Old Thu, Dec-07-2017, 01:00:50 PM   #31
Mr.Sono
Mr.Sono's Avatar
Reputation: 0 Mr.Sono is on a distinguished road
Default Re: DIY: E46 M3 detailed rod bearing replacement and front suspension refreshment
wow, great diy.
Jump to top Mr.Sono is offline   Reply With Quote
Old Thu, Dec-07-2017, 02:09:32 PM   #32
TheSt|G
Resident Curmudgeon
TheSt|G's Avatar
Reputation: 0 TheSt|G has a spectacular aura about
Isle of Man
This is a DIY.
Current - '05 Interlagos E46 M3 SMG Delete 6MT Coupe - 3350lbs
Current - '85 Schwarze 911 3.2 Carrera 5MT Coupe - 2550lbs
911 Journal/Build Thread
Sold - '13 WRB BRZ Limited 6MT
Sold - '03 Lemans on Lemans E39 M5 6MT
Sold - '99 Kosmos-Schwarzes E36 5MT M3 Coupe
Jump to top TheSt|G is offline   Reply With Quote
Old Tue, Mar-13-2018, 04:43:17 PM   #33
den_bart
den_bart's Avatar
Reputation: 0 den_bart is on a distinguished road
would you guys say this is more difficult than doing a vanos overhaul?
Jump to top den_bart is offline   Reply With Quote
Old Tue, Mar-13-2018, 05:43:48 PM   #34
Radekxpl
Radekxpl's Avatar
Reputation: 0 Radekxpl is on a distinguished road
Poland
Not at all, just finished doing my rod bearing and mine is the newer model with this crazy torque procedure, its just time consuming and lot of things to disposable. Overall it not bad
2006 M3 Silver Grey
Mod list: TTFS Custom Tune, Headers Sec 1 AR20, M-Track Mode programmed, IAT relocated, Upadted cam bolts with S62 pressure springs and diaphragm, sub-frame reinforced foam/epoxy Vince bar & plates, 996 Brembo brakes PFC 08 pads, CDV delete, F10 M5 shift knob, CSL diffuser, black chrome grillies, smoked corners tinted windows, asymmetrical mirrors, Hardwired Bell Pro 300, D/A pulleys, AVANT-II, Dinan CAI, SDW RTAB, TCkline 500/600 GC Weight Jacks, GC Street Camber Plates, Beisan Oil Pump Disk, ECS camber arms, N15 SPAL 2082 fan, Micro-blue rod bearings, ZHP .712 Yellow tag rack.
Jump to top Radekxpl is offline   Reply With Quote
Old Tue, Mar-13-2018, 05:52:53 PM   #35
They are very different, I'll try to provide a summary, you assess.
Vanos is technically challenging (if you are doing the full bullet-proofing), but once you understand how it all works together, it is "simple" (subjective, obviously). Fewer parts to take off to get to it, you get to work from the top of the car. If you are just doing seals in sealing plate and pistons in the vanos unit, it's very quick and simple. If you are doing the full "bullet-proofing" with cam bolts, chain tensioner, upper chain guide, it's a bit more complicated and you need a timing tool. Do not do valve adjustment while doing vanos, do one first, then the other, order of which one you do first doesn't matter, but don't do them concurrently .
Bearings are a different beast. You work from the bottom of the car a lot. That said, there is plenty to do from the top like take off the power steering pump (it hides a few oil pan bolts, so has to come off). There are a lot more opportunities of "while I'm in there" with bearings job, like power steering hoses, new ps pump, engine mounts, steering guibo, control arms, tie rods, new tensioner pulleys, driving belts, swaybar endlinks and bushings. Obviously new rod bearings and oil pan gasket, but you might need new rod bolts if your car is post 12/31/2002. Check some of the seals on oil pump pickup lines, new oil pump (maybe?). Need to get a lot of power steering banjo bolt washers, new ps fluid. Upgrade the oil return line, if you have the older (non-metal) version. You have to drop the subframe, so you need a way to hold up the engine (with engine bar?). A lot more things to keep track of here, but it's not difficult.
Happy to help with VANOS or any other DIY job around NorCal
Old Fri, Mar-16-2018, 06:10:53 PM   #36
schoonerm3
Reputation: 0 schoonerm3 is on a distinguished road
Ireland
Im not sure if it was mentioned. I didn't see it anyways.
Are OEM bolts installed dry or oiled? I know ARP use lube
Jump to top schoonerm3 is offline   Reply With Quote
Old Mon, Mar-19-2018, 06:10:50 PM   #37
Da Jemster
Institutionalized User
Da Jemster's Avatar
Reputation: 0 Da Jemster is a jewel in the rough
Dry. You place the lube/oil on the bearings.
2008 E93 - AW - DCT - Stock...for now
2004 E46///CB-BLK///SMG II///D/A tuned///AFE Stg 2///SS Stepped///SS Metallic Cats///Eisenmann SS X-pipe///SS Race///4.10 diff///ACS CF Front Lip///6000K Xenons & Fogs///CF Grills & Gills///Angel Eyes///Clear Corners w/Solaris///Painted Reflectors///Black'd Sides & Tails///TEIN S
Jump to top Da Jemster is offline   Reply With Quote
Old Mon, Mar-19-2018, 08:04:14 PM   #38
rbg
Reputation: 0 rbg is on a distinguished road
Default Re: DIY: E46 M3 S54 detailed rod bearing replacement and front suspension refreshment
Guys is snap-on Techangle Torque will be a good tool for that crazy later s54 bolts tightening?
Jump to top rbg is offline   Reply With Quote
Old Mon, Mar-19-2018, 08:18:27 PM   #39
You don't need any special tools for that. If you have some spatial awareness, you start the handle at 12 o'clock, you end at 3 o'clock, that is 90 degrees. Nothing else special about angle torque. You can get it for peace of mind, but don't need it.
Old Mon, Mar-19-2018, 08:23:35 PM   #40
divedoc
Reputation: 0 divedoc is on a distinguished road
The Snap-On digital torque wrench is one of the coolest tools that I have, and it definitely comes in handy for the rod bolt tightening sequence. Yes, you can wing it, and you can also do it the old-fashioned way with an analog torque angle meter. I've done it all three ways on different cars, and it's much much easier with more peace of mind with a good digital torque angle meter.
If you're doing the job with the engine on a stand, where you can stand up and orient yourself with your tools in a nice open space, you can be just as accurate with an analog meter and you probably don't need the extra digital help. But if you're lying on your back, with barely enough wiggle room to get the angle you need, and you've already wasted your arms on the initial torque settings, the audible/visible/tactile feedback from the digital wrench will make this job almost enjoyable.
2003 Jet Black/Gray M3 Coupe 6MT
Jump to top divedoc is offline   Reply With Quote
Discussing DIY: E46 M3 detailed rod bearing replacement and front suspension refreshment in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
