Old Fri, Dec-01-2017, 06:17:36 PM   #1
Good
@GOOD_M3
Good's Avatar
Default Help! Bouncing idle after intake airbox reinstallation
So Iíve been dealing with this issue after a long drive where pushing the car above 3500-4000 rpm the car will throw eml, brake, disc and then following these lights the car goes into limp and throws the oil, battery light and cuts the power steering. I figured after pulling codes P0221 and P0121 from a generic ob2 reader that it was a tps so I purchased one and replaced the front sensor along with spark plugs and coils. This did not change anything after a test drive so I began pulling out the intake to access the tps sensor below the intake. I then went ahead and replaced the lower tps and after assembling the intake together and began to have this extremely rough idle as if the fuel line was being chocked. I made sure everything was connected and along the way I cleaned each plug with maf cleaner. I even went back and removed the manifold again and double checked that everything was connected correctly. I did not install the 6 clamps that connect the intake manifold to the engine as I will need to replace those so the only thing I could think of is this could be causing the issue but it seems airtight without them, could this really be causing this extreme idle?
I cant figure this out for the life of me. I did stupidly forget to disconnect the battery but the engine management fuses (pack of 5) all were in tact. I have pretty much searched every thread for a solution but nothing has seemed to work. I would really appreciate any input or previous experiences with this type of issue.
https://youtu.be/_lmczwa_Xiw
2006 M3 Competition | Silver Grey Metallic
Modifications:
- Complete SuperSprint Exhaust: Stepped V1 Headers, Race Catted Sec 1, Resonated X-Pipe Sec 2, Sport (Gen 2) Sec 3.
- Karbonius CSL Airbox (Alpha N) w/ Flap and Oil Catch Can
- KW V2 w/ Ground Control Camber Plates
Preventative:
- Vanos Beisan Lockdown~ Upper Guide Chain, Solenoid Coil Pack, Oil Pump Disk
Old Fri, Dec-01-2017, 06:27:46 PM   #2
Jeffy JJ
Jeffy JJ's Avatar
Reputation: 0 Jeffy JJ is on a distinguished road
Default Re: Help! Bouncing idle after intake airbox reinstallation
If you have the means, try clearing adaptations on the dme.
Jump to top Jeffy JJ is offline   Reply With Quote
Old Fri, Dec-01-2017, 07:03:41 PM   #3
Good
@GOOD_M3
Good's Avatar
Anyone in LA that would be willing to do this for me? Pm me and let me know how much!
Modifications:
Preventative:
Old Fri, Dec-01-2017, 07:16:46 PM   #4
angelr
angelr's Avatar
Reputation: 0 angelr is on a distinguished road
I'm not in La, I'm in the mountains near Arrowhead and Big Bear but if you're willing to drive a little I can do it for you. No charge, beer is always accepted. Great roads up here too!
07 z4 m coupe aw over ir
04 IR smg coupe- Dead
Jump to top angelr is offline   Reply With Quote
Old Fri, Dec-01-2017, 08:20:16 PM   #5
L0ADED
L0ADED's Avatar
Almost guaranteed there is a vacuum leak. Check the idle control valve connector under the intake manifold that it is fully clipped/secured and all six throttle body boots on the intake manifold are fully sealed. There is also the tube for the oil return under the manifold. Just double check all connections and you'll most likely find the culprit.
Old Sat, Dec-02-2017, 12:03:29 AM   #6
MrCooperS
Reputation: 0 MrCooperS is on a distinguished road
Did you unplug and plug in the MAF sensor by any chance? Someone once mentioned it’s possible to install it backwards and cause the symptoms you’re describing.
2005 BMW M3 ZCP |IB & Black Leather Interior
OEM gloss black kidney grills & fender grills | Osram DS2 bulbs | Smoked corners | IB valve cover | IB side markers | Angel eyes | Status Gruppe CF Trunk | CF CSL rear diffuser | CF front spoiler | US Mill Works tow hook license plate holder | Stainless steel M3 pedals
Auto Solutions 30% SSK | Eventuri Intake & CF Scoop | Macht Snell silicon intake elbow | Turner IAT relocation kit | WPC-treated rod bearings | CSL headers | Euro section 1 | Supersprint resonated section 2 | Supersprint sport section 3 | Eibach springs | Turner monoball FCABs | Apex EC-7 hypersilver wheels | Bridgestone RE71R | Apex spacers | Apex bolts
Ledarmanz perforated flat bottom steering wheel | Coby Alcantara shift + e-brake boot | ZHP Shift Knob | Armrest & cupholder delete + Euro tray | Schroth 3-point harness | Alcantara wrapped A+B+C pillars
Are you an E30 M3 owner? If you're looking to trade for an 05 Interlagos Blue E46 M3, message me!
Jump to top MrCooperS is offline   Reply With Quote
Old Sat, Dec-02-2017, 12:05:17 AM   #7
Good
@GOOD_M3
Good's Avatar
I attempted to install backwards but the way the screws sit it can only mount one way :/
Modifications:
Preventative:
Old Mon, Dec-04-2017, 02:13:32 PM   #8
ctdriver86
Reputation: 0 ctdriver86 is on a distinguished road
Make sure the oil drain hose to the oil pan is clipped on and all your hoses are tight. Im sure its your throttle bodies without clamps thats causing it. Its clamped for a reason, go to a parts store and buy clamps!
Jump to top ctdriver86 is offline   Reply With Quote
Old Mon, Dec-04-2017, 02:29:00 PM   #9
Drewster
Drewster's Avatar
Did you use worm-gear clamps on the throttle body clamps? Make 100% sure nothing is obstructing the throttle actuator
Old Mon, Dec-04-2017, 02:35:38 PM   #10
JaredMV
Amateur Weekend Mechanic
JaredMV's Avatar
You may have forgotten to plug one of the vacuum lines under your airbox in when you reassembled it. Same thing happened to me after I did my Vanos/airbox cleaning project.
Jared's Daily/Track '02 M3 Convertible: http://www.m3forum.net/m3forum/showthread.php?t=545658
Discussing Help! Bouncing idle after intake airbox reinstallation in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
