Old Wed, Dec-06-2017, 11:26:30 PM   #11
Da Jemster
Institutionalized User
Da Jemster's Avatar
Reputation: 0 Da Jemster is a jewel in the rough
Default Re: Help! Bouncing idle after intake airbox reinstallation
Did you clean your filter and oiled it? I once over did my oil and didn't let it dry and had the same symptoms for a couple of days.
2008 E93 - AW - DCT - Stock...for now
2004 E46///CB-BLK///SMG II///D/A tuned///AFE Stg 2///SS Stepped///SS Metallic Cats///Eisenmann SS X-pipe///SS Race///4.10 diff///ACS CF Front Lip///6000K Xenons & Fogs///CF Grills & Gills///Angel Eyes///Clear Corners w/Solaris///Painted Reflectors///Black'd Sides & Tails///TEIN S
Jump to top Da Jemster is offline   Reply With Quote
Old Wed, Dec-06-2017, 11:28:39 PM   #12
Good
@GOOD_M3
Good's Avatar
I the third time I put it back together I got it worked, no idea what it was.
2006 M3 SILBERGRAU COMPETITION
EXTERIORJCSL 1X1 DIFFUSER | VÖRSTEINER CSL BUMPER
PREVENTATIVE ▌ VANOS BEISAN LOCKDOWN: UPPER GUIDE CHAIN | SOLENOID COIL PACK | OIL PUMP DISK
EXHAUSTSUPERSPRINT EXHAUST ~ OVERSIZED STEPPED V1 HEADERS | RACE CATTED SEC 1 | RESONATED X-PIPE SEC 2 | SPORT (GEN 2) SEC 3
BRAKES ▌ STOCK CSL/ZCP ROTORS | PORSCHE 996 BREMBO CALIPERS | SS LINES
WHEELS ▌ STOCK ZCP BBS 19" | 75MM ECS/TMS F&R WHEEL STUD CONVERSION
SUSPENSIONTURNER MOTORSPORT 30MM FRONT SWAY BAR | KW V2 COILOVERS | GROUND CONTROL CAMBER PLATES | SDW RTABS
ENGINE ▌ TUNED BY PAUL-CLAUDE | KARBONIUS CSL AIRBOX (ALPHA N), OEM SNORKEL (FLAP DELETE), OIL CATCH CAN
TRANSMISSION ▌'255' CSL SMG DME TUNE | INERTIA SMG DME UPDATE | WARM-UP LIGHT RECALIBRATION
Instagram: https://www.instagram.com/good_m3/?hl=en
Youtube: https://www.youtube.com/channel/ucow...3n7qdfz5nszria
Jump to top Good is online now   Reply With Quote
Old Thu, Dec-07-2017, 02:03:17 AM   #13
L0ADED
L0ADED's Avatar
Stated it above, but vacuum leak was most likely the issue.
Old Thu, Dec-07-2017, 02:26:27 AM   #14
Good
@GOOD_M3
Good's Avatar
I think it was the plug that connects to the bottom side of the airbox. The third time connecting it I really had to press it hard for it to click for some reason. Previous times I just put a decent amount of pressure to get it to sit in place but did not hear it click.
Old Thu, Dec-07-2017, 04:25:42 AM   #15
L0ADED
L0ADED's Avatar
Yup, that one caused the same issue on an aftermarket CSL airbox where the ICV port under the box was a tad too far for the connector to fully click into place. On startup, it would idle very poorly just like in your video, and it would stall when coming to a stop.
Discussing Help! Bouncing idle after intake airbox reinstallation in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
