Old Tue, Nov-28-2017, 02:01:51 AM   #181
Schweeeebs
Schweeeebs's Avatar
Reputation: 0 Schweeeebs is on a distinguished road
Default Re: My 98 Dakar Yellow "build" thread
Originally Posted by Dee514 View Post
Beautiful car....I take it you are in Montreal? I grew up there but didn't see too many modded BMWs..
Yes I am from Montreal. There are quite a few modes e46 m3 and newer but e36 are pretty rare around here. I know 2-3 clean e36 in the province !
Cyber Monday was a good day.
Ordered some supersprint headers since they are 50% off.
Also ordered a bunch of small misc items :
Only thing left is Z3 steering rack. Found 2 on ebay for 200 usd but sceptical to buy from a scrap yard without seeing the part first.
Also played with my abrahams ltw wing.
The riser was crooked so removed it and straighten it to make it look better.
Before :
After :
I canít wait to start working on the real stuff. I have something getting done to my house and will have to take my car out of the garage this weekend sonI didnít start any big jobs. Once work on the house done :
1: both front wheel bearings
2: check both front and rear suspension
3: headers install and find exhaust rattle
4: fix small coolant leak from coolant level sensor. Will also replace the sensor while at it.
5: spark plugs
6: oil change
7: steering rack replacement
8: RK tune
Car will go to the body shop as soon as itís out of storage to take car of some small rust dots that appeared under the trunk rubber seal.
Long winter ahead !
Jump to top Schweeeebs is offline   Reply With Quote
Old Tue, Nov-28-2017, 03:47:11 AM   #182
Texaz3
Nice!
Old Mon, Dec-18-2017, 12:13:03 AM   #183
Schweeeebs
Schweeeebs's Avatar
Spent the whole weekend working on the car.
Removed the expansion tank and put some teflon tape and screwed in a new level sensor. Hopefully it wonít leak anymore.
Bumper was sagging a bit, so removed the 4 bolts holding it and adjusted it.
Put a brand new oem corner light.
Jacked the car on stands and started working on it.
Slowly making my way to the hub and bearings.
Had some trouble removing the wheel bearings race, but eventually gave up and just bent the dust collars so I could use the puller and pull them out.
Will need 2x part number 2.
Everything is out.
Canít advance unfortunately until I get the new dust protection collars. Hope the dealership has them stock, but I guess they wont have them.
Sourced a z3 steering rack. Will arrive soon. Hopefully wonít leak.
Canít wait to finish the bearings. Will proceed with removing the steering rack and the whole exhaust system to install headers.
Old Mon, Dec-18-2017, 02:56:44 AM   #184
englishtom1596q
englishtom1596q's Avatar
Had the same problem when I did my wheel bearings. Ended up pulling the race off using the dust shields and replaced them. Interested to see how you like your tune. Keep up the good work! This would be the time to add brake cooling backing plates btw or remove the stock ones so you can install aftermarket ones later.
Old Mon, Dec-18-2017, 03:56:56 PM   #185
Schweeeebs
Schweeeebs's Avatar
Hmm, I donít track the car so cooling ducts are a bit overkilled. Maybe if I find a diy that looks clean Iíll look into it, but donít know if I want to spend 200$ on a brake cooling vent kit.
Hereís the difference between a good and a bad bearing:
One had water and rust inside.
Old Mon, Dec-18-2017, 06:34:26 PM   #186
englishtom1596q
I'd say you could check out my build thread but photobucket killed all my pictures. If you take off the OEM shield you can add aftermarket ones while the hub is on. I'll try and get pics of mine. I don't have ducts and hose yet but wanted it in the future
https://flic.kr/p/HFW2DF
Old Tue, Dec-19-2017, 04:12:36 AM   #187
Texaz3
Yeah, that bearing looks shot.
Old Tue, Dec-19-2017, 05:49:35 PM   #188
Schweeeebs
Schweeeebs's Avatar
Getting the dust collars today. Dealer wanted 16$ each lol got them for 6$ each from someone else.
Why does bmw always inflate prices on parts like this ?
They do this with everything even bolts. Even plastic clips for trims. 7$ each we can only sell you 10 of them. Still canít understand the logic.
Old Tue, Dec-19-2017, 07:49:38 PM   #189
nholmes
Track Junky
nholmes's Avatar
I get my clips from China via eBay but I'm a track rat and not as much a purist.
Your thread is helping me learn about the front heat shields since I'll probably add front ducting in the future.
Follow my build thread here:
Old Thu, Dec-21-2017, 12:57:04 PM   #190
Schweeeebs
Schweeeebs's Avatar
Got the dust caps and also got a nice surprise in the mailbox (next to the mailbox because it didnít actually fit inside)
A nice z3 rack. 84k miles on it from Texas.
One boot has a cut but other than that looks pretty clean.
Need to finish installing bearings tonight and putting back the expansion tank. Hopefully Iíll start removing the rack over the weekend.
Discussing My 98 Dakar Yellow "build" thread in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
