Old Thu, Jan-28-2016, 02:03:45 AM   #141
Eric M3
shogun
Eric M3's Avatar
Reputation: 0 Eric M3 is on a distinguished road
Japan
Default Re: The definitive guide to self diagnosing your ABS/ASC light.
Basically it is possible with the V8 in an E36 chassis, Alpina did it for example, but very difficult, engine not mounted from below, but from above http://www.alpina-archive.com/?page_id=59
But back to the subject: has somebody downloaded the pics for the repair and can post them here again? Thanks
Jump to top Eric M3 is offline   Reply With Quote
Old Fri, Jan-29-2016, 07:02:03 AM   #142
The Producer
The Producer's Avatar
Reputation: 0 The Producer is on a distinguished road
the pics weren't super helpful - the pinouts were the best part and they're available within the thread
Check here for more info
http://blog.bavauto.com/14248/bmw-di...es-and-others/
Also - tell us what your specific issue is.
Jump to top The Producer is offline   Reply With Quote
Old Fri, Jan-29-2016, 08:11:48 AM   #143
Eric M3
shogun
Eric M3's Avatar
Japan
No issue on my car, just was interested in the repair possibilities in case I have such a problem in the future. Thanks for the comment about the pics and the pinouts.
Old Fri, Mar-18-2016, 01:41:26 PM   #144
Slagdemon
Reputation: 0 Slagdemon is on a distinguished road
I was troubleshooting my ASC/ABS light issue last night and it turned out to be the broken solder points in the brake pedal travel sensor. Easy fix, once you figure out how to get the little clip off. Not much room to work with when you have man hands like I do.
Jump to top Slagdemon is offline   Reply With Quote
Old Tue, Apr-25-2017, 05:45:24 PM   #145
Frost12850
Reputation: 0 Frost12850 is on a distinguished road
I'm actually having this issue now as well. ABS/ASC light is not on when I start the car but as soon as I start moving faster than 5mph or so it trips on. I want to test the wheel sensors. It don't know where the module is behind the glovebox that was talked about and was hoping the pics would have still worked. Can anyone post a picture of what I need to remove once the glovebox is out? Or is there another way to test the sensors?
Jump to top Frost12850 is offline   Reply With Quote
Old Tue, Apr-25-2017, 08:12:28 PM   #146
jayjaya29
Photographer
jayjaya29's Avatar
Pull out the kick panel under the glove box in the passenger foot well. It will be the large connector closest to the door. Use a flat head screw driver to pop open the metal hinge and then the connector will release from the ABS computer enclosure.
Old Sat, Dec-02-2017, 06:38:12 PM   #147
Spanu27
Reputation: 0 Spanu27 is on a distinguished road
Romania
Can anybody tell me the pinout ABS ASC+T control unit, bmw E36 318 , year 1997 , engine M43.
Jump to top Spanu27 is offline   Reply With Quote
Old Thu, Dec-07-2017, 04:51:22 PM   #148
Spanu27
Romania
Nobody can help me to solve my problem I have change ABS sensor for all 4 whell, I have check all 3 fuse for ABS , I have check my relay for ABS it is good, my engine for ABS it s working ( I have schorted pins from relay ) and the lights from ABS& AST still on.
Old Wed, Jan-03-2018, 12:04:02 PM   #149
jrsc
Reputation: 0 jrsc is on a distinguished road
Hi all,
Happy New Year!!
Jump to top jrsc is offline   Reply With Quote
Old Fri, May-11-2018, 12:36:43 AM   #150
motorsports_3
Reputation: 0 motorsports_3 is on a distinguished road
Does anyone have a pic of the pinout locations so I know which location is which wire on the connector. I can’t find any numbers to begin with on the plug.
My abs/asc light used to come on intermittently, but now every time the car is turned on they are there. Any idea what it could possibly be or is every component tested at startup?
Jump to top motorsports_3 is offline   Reply With Quote
abs or asc, definitive, diagnosing, guide, light
Discussing The definitive guide to self diagnosing your ABS/ASC light. in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
