Old Tue, Dec-05-2017, 04:42:11 PM   #1
dunkman23
dunkman23's Avatar
Reputation: 0 dunkman23 is on a distinguished road
Default Bought new Used 97 M3 - Keys arent matching
So I purchased an 1997 M3 Sedan over the weekend. And the door keys, ignition, and the Trunk release key doesnt match.
What is the best way handle this? Can I just go to my dealership the original key my VIN is assigned to and Tumbler/cylinder?
If i swap out the ignition cylinder/tumber, does it affect the EWS? Does anything need to be reprogramed?
2002 BMW ///M3 6mt TiAg /Imola - APEX ARC-8/PSS - BILSTEIN PSS10
1993 BMW ///E34 Touring - OBD1 S52 - 5sp MT, 3.23 LSD - SOLD
1997 BMW ///E36 Sedan -
2012 BMW ///E70 MSport -
Jump to top dunkman23 is offline   Reply With Quote
Old Tue, Dec-05-2017, 05:00:18 PM   #2
bluptgm3
Default Re: Bought new Used 97 M3 - Keys arent matching
Keys/tumbler need to match the VIN/EWS/ECU -
http://www.unofficialbmw.com/images/BMW_EWS.pdf
Old Tue, Dec-05-2017, 06:14:52 PM   #3
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
The EWS is aligned with the DME/ECU.
They keys/locks are linked to EWS. There is no direct link between keys/locks and DME/ECU.
Old Tue, Dec-05-2017, 07:44:49 PM   #4
bluptgm3
DME is aligned to EWS which is VIN specific. Keys and EWS are then VIN specific.
DME is VIN identified but not the driver, the key codes are in the EWS.
Old Tue, Dec-05-2017, 09:13:59 PM   #5
spaghettiM3
spaghettiM3's Avatar
Reputation: 0 spaghettiM3 is on a distinguished road
Wait... what?
Didn't you just say there is a direct link in your post? If the keys/locks are linked to EWS and EWS is aligned with the DME/ECU, there is a direct link.
IG - DaytonaViolet283
www.HealthyBeardOil.com
Jump to top spaghettiM3 is offline   Reply With Quote
Old Tue, Dec-05-2017, 11:10:44 PM   #6
dunkman23
dunkman23's Avatar
yea I'm confused now.
So if the person did infact change the keys , in order for him to do so.... he would need a Key that matches the Tubler/Cylinder, EWS, and DME>
what if he got a new cylinder/key and just did an EWS Delete chip? is that possible?
Old Tue, Dec-05-2017, 11:34:24 PM   #7
bluptgm3
LOL!! For the reading impaired - VIN encoded EWS and ECU have to ‘talk’ amongst themselves, EWS wins, it holds the codes, checks the keys.
Unless you know definitely different for 1996+ EWS II - http://www.unofficialbmw.com/images/BMW_EWS.pdf
Old Wed, Dec-06-2017, 05:20:11 AM   #8
dunkman23
dunkman23's Avatar
Originally Posted by bluptgm3 View Post
LOL!! For the reading impaired - VIN/EWS/ECU have to ‘talk’ amongst themselves, EWS wins, it holds the codes, checks the keys.
So I'm going thru that link you sent and looking at the 4 keys BMW offers. My key doesn't look like any of those.. hmmmm
Sent from my Pixel XL using Tapatalk
Old Wed, Dec-06-2017, 07:18:29 PM   #9
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
It’s not that difficult. Read my post carefully.
Old Thu, Dec-07-2017, 12:32:47 AM   #10
bluptgm3
Originally Posted by dunkman23 View Post
yea, I'm confused now.
So if the person did infact change the keys , in order for him to do so.... he would need a Key that matches the Tumbler/Cylinder, EWS, and DME…
The tumbler only has to mate with the key. The key needs to be recognized by EWS module, which comes from factory with 8 key chip ‘codes’.
OBDII is flash memory and yes EWS ‘conversation’ can be coded out of ECU.
That key is suspect #1!
No branding on any of the 9 BMW sourced key that I have.
My bet is that key (aftermarket) contains a mimicked factory key code and was cut from the Valet key.
Go to Dealer and buy two factory keys.
Discussing Bought new Used 97 M3 - Keys arent matching in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
