Go Back   BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X) > M3Forum Garage > Audio/In Car Entertainment (I.C.E.)
Audio/In Car Entertainment (I.C.E.) Place to discuss sights and sounds.
Old Wed, Feb-25-2015, 02:01:10 AM   #81
SunD3v1L
hi
SunD3v1L's Avatar
Reputation: 0 SunD3v1L is on a distinguished road
Italy
Default Re: My highly unusual (weight/practicality focused) stereo project
I can't seem to find my lightning to 30 pin adaptor...
Jump to top SunD3v1L is offline   Reply With Quote
Old Fri, Feb-27-2015, 12:44:22 AM   #82
uscbeemerM3
uscbeemerM3's Avatar
Reputation: 0 uscbeemerM3 has disabled reputation
Question, not M3 related but audio related, is there a way to repair a blown home speaker if the speaker has rips along the edges? It rattles a little at certain parts of say a movie but doesn't rattle all the time, just certain loud action scenes. I tried putting black tape over the rips and that muffled it a little. No easy repair aside from replacing the actual speaker?
Current Car; 2008 S63 AMG. Still active on m3f, benz forums are empty.
Sold to my cousin; 2005 SMG II. Imola Red Inside
Koni Yellow struts/shocks with stock springs. M Track Mode (with M Track Mode light in the cluster),
CSL factory software via autologic (launch control is at 4800rpm), genuine CSL sway bars; front (30.8mm/hollow/8lb) and rear (22.5mm/solid/8lb), brake light mod all LEDs enabled when braking.
Jump to top uscbeemerM3 is online now   Reply With Quote
Old Fri, Feb-27-2015, 08:22:37 AM   #83
NealfromNZ
NealfromNZ's Avatar
Reputation: 0 NealfromNZ is on a distinguished road
New Zealand
If its the rubber or foam part of the edge suspension they can be removed and replacement re-glued. Some quality speakers can also be re-coned.
The rattle can either be caused by the suspension damage allowing too much movement of the cone or its a sign that the voicecoil has become damaged.
Jump to top NealfromNZ is offline   Reply With Quote
Old Tue, Nov-19-2019, 07:20:56 AM   #84
gixxer
gixxer's Avatar
Reputation: 0 gixxer is on a distinguished road
Intravee breakout box on top of Alpine HD radio on top of OEM bluetooth:
Hello, any chance you still have the above Intravee breakout box, and if for sale, after your upgrade to Avin headunit?
By the way, this is pushing it, but along the similar question (on older products), i recall way-way-way-back, you had Stealth1 for sale. Still have it?
Thanks much.
need2buy: LTW flywheel + clutch ;
wish: HPF ;
Mod Journal
Jump to top gixxer is offline   Reply With Quote
Old Tue, Nov-19-2019, 03:19:51 PM   #85
Thanks much.
yes to both-- I actually haven't sold anything from this project yet. Just sitting in a box in my basement
FS: Intravee and various compatible AI Net components.
Old Tue, Nov-19-2019, 08:35:18 PM   #86
gixxer
gixxer's Avatar
Okay, thanks.
Will PM you shortly.
wish: HPF ;
Mod Journal
Discussing My highly unusual (weight/practicality focused) stereo project in the Audio/In Car Entertainment (I.C.E.) Forum - Place to discuss sights and sounds. at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
