Old Tue, Dec-05-2017, 05:38:31 PM   #1
911Fiddler
Reputation: 0 911Fiddler is on a distinguished road
United Kingdom
Default Just learned something new about our racks
This is new to me, there is a torsion bar built into pinions and its mechanical properties (stiffness) determines steering 'feel'.
This thread about the non M3 E46s explains.
URL: https://forum.e46fanatics.com/showthread.php?t=954523
I have an old 911 pinion and can see a torsion bar in it.
Question: having just dropped in a purple tag rack I thought that I'd added some 'CSL' ness to her, however if the torsion bar differs, I havnt, except for the revised gearing ratio. Anybody ahead of me on this & know the whether the purple tag rack differs to CSL in this respect?
Jump to top 911Fiddler is offline   Reply With Quote
Old Wed, Dec-06-2017, 05:35:57 AM   #2
icecream
Registered Apples
icecream's Avatar
Default Re: Just learned something new about our racks
Is it a CSL Part number? If not then I would say no regardless if the ratio is the same.
Old Wed, Dec-06-2017, 08:17:26 AM   #3
911Fiddler
United Kingdom
Ive put in the std purple tag rack used on UK cars. The number ends in *679. I know this rack is used on the 330Ci Sport only (ZHP).
The details of the M3 CSL rack remains unclear, however post #11 on this thread tries to throw some light on it..
http://forums.m3cutters.co.uk/showthread.php?t=129820
Old Wed, Dec-06-2017, 07:22:16 PM   #4
Arehman
Arehman's Avatar
Reputation: 0 Arehman is on a distinguished road
Pakistan
Zcp/Csl are a blue tag.
2002 AW/IR 6spd coupe
Jump to top Arehman is offline   Reply With Quote
Old Wed, Dec-06-2017, 09:29:52 PM   #5
C///M
I thought this was common knowledge, but I suppose people mostly focus on steering ratio (and those that don't quite understand how everything works just refer to 'lock to lock').
Yes, the torsion bar is different on the blue tag CSL/ZCP racks which defines the steering feel and affects effort.
This is why I spent a lot more on a CSL rack than an E46 purple tag which are all over the place. But that said, it depends on what kind of feel you like. I just kind of feel like the purple tag racks, while nice and quick, feel very light and dead; more like a video game. Some people prefer that feel (on a street car).
Jump to top C///M is offline   Reply With Quote
Old Sat, Dec-09-2017, 03:04:29 PM   #6
911Fiddler
United Kingdom
Cheers for the reply. Ive been on the purple tag now for a few days with the toe set at zero -feels v nice, although part of the improvement is that the rack has less backlash so much reduced lost motion.
Re my new awareness on how racks work and that torsion bar, I thought it alarming that the torsion bar had such a thin diameter -its critical to safety, however after opening up an old 911 pinion I can see that they build in a failsafe, ie the torsion bar twists so far then a hard stop is reached to maintain steering 'connection'.
My purple tag rack has about 2.7 turns lock to lock. The old rack had about 3.2. What does your CSL original have?
Old Sat, Dec-09-2017, 05:11:10 PM   #7
Dave B
M3 collector
Dave B's Avatar
Italy
I installed the 712 yellow tag ZHP rack in my convertible. The directionality/turn-in on it strike me as absolutely perfect and natural...
My 14.5:1 ZCP rack is WORLDS better, feel-wise. It's not even close. And thus I have always been annoyed with my ZHP purchase and hate sitting back down in the vert after having driven the ZCP. (This has gone away slightly since obtaining the wagon, which is floaty garbage.)
Then again, I have had several other ZCP owners tell me that mine has the best steering feel they've ever felt, much better than yours, so maybe I just got some freakishly perfect unit in that.
Jump to top Dave B is online now   Reply With Quote
Old Sat, Dec-09-2017, 05:23:41 PM   #8
The one real ZCP I drove felt pretty similar to my ZHP rack, though I didn't drive that car at length.
Possible you're feeling a coupe vs convertible thing?
Old Sat, Dec-09-2017, 05:24:14 PM   #9
911Fiddler
United Kingdom
Interesting. For racks with the same part# with identical physical dimensions (ie the hydraulic porting) the power steering feel is going to be dependent on the torsional rigidity of that torsion bar inside the pinion this is likely subject to item-item variability from the manufacturing process -maybe why you've found a goodun, better than others.
How many turns lock to lock Dave on that ZHP yellow?
Old Sat, Dec-09-2017, 05:26:46 PM   #10
My yellow tag rack is about 2.7 lock to lock
Discussing Just learned something new about our racks in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
