easy to install and from what little I have seen it has the best heat shield going. Not as far down as some of the longer ones, but still only a few inches shy of being down in the well. After moving the horns and cutting two holes in the brake duct I don't think it makes any difference in performance. Also has a very nice look to it. ~X~
97/4 Luxury Boston Green w/Magma
AA CIA, Rogue Engineering SSK, UUC Tranny Mounts, Racing Dynamics Front & Rear Braces, OEM X-Brace, Clear corners and side markers, H7 Foglights, System U
Wish List
Ground Control Track/School Kit
UUC Sway Bars
JT Designs Rear Strut Brace
JT Designs Aluminum Under Panel
Shark Injector
Supersprint Headers
AA Track Pipe
Jump to top xochytl is offline
Old Fri, Jul-18-2003, 05:12:49 AM   #7
M3AN
321 fun...
M3AN's Avatar
New Zealand
Since you're going to reformat this anyway...
Adding URL for the manufacturers will be very useful as well.
Nice idea lads!
/// E36 M3 Evo Coupe / Estoril Blue / Lotus White Individual
/// S50B32 / 6MT / Slick Top / Alu Doors / Z3 Rack / Simota / Remus / Bilstein / Eibach / BBS / Goodyear / Rally Road / 3.62 CWP (TBI)
Jump to top M3AN is offline
Old Fri, Jul-18-2003, 05:27:23 AM   #8
PurpleM3Pursuit
good call mean.. do u think it would be appropriate to show a pic of each one also?
BMWCCA# 368302
Also in the fleet:
'87 Porsche 951
'15 F150 EB SCrew
Old Fri, Jul-18-2003, 05:35:27 AM   #9
BMW M Power
Senior Member
BMW M Power's Avatar
Reputation: 0 BMW M Power is on a distinguished road
yes a pic would be great. two would be better, ie one of just the intake and then one of it installed in the car.
99 Silver M3: GC Race Coilovers (500/550), UUC Sways, JTD Bar, UUC Stage2 Clutch/Flywheel, M50 Manifold, ASC Delete, Cosmos CAI, Custom Exhaust, UUC UDP's, UUC SSK/RK3, ZKW w/dde enhanced, V2 Splitters, Black Kosei K1 17x8.5 with 255/40 Kumho MX
Jump to top BMW M Power is offline
Old Fri, Jul-18-2003, 05:37:00 AM   #10
xochytl
No pics of the intakes, just a big blowup of the girl in M3AN's reply and a super sized squirt gun for everyone.
Wish List
UUC Sway Bars
Shark Injector
Supersprint Headers
AA Track Pipe
Closed Thread
E36 information - towing Dave Crump E36 M3 (1992-1999) 5 Sat, Aug-04-2007 07:41:18 AM
FS - Conforti E36 Intake. def328 Parts for Sale/Wanted 13 Sat, Apr-14-2007 04:44:05 AM
Wtb E36 M3 Chip Or Intake koolikdat Parts for Sale/Wanted 0 Wed, Apr-20-2005 05:01:09 PM
Does the E36 come with AIR INTAKE? PiZark E36 M3 (1992-1999) 7 Fri, Sep-10-2004 06:30:17 PM
looking to buy an e36...looking for information imaboa E36 M3 (1992-1999) 2 Tue, Aug-17-2004 04:52:22 AM
Discussing (E36) Intake information in the E36 FAQ Forum - at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
