Old Mon, Jul-15-2013, 02:47:57 PM   #1
Roux28
Grilled Cheese
Roux28's Avatar
Reputation: 0 Roux28 is on a distinguished road
Default Engine coolant temp, plausibility
Had this code show up. Turns out the thermostat was stuck closed. Replaced the thermostat.
A week goes by, and boom same code appears again.
What could else be the issue? Have I looked at everything?
Thanks
Jump to top Roux28 is offline   Reply With Quote
Old Mon, Jul-15-2013, 02:51:47 PM   #2
nrubenstein
Default Re: Engine coolant temp, plausibility
Have you replaced the sensor? I'd expect a plausibility code to come from the sensor, not the thermostat, even if it was stuck closed.
Old Mon, Jul-15-2013, 03:13:50 PM   #3
Roux28
Grilled Cheese
Roux28's Avatar
Ah, I haven't checked that, and that's more than likely it.
Thanks
Old Mon, Jul-15-2013, 03:32:56 PM   #4
Roux28
Grilled Cheese
Roux28's Avatar
To add, I see that there are 2 sensors #4 and #18. I believe that #18 is what controls the temp sender from what I read.
So more than likely it's going to be #18 that I need to replace for get rid of this code. Since #4 is pretty cheap and easy to do, I'll replace that as well. The thermostat and coolant are both already brand new.
Now if i could just find a DIY on # 18?
Old Mon, Jul-15-2013, 03:38:25 PM   #5
Hacksaw
What broke now?
Hacksaw's Avatar
Reputation: 0 Hacksaw is on a distinguished road
You are left pretty much going back in as if you were doing the thermostat.
One of the reasons I just add it to any cooling refresh. One time in and done.
'02 BMW ///M3
Imola Red|Blk Cloth|6MT|FS CSL Custom TUNE -MSS54HP|CSL Replica Airbox|Euro Headers|BimmerWorld 3.5" race front Y and resonator|Hacksaw's custom 3.5" SS exhaust system w/Magnaflow and 4 tipped goodness|SGT RS-ENR Coilover Kit|Evo Sport Performance Pulley Set|CDV Delete|UUC USS & DSSR|Sparco Roadster Seats|StopTech ST-40 BBKs on all 4|Beisan Systems vanos rebuild w/original stock exhaust hub|Kirk 4 point roll bar|CF CSL Rep Trunk|GC Race F/R Sway Bars|TR Motorsports MT-1|Avin Avant 2|Seibon CF GTR Hood
Jump to top Hacksaw is offline   Reply With Quote
Old Mon, Jul-15-2013, 03:52:12 PM   #6
Roux28
Grilled Cheese
Roux28's Avatar
Great
Well at least i know it's the source now.
Old Mon, Jul-15-2013, 04:59:35 PM   #7
kokgo20
kokgo20's Avatar
Is it the p00128 code i think?
Build thread
Old Mon, Jul-15-2013, 05:36:39 PM   #8
Roux28
Grilled Cheese
Roux28's Avatar
Yes I believe that's the code. I was using a Peake reader, which was code 69
Old Tue, Jul-16-2013, 12:44:42 AM   #9
kuksul08
I had that code, fixed the thermostat, still got the code. Oh well, not really that big of an issue.
Old Tue, Jul-16-2013, 01:48:02 AM   #10
waldron80
waldron80's Avatar
Reputation: 0 waldron80 is on a distinguished road
It is #18. It is under the air box and a pain to get to. Some people managed to change it out by not taking it all apart but I took the box out and cleaned my idle control valve as well. #4 does not communicate to the OBC. It is a thermal switch that runs the aux fan. I changed #18 and my code went away.
My RTAB Experience - Don't do what I did....
Often requested Tire Size Calculator -- My 3.5mm AUX install -- My home grown Maintenance Spreadsheet
Jump to top waldron80 is offline   Reply With Quote
Discussing Engine coolant temp, plausibility in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
