Old Mon, Dec-04-2017, 01:27:54 PM   #1
cosmos///m3
MMMmmmmmm....
cosmos///m3's Avatar
Reputation: 0 cosmos///m3 is on a distinguished road
Default Rear Headlight Leveling Sensor - Plug
Alright guys quick question for you, and I believe I already know the answer, but figured I would ask just in case. Yesterday I was dropping the rear end on the M3 again for some new work I am doing and sending out the diff for some goodies to be replaced
....anyways, while dropping the rear end the Rear Headlight Leveling Sensor, clip/plug end managed to get wedged between the jack and subframe, which resulted in a cracked/broken clip. I believe this is tied into the main wiring harness, thus not a simple replace. I am guessing I would need to find a used clip and simply tap into the existing harness and reuse the new one. Please let me know if anyone else has had a similar issue and how you went about replacing/fixing things or if I am easily overlooking a better solution.
Photo borrowed from another thread...Original location of Sensor
Photo of Sensor Clip (current broken state )
Photo Of Sensor Clip... and shown the plug in background where sensor comes from on bottom of trunk.
Thanks,
Kyle
2005 ZCP Schwarz II/Imolarot 6spd ///M3 ||| 1999 Estoril Blau/Estoril Blau ///M Coupe "Clownshoe"
2014 Alpinweiss Uni/Mokka X5 ///M Package (wifey)
Originally Posted by hum3a
man i need a fu<kin wife to run errands for me......fu<k grocery shopping
Jump to top cosmos///m3 is online now   Reply With Quote
Old Mon, Dec-04-2017, 02:27:08 PM   #2
M3GA
Reputation: 0 M3GA is on a distinguished road
Default Re: Rear Headlight Leveling Sensor - Plug
If it still works, reconnect, zip tie, you're good to go?
Did you cut the wires?
Sent from my SM-G920V using Tapatalk
Jump to top M3GA is offline   Reply With Quote
Old Mon, Dec-04-2017, 03:14:52 PM   #3
cosmos///m3
MMMmmmmmm....
Yes it still works and no I did not cut the wires. A zip tie may work, but not 100% as there is no true way to connect it back and secure it to the sensor itself. Plus it will no longer be "weather proof" which isnt a huge concern, but always something to think about.
Old Mon, Dec-04-2017, 03:20:13 PM   #4
M3GA
Short of a proper fix (new harness connector, splicing wires), I'd reconnect, zip tie... and for "weather proofing", a little silicone bead would do the trick.
Old Mon, Dec-04-2017, 03:26:54 PM   #5
blatant
///Mthusiast
Reputation: 0 blatant is on a distinguished road
Im parting out a convertible. I can cut the connector with extra wire if you'd like.
Send me a PM if you would like it.
RK-Tune | Alpha-N | Dyno here-> here
Jump to top blatant is offline   Reply With Quote
Old Mon, Dec-04-2017, 11:48:57 PM   #6
Zroman610
Zroman610's Avatar
Reputation: 0 Zroman610 is on a distinguished road
I broke mine as well. I don't notice any difference between before and after it broke so I'm just going to let it go.
Jump to top Zroman610 is offline   Reply With Quote
Old Tue, Dec-05-2017, 01:31:19 AM   #7
kaiv
SoCal S54 specialist :P
kaiv's Avatar
France
Protip: same connector and housing as the vanos solenoid.
PN# 61138383300
E46 ///M325i Touring journal
Old Tue, Dec-05-2017, 02:08:15 AM   #8
Zroman610
Zroman610's Avatar
[QUOTE=kaiv Protip: same connector and housing as the vanos solenoid.
PN# 61138383300[/QUOTE]
Is this really necessary to replace? Mine broke a while back and haven't noticed any difference from before it broke
Old Tue, Dec-05-2017, 02:17:40 AM   #9
C///M
I might not understand exactly what you said, but why not just order a new plug connector, pull the wiring pins out of the old connector and insert them into the new plug?
Seems like a lot more work to get a used plug with wires and then tap into the harness.
Jump to top C///M is online now   Reply With Quote
Old Tue, Dec-05-2017, 03:46:19 AM   #10
CheckABS
Volks or bust!
Reputation: 0 CheckABS is on a distinguished road
I had the hardest time unclipping mine so I managed to break it as well.
Thank you for the tip guys.
ITRs | NSX | M3s | M5
IG: Book_a_Room
For Sale:
Volk TE37SL 18x9.5 +35 squared
Volk CE28N 19s
Jump to top CheckABS is offline   Reply With Quote
Discussing Rear Headlight Leveling Sensor - Plug in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
