Old Wed, Dec-06-2017, 06:13:38 PM   #1
Kwakjoe
Kwakjoe's Avatar
Default Possible air scoop in place of Eventuri?
So I'm running an Eventuri intake without a air scoop (bought it that way) and I recently ran into one of these on eBay. What do you guys think? Worth the investment? Or should I just keep running the stock ducting.
https://www.ebay.com/itm/AVT-Lower-I...FXK8xj&vxp=mtr
Old Wed, Dec-06-2017, 06:34:06 PM   #2
C///M
Default Re: Possible air scoop in place of Eventuri?
If cost isn't a concern, you can buy the eventuri scoop on it's own from ECS or IND
Jump to top C///M is offline   Reply With Quote
Old Thu, Dec-07-2017, 12:23:53 AM   #3
Joshe46
Joshe46's Avatar
Id like to hear input as I also bought one without the scoop. And $280 IIRC is a little ridiculous for me
Old Thu, Dec-07-2017, 01:47:46 AM   #4
whips333
whips333's Avatar
I think the eventuri scoop is what makes the intake work so well. If you want the most out of the intake I will advise you to get the scoop.
Old Thu, Dec-07-2017, 05:37:11 PM   #5
Joe if you're going to buy one, get it straight from Evolve or a distributor for $170 (discount price right now).
I wouldn't waste $50 on that ebay one.
Be aware, adding a scoop will not do anything you'll feel whatsoever. It'll drop temps by a degree or two.
Do it for looks/just because, but don't do it expecting the eventuri to get louder or get more air - it's sucking in plenty of air where it sits AND there's stock ducting bringing in air
/// 2004 SilberGrau M3 · Coupe · 6MT · slicktop · manual seats · no nav · no xenon · no anything · JOURNAL
Evolve-R Alpha N · Evolve CSL CF Airbox · Eventuri Scoop · Supersprint V1 stepped 63mm · SS V1 S pipe 63mm + 200 cell HFC · OE sect 2 60mm · SS Sport 60mm · BMW Motorsport 4.10 · Besian · RE pullies/fan delete · WPC rod bearings · TMS Camber & Subf plates · RE Trans Mounts · AKG poly SUB/DIFF 95a · SDW RTAB · ZHP knob + UUC DSSR · GroundControl S/A (Koni/Eibach 376/440) + tall RSMs · OE CSL trunk · APEX 75mm Studs · Sportline 8S 18"x8.5/9.5" · MPSS 245/275 · Brembo 996 36/40 345mm Textar · Pioneer DEH-80PRS · Eclipse PA5422 · CDT HD-6 + WS-100i · CDT EX-530 · 8" Kicker
DD/Beater: 1999 Civic LX - Kenwood x998 · PPI 1600.4 · CDT HD-6 + HD-100 · CDT EX-530 · Clarion 10"
Old Thu, Dec-07-2017, 10:10:03 PM   #6
whips333
whips333's Avatar
If that is the case then why did evolve develop the scoop!? The scoop makes a big difference. Check out their video on the development of the e9X m3 intakes. All the facts you will need is right there.
Old Thu, Dec-07-2017, 10:20:02 PM   #7
11b4
11b4's Avatar
I run a stock Airbox with eventuri filter and scoop. Defiently has improved with the scoop.
Old Thu, Dec-07-2017, 10:36:36 PM   #8
What has improved?
The engine can only "suck" air at a certain rate through a certain sized "straw"
Adding a air scoop doesn't make it breath any better.
Cold air is already being fed to that area so the scoop isn't going to lower temps much.
Please explain how the car will be "better" with the scoop?
Or is this like how your car runs better after an oil change or a car wash?
Old Fri, Dec-08-2017, 12:11:44 AM   #9
Joshe46
Joshe46's Avatar
Tempted by the lower price, and then again you also discouraged me due to the fact it won’t do anything for me. Hmmm
Old Fri, Dec-08-2017, 12:45:26 AM   #10
11b4
11b4's Avatar
It's more responsive compared to the the stock nonexistent scoop(was the even a scoop? I don't remember) obviously at speed with air flowing up the scoop into the air box.
Discussing Possible air scoop in place of Eventuri? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
