Old Tue, Nov-21-2017, 12:29:25 AM   #21
LockDots
LockDots's Avatar
Default Re: help: oem splash guards
Originally Posted by M_Parallel View Post
Thought you knew. Thatís for the dual pickup.
It has the main sump on the back, flat middle, smaller sump up front.
No oil splash guard as itís not needed. And provision for a second screenfilter and oil level/temp sensor.
Like most, the S50B32 is totally different.
I didn't, but should have. I forget that the euro engine is completely different.
Old Tue, Nov-21-2017, 01:14:40 AM   #22
westopher
westopher's Avatar
Does anyone know the parts needed to replace the whole assembly if you have the LTW splitter? I can’t find definitive parts that I’d need to use.
98 m3, techno/anthrazit cloth, 103k and officially worthless. 2000 323i touring, silver/grey/sport pack, 170k and officially boring.
Jump to top westopher is online now   Reply With Quote
Old Tue, Nov-21-2017, 02:09:45 PM   #23
thirtysixnick
Originally Posted by LockDots View Post
If you end up replacing all the parts mentioned in the original post, then the MM panel is actually cheaper even after shipping and including the optional radiator baffle.
Didn't think of the MM panel technically replacing all of those OEM parts, basically.
Regardless my parts have already been purchased and I'll use them till they fall apart then upgrade....
Old Tue, Nov-21-2017, 04:54:40 PM   #24
bmwstephen
regardless of MM or OEM they both total the same amount afterwards after shipping. tough choice for me to but wanted to stick with OEM because I know the design was for a reason. Ie the pork chops deflect air and the shape of underpanel and its baffel creates an inverse wing underneath for airflow underneath the car and to the radiator.
I guess the only thing I can do to prevent failure is to take better care of it (I am on stock suspension).
should they fail then I would consider the MM panel.
Jump to top bmwstephen is offline   Reply With Quote
Discussing help: oem splash guards in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
