Old Mon, Nov-20-2017, 05:17:48 AM   #1
bmwstephen
Default help: oem splash guards
hey gang. since my car never had oem splash guards (ripped off at some point in its life). I am confused on which pieces I am missing
obviously I need:
51712250643
51712250642
51712250641
but do I also need 51711977117 and 51711977118?
Jump to top bmwstephen is offline   Reply With Quote
Old Mon, Nov-20-2017, 05:45:30 AM   #2
solelybmw
Reputation: 0 solelybmw is on a distinguished road
Default Re: help: oem splash guards
Go to Bmw parts department and they can pull up what part #s you need. They are helpful in parts.
Jump to top solelybmw is offline   Reply With Quote
Old Mon, Nov-20-2017, 11:39:59 AM   #3
LockDots
LockDots's Avatar
Depends how "OE" you want to go. Personally for about that same amount of money and MUCH better durability, I would install a Motion Motorsport under panel. It's all one piece and strengthens the bumper as well as the wheel well liners.
The plastic OE pieces fall off much easier.
Old Mon, Nov-20-2017, 02:16:13 PM   #4
thirtysixnick
For people who are cheap the OE underpanel is still better than none imo and it's actually quite a bit more cheap than the MM panel.
Just bought basically everything to bring my front end to how it was before four other dumb asses owned it, on ECS, and it definitely gets pricey so the cheaper OEM panel is understandable to me. Easier to just throw in the OEM panel when doing shopping on the same site rather than switching over to MM and paying shipping, and more money for their panel.
If you wanted just the panel I'd suggest MM.
But it'll be fun to see how quickly my OEM panel falls apart so I can appreciate the MM under panel.
Old Mon, Nov-20-2017, 02:20:51 PM   #5
mitch500
mitch500's Avatar
Reputation: 0 mitch500 is on a distinguished road
+1 on MM under panel. Oem plastics are garbage
97 E36 M3 Coupe Alpine white
s54 swap in progress
Jump to top mitch500 is online now   Reply With Quote
Old Mon, Nov-20-2017, 02:46:31 PM   #6
LockDots
LockDots's Avatar
If you end up replacing all the parts mentioned in the original post, then the MM panel is actually cheaper even after shipping and including the optional radiator baffle.
Old Mon, Nov-20-2017, 02:54:08 PM   #7
bmwstephen
Was it 3 or 5 pieces you ended up buying?
Old Mon, Nov-20-2017, 03:24:54 PM   #8
kyrix1st
kyrix1st's Avatar
Japan
MM underpanel looks like it has different aerodynamics compared to the stock ones. I would personally use OEM parts on these areas.. i.e. the under guard from engine to transmission provides better cooling for tranny than without it.
WTB: Carbon airbox
'98 M3 evo (S50B32)
Rear: Stock-Endless CC-RG //
Recaro SPG, SR-2//
Sparco 35cm steering//
Hella headlights//
Old Mon, Nov-20-2017, 03:37:52 PM   #9
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
All these garbage underpanels, including the big one covering half the car are still fitted tightly on my car.
Guess ones garbage, is another man's treasure.
Old Mon, Nov-20-2017, 04:43:03 PM   #10
LockDots
LockDots's Avatar
Which underguard are you talking about? If anything, the MM underpanel reduces air turbulence in this area and I like the radiator baffle a lot better than the stock one.
Yeah, I wouldn't go somfar as to call it garbage. I think it also depends on the kind of roads and conditions you're driving in. For example, I autocross my car. There's no way the stock under panels would survive being hit by cones the way this under panel does.
Discussing help: oem splash guards in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
