Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > M3Forum Marketplace > Parts for Sale/Wanted > E36 / E30 - Parts for Sale/Wanted
E36 / E30 - Parts for Sale/Wanted Use this section to post parts for sale or wanted that are related to the E36 or E30 only.
Old Wed, Dec-18-2019, 12:30:47 AM   #1
ApexRaceParts
Reputation: 0 ApexRaceParts is on a distinguished road
Default ► APEX | Flow Formed Lightweight BMW Wheels - Built to Perform
Questions?
Call: 925-245-0773
Email: expert@apexraceparts.com
Web: www.apexraceparts.com
Hours: M-F 9a-5p PST
APEX Flow Formed Wheels
For over 10 years, APEX has been the go-to wheel for BMW enthusiasts looking for the perfect balance between strength, weight, and cost. Our ARC-8 and EC-7 designs address the concerns of more and more racers and track day enthusiasts: long term durability, fitment, and performance. Our newer FL-5 and SM-10 designs provide a step-up in strength and true race wheel features like I-beam spokes and reinforced lips.
➡︎ Perfect fit without spacers
➡︎ Made to work with big brake kits
➡︎ 100% OEM compatibility, no extra hardware required
➡︎ Unbeatable warranty & 50% replacement program
Order Now
ARC-8 / EC-7 / FL-5 / SM-10
Designs & Finishes
ARC-8 - 17" / 18" / 19"
The lightest wheel we make. Also the most affordable. A deep lug recess allows for easy access for beefy impact sockets without scratching the wheel face. Available in Profile 1 (less concavity) and Profile 3 (deep concavity). The less concave profile provides increased caliper clearance on narrow applications, while the deep concave profile reduces weight and creates a stunningly aggressive appearance on low offset and wide width applications. Both profiles are available in 17”, 18”, and 19” diameters. Face profile is determined by offset and width and cannot be selected independently.
EC-7 - 18" / 19"
Massive brake clearance & a plethora of fitments. The curved spokes of the EC-7’s face beautifully contour around some of the largest brake calipers available. The split "Y" spokes were carefully evaluated from every aspect to ensure light weight and remarkable strength. Available in Profile 1 (less concavity), Profile 2 (medium concavity), and Profile 3 (deep concavity). Profile 1 provides increased caliper clearance on narrow applications, while the deepest concave face reduces weight and creates a stunningly aggressive appearance on low offset and wide-width applications. All three profiles are available in both 18”, and 19” diameters. Face profile is determined by offset and width and cannot be selected independently.
FL-5 - 18"
Gorgeous flow formed lip with I-beam spokes for reduced weight. Both the inner and outer lips are flow formed to stand up to all the abuse the street and track have to offer. The spokes of the FL-5 were designed to be robust where they need to be, and extra lightweight where they should be. Weight is reduced by CNC machining material out from the sides of each spoke. It’s expensive and avoided by almost every manufacturer, but affordable with volume. Available in Shallow, Medium, and Deep lip profiles. This maximizes spoke concavity and reduces weight on the FL-5 design. Lip size is determined by offset and width, and cannot be selected independently.
SM-10 - 18" / 19"
Modern design with reinforced lips and I-beam spokes. Like the FL-5, the SM-10 spokes were also designed to be robust where they need to be, and extra lightweight where they should be. Weight is reduced by CNC machining material out from the sides of each spoke. Available in Profile 2 (medium concavity) and Profile 3 (deep concavity). The medium concavity is offered on narrow-width applications, while the deep concavity is offered on our wide-width applications. Concavity is dependent on width and offset, and cannot selected independently.
Order Now
Fit Matters
The right solution for every application. An optimized car setup begins with the perfect wheel and tire fitment. Without model-specific attention to each wheels specifications, maximum performance is compromised. Each size was selected to find the right balance between a clean fit and the most grip possible. Each design's wide range of widths, offsets, and face profiles result in unique fitments ranging from 8.5" to 11" wide. Each wheel combines these features to meet the different brake caliper, strut, and fender clearance needs of each BMW model. Most vehicle models have options for wheels that range from direct-fit to aggressive for specialty applications. Daily drivers and professional racers don't have the same needs, so why should they be forced to buy the same exact fitment?
100% OEM Compatibility
No need to change your wheel bolts, center caps, or TPMS sensors. All APEX BMW wheels were designed from the start to work with OEM 60 tapered hardware, which means both OEM lug bolts and aftermarket stud kits with the proper lug nut seat type will fit perfectly. All of our 5x120 BMW wheels use a 72.56mm center bore, no hubcentric rings or adapters are necessary. All wheels come with gloss black APEX center caps, but you can also snap-in your OEM BMW caps for a more OEM+ look. All APEX wheels accept OEM and aftermarket equivalent TPMS sensors, and any standard-sized metal or rubber valve stem.
Brake Clearance
If the spokes or barrel of a wheel can’t clear your brakes, the wheel can’t be used at all. We’ve made sure all of our flow formed wheels clear OEM steel brakes spacer-free when the correct vehicle-specific designs and fitments are used. With many applications, even big brake kits will clear spacer-free. The 17" ARC-8 clears many kits up to 355mm. Our 18" wheels clear up 380mm, including the Brembo GT kit, which has long been the benchmark as one of the toughest brake setups to clear. Our 19" wheels clear even the 410mm BMW Carbon Ceramic brakes. View our fitment guides to confirm brake clearance, or contact us if you don't see your setup listed.
Weight Optimized
We conducted extensive Finite Element Analysis to reinforce high-stress areas and to remove material where it didn’t improve strength. The end result is a flow formed wheel with an ideal balance of strength and weight.
True VIA - JWL & Beyond
Many companies promote their wheels as being certified by the VIA when they actually aren’t. That’s like using the USDA logo on food without permission. APEX wheels get officially tested and registered by the VIA in Japan, and we have the proof to back it up. Japan’s JWL is a standard for wheel load ratings. Our wheels exceed those ratings. Most manufacturers only meet the minimum, while some even fall below—yet they still claim to be JWL. Always verify load ratings before you buy.
Learn more about VIA and JWL
Additional Features
Hub Centric - All APEX BMW wheels with a 5x120mm bolt pattern are purpose built featuring a 72.56mm center bore. No centering rings required.
Center Caps - We don't charge extra for caps and we design our BMW wheels to be interchangeable with the OE roundel cap for enthusiasts seeking a clean factory look. All wheels come with our gloss Black APEX caps included. We also offer optional gloss red or gloss blue APEX caps.
Hardware - APEX wheels can be used with all OEM mounting hardware, proper aftermarket hardware and wheel spacers. Wheel locks and stud conversion kits also work perfectly.
TPMS - All APEX wheels accept OEM and aftermarket Tire Pressure Monitoring Sensors and standard fit valve stems. If your vehicle isn’t equipped with sensors or you choose to bypass them for your track/race car, then select from our metal stems available in multiple finishes.
Lifetime Warranty
All our wheels come with a lifetime structural warranty and 1 year finish warranty, so you can be confident in your purchase.
APEX360 Wheel Replacement Program
Let’s face it: Whether you are a weekend warrior practicing at the track, a club racer pushing the limit for a podium finish, or your daily commute involves crater-ridden minefields known as city roads, mistakes happen and parts will be damaged along the way. We are not really a performance company if we sell wheels in a way that penalizes the pursuit of driving at the limit. For this reason, we stepped up and created a program to significantly reduce the costs of properly maintaining a set of wheels by making replacements extremely affordable.
Our unique APEX360 Wheel Replacement Program offers eligible customers replacement wheels at 50% off our standard prices.
Chassis-Specific Fitment Guides
We know what fits. From direct bolt-on to all-out race fitments and everything in between. We've street and track tested extensively to save you the trial-and-error. View our fitment guides.
APEX Flow Formed Wheel Gallery
Wheel & Tire Packages
Shop Tires
For your convenience, wheel and tire packages are now available at APEX. Our knowledgeable BMW Product Experts hand pick some of the best compounds available from prominent brands like Michelin and Nitto, and we’ve priced them competitively.
All wheel and tire packages include free mounting and road force balancing by our trusted enthusiast technicians. We use high-end, touchless equipment and inspect every wheel and tire combo thoroughly before they leave our warehouse.
Order Now
Questions?
Call: 925-245-0773
Jump to top ApexRaceParts is offline
Rate Seller View Rating
Old Wed, Dec-18-2019, 12:32:11 AM   #2
ApexRaceParts
Default Re: ► APEX | Flow Formed Lightweight BMW Wheels - Built to Perform
Jump to top ApexRaceParts is offline   Reply With Quote
Old Mon, Feb-17-2020, 08:42:10 PM   #3
ApexRaceParts
Strong and Light:
The I-beam spokes of the FL-5 and SM-10 reduce the rotational mass of these designs while also being visually striking.
Pick up your set today!
Discussing ► APEX | Flow Formed Lightweight BMW Wheels - Built to Perform in the E36 / E30 - Parts for Sale/Wanted Forum - Use this section to post parts for sale or wanted that are related to the E36 or E30 only. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
