Old Tue, Dec-05-2017, 04:17:43 AM   #11
ftc3
Reputation: 0 ftc3 is on a distinguished road
Default Re: Rear Headlight Leveling Sensor - Plug
Yep and I've broken them both! To easy and cheap to not replace.
Originally Posted by kaiv View Post
Protip: same connector and housing as the vanos solenoid.
PN# 61138383300
My journal
Dinan Intake | Dinan TBs | Schrick 280/272 | SSV1| SS Res Sec 2 | Dinan Exhaust | Koni Yellow | Dinan Springs | TTFS Tune | 356WHP
Jump to top ftc3 is offline   Reply With Quote
Old Tue, Dec-05-2017, 11:48:34 PM   #12
PN# 61138383300
One thing to keep in mind though is that the factory connector has only 3 of the 6 holes actually molded. The replacement connector will have all 6 holes, so you'll want sealing plugs for those (3 per connector):
https://www.mouser.com/ProductDetail...vity/967056-1/
There's probably a BMW part number too, but I don't know it.
Ive also sucecssfully used https://www.mouser.com/ProductDetail...MP/1-967616-1/ instead of the BMW part for the actual connector
Originally Posted by C///M View Post
I might not understand exactly what you said, but why not just order a new plug connector, pull the wiring pins out of the old connector and insert them into the new plug?
Seems like a lot more work to get a used plug with wires and then tap into the harness.
Yes, this is what I'd recommend if the wiring is still intact. That way you don't have to worry about recrimping the wires.
Old Wed, Dec-06-2017, 11:27:22 PM   #13
cosmos///m3
MMMmmmmmm....
cosmos///m3's Avatar
Reputation: 0 cosmos///m3 is on a distinguished road
Originally Posted by blatant View Post
Im parting out a convertible. I can cut the connector with extra wire if you'd like.
Send me a PM if you would like it.
Thanks man! I am out of town this week for work, but when I get back to my place I will see what my options are and get back to you.
PN# 61138383300
Thanks bud... that is exactly what I was trying to look for, but couldnt find a damn connector/housing part number
Yep I think this is what I am going to try and do, but like I said earlier I couldnt find any part numbers. Once I get back to my place next week I will see what my options are.
2005 ZCP Schwarz II/Imolarot 6spd ///M3 ||| 1999 Estoril Blau/Estoril Blau ///M Coupe "Clownshoe"
2014 Alpinweiss Uni/Mokka X5 ///M Package (wifey)
Originally Posted by hum3a
man i need a fu<kin wife to run errands for me......fu<k grocery shopping
Jump to top cosmos///m3 is online now   Reply With Quote
Discussing Rear Headlight Leveling Sensor - Plug in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
