Old Mon, Jan-23-2017, 03:19:48 AM   #1
6Gears
6Gears's Avatar
Reputation: 0 6Gears is on a distinguished road
Default Does Your E46 BMW Consume Oil?
Does any of this apply to the S54 engine?
Jump to top 6Gears is offline   Reply With Quote
Old Mon, Jan-23-2017, 03:53:03 AM   #2
2001E46m
Reputation: 0 2001E46m is on a distinguished road
Default Re: Does Your E46 BMW Consume Oil?
I believe not. S54 seems to use the M52 style ring.
Jump to top 2001E46m is offline   Reply With Quote
Old Mon, Jan-23-2017, 06:33:50 AM   #3
Flow
Flow's Avatar
France
Mine does not burn a drop of oil.
2004 M3 TiAg / LSB SMG
Old Mon, Jan-23-2017, 08:32:25 AM   #4
w3fl3x
...yummy...
w3fl3x's Avatar
Reputation: 0 w3fl3x is on a distinguished road
Mine does not burn oil either. That goes for both of my current m equipped with s54's.
Jump to top w3fl3x is online now   Reply With Quote
Old Mon, Jan-23-2017, 08:32:36 AM   #5
TheM
Reputation: 0 TheM is on a distinguished road
I've never had to add oil between changes. It stays at the top of the mark for 5000+ miles.
2002 M3 SteelGray/Cinnamon, TCKline, Besian, ACT clutch
A pair of Ducatis
Jump to top TheM is offline   Reply With Quote
Old Mon, Jan-23-2017, 01:22:56 PM   #6
Pnick
Pnick's Avatar
Same here. It stays at the same level from last oil change...not a drop required to top it off.
Old Mon, Jan-23-2017, 01:58:23 PM   #7
Dr M3an M3
GroupBuyingPower@outlook. com
Dr M3an M3's Avatar
As with everyone else posting, I have not had to add any oil between changes. I try to check it regularly and the levels are consistently the same. OP, are you finding that your car is consuming oil?
IG: DrM3anM3
Mods: Karbonius CSL Airbox, OE CSL Snorkel w/ working Flap, OE Map Sensor + OE Air Rail, Paul Claude Custom Tune, CSL Engine management with CSL converted DME, Supersprint V1 Stepped Headers w/ Oversized Catless section 1, SS Resonated X-Pipe section 2, RE El Diablo Muffler, WPC treated rod-bearings, VinceBar (weld) + Redish Plates, Full Beisan VANOS lockdown, BBS LMs w/ PSS, Streamline CSL Bumper, CSL style CF diffuser, Vorsteiner CF CSL Bootlid, CSL SMG Engine DME tune, CSL '255' SMG DME tune, .
Active Group-Buys (PM if Interested): OE CSL Bootlids, CSL Bumper, OE CSL Wheels, Supersprint Headers/Exhaust MEGA thread, CSL Airbox, Brembo, Cams/Pistons...and more to come!
Old Mon, Jan-23-2017, 02:04:37 PM   #8
No oil consumption here, either... on my S54s.
S62 on the other hand... is a two stroke
Old Mon, Jan-23-2017, 02:07:19 PM   #9
SQ13
2-3 liters between oil changes. ~4K miles/yr. Not a single drop consumed on track; always happens during normal street driving. Compression/leakdown test is way overdue.
Old Mon, Jan-23-2017, 02:30:12 PM   #10
legacyej25
Reputation: 0 legacyej25 is on a distinguished road
Happy to say, not a drop burned.
2002 Carbon Black on Cinnamon
Jump to top legacyej25 is offline   Reply With Quote
Discussing Does Your E46 BMW Consume Oil? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
