Old Sun, Dec-03-2017, 06:15:03 AM   #61
babydocjd
babydocjd's Avatar
Reputation: 0 babydocjd is on a distinguished road
Default Re: Does Your E46 BMW Consume Oil?
Originally Posted by M3 dude View Post
only consumed oil when i ran tws.
switched to liquimoly, not even a drop
Iím switching to liqui moly, Iím adding oil at a alarming rate without any CEL,CPV valve not leaking,no smoke from the exhaust and no leaking oil anywhere.$hits ridiculous
///M Life
Jump to top babydocjd is offline   Reply With Quote
Old Sun, Dec-03-2017, 06:42:01 AM   #62
erickrayos
nope. my 325i did, changed the CCV and it helped but not completely gone. I know 330i's do burn but wasn't sure about my 325i.
But my M3 now doesn't burn oil. Only issue I had was the CPV which I addressed during header install.
Old Sun, Dec-03-2017, 03:12:19 PM   #63
exodus454
Reputation: 0 exodus454 is on a distinguished road
Mine consumes nothing using LM 10-60 (even at the track), will use 1/2 qt per OCI running 0w-40 M1 though.
05 ZCP - 6MT >> CPI Stepped Headers - Magnaflow cats & 1 Cherrybomb - Meisterschaft Titanium - CSL software - Eibach pro kit - 15mm rear spacers - BW studs - GC Hybrid FCABS - BW Spherical RTABS - TMS front bar
Manual Leveling - Factory Xenon - Nightbreakers - ZKW-R lenses
Jump to top exodus454 is offline   Reply With Quote
Old Mon, Dec-04-2017, 12:46:20 PM   #64
Speed Monkey
Bananas, Just Bananas
Speed Monkey's Avatar
From 0 to 60k-ish miles, it used a quart between 7k oil changes. Since the motor broke in a zillion yrs ago (so to speak), the blue bomber doesn't use a drop.
Jump to top Speed Monkey is offline   Reply With Quote
Old Mon, Dec-04-2017, 01:00:10 PM   #65
WyattH
Zero oil consumption.
TWS since new, 88K on the engine now, OCIs at ~4K (1x/year with my mileage, and per Dinan due to SC which shares oil).
Old Mon, Dec-04-2017, 02:55:48 PM   #66
Elgm
Reputation: 0 Elgm is on a distinguished road
Norway
Had to refill 1l the first 8000 kms when I bought my m3. Replaced the valve cover gasket, cpv ring, oil pan gasket, vanos gasket and the vanos solenoid O-rings, never had to refill between changes since. 200k kms/125k miles
Jump to top Elgm is offline   Reply With Quote
Old Mon, Dec-04-2017, 04:26:13 PM   #67
aerpelding
///M Driver
aerpelding's Avatar
Reputation: 0 aerpelding is on a distinguished road
I add 1 litre after 2500 miles. 149k miles on the clock. It's burning it, and not leaking at all. I'm going to do headers soon so i'll replace the CPV then. I'm thinking a tear down with bearings & rings replacement will be in my future. But, i put only 5k miles or less per year on my e46, so i'm not too concerned about it.
-Aaron
Laguna Seca Blau | Full Cinnamon Interior Swap | KW v1 | GC Street Camber plates | OEM e92 19" ZCP w/10mm Macht Schnell rear spacers | 245/35, 275/30 Michelin PSS | OEM 330d shifter | ZHP Leather weighted shift knob | Ledermanz Alcantara wrapped steering wheel | Coby Alcantara e-brake handle & Alcantara e-brake boot | Macht Schnell intake elbow | Macht Schnell air filter | OEM Fender Gills painted Gloss Black via iND | OEM Hood Grills painted Gloss Black via iND | OEM LED Taillight retrofit | Bi-Xenon D2S 4.0 Projector retrofit by Kustom54 Lighting | Streamline CF CSL Style rear diffuser | SuperSprint LTW Race |
Jump to top aerpelding is offline   Reply With Quote
Old Mon, Dec-04-2017, 06:26:50 PM   #68
GrendelsbaneM3
GrendelsbaneM3's Avatar
Reputation: 0 GrendelsbaneM3 is on a distinguished road
Talking Re: Does Your E46 BMW Consume Oil?
162K on the clock and no, its not burning oil.
My M3 is quite content with eating my bank account.
2004 Silver M3 / SMG / Koni Yellow shocks and struts / Vogtlands lowering springs / Eibach front and rear sway bars / Proflex bushings / Predator Orion V2 Multi-Color LED Angel Eyes / Laser Interceptors / Clear Bumper Reflectors / Zionsville Competition Cooling Kit with Offset Fan / AKG Motor mounts / Rogue Engineering Transmission Mount / AKG differential bushings / Euro mirrors / B&B Exhaust / CSL SMG tune /DME CSL tune / ESS 575 Supercharger
Jump to top GrendelsbaneM3 is offline   Reply With Quote
Old Thu, Dec-07-2017, 12:31:30 AM   #69
kuksul08
None perceptible on the dipstick
Old Sun, Dec-10-2017, 03:55:34 AM   #70
Arehman
Arehman's Avatar
Reputation: 0 Arehman is on a distinguished road
Pakistan
My current motor (05MY) doesn’t burn a drop on street or at the track. My first M3 however (01) burned almost a quart every 1000 miles. Had it when the car was under warranty and dealer said it was “normal”.
2002 AW/IR 6spd coupe
Jump to top Arehman is offline   Reply With Quote
Discussing Does Your E46 BMW Consume Oil? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
