Old Sun, Dec-03-2017, 06:47:11 PM   #41
Nate047
Nate047's Avatar
Default Re: 1998 Alpine White Sedan Build Thread
The optima battery did not come with the proper mounting and the price for such a heavy battery doesn’t make sense for me (agm drycell aside). I’d rather just have a lighter, cheaper Mini Cooper / CSL battery.
Not sure what you mean by BW tray?
NM, I didn't look close enough at that tray. The BimmerWorld tray is a pretty elegant solution, I have one with a RedTop since the battery my car came with wasn't the right size and it was bouncing around back there. I assume the "audiophile" previous owner of your car must have gone with the YellowTop to support mad tight stereo modz... No need for a battery that big. How big and how much does the Mini Cooper battery weigh? How do you have it tied down?
Old Sun, Dec-03-2017, 07:09:40 PM   #42
I had a stock E36 battery laying around so that is in there now. The Mini/CSL battery came in a previous E46 M3 I had. You're probably right about the Optima being for the audio stuff. The Mini battery isn't ideal for that or cold climate.
The mini battery is 34lbs versus ~45lbs. I believe the E36 already supports the shortened body with the provided mounts. There are several holes there for different sized batteries. I'm yet to try the Mini battery on the E36, just something I wanted to do... or go for broke on an OEM Lithium battery http://f80.bimmerpost.com/forums/sho....php?t=1004967
I didn't know BW made a battery tray. I will look into that. I'm not sure now but doesn't the optima also interfere with the fitment of the cover on that side too? I feel like it was taller as well.
Old Sun, Dec-03-2017, 09:52:26 PM   #43
L0ADED
L0ADED's Avatar
Really enjoying this restoration/build
Old Sun, Dec-03-2017, 10:58:22 PM   #44
Nate047
Nate047's Avatar
Yea I think the RedTop is 39 lbs. I can take it out and weigh it if you're interested, just lmk. It's a few pounds lighter than the stock style battery that was in there before. That F80 battery in the link you posted looks impressive at 30lbs, but is the price really $1100? That's crazy!
Here's the tray:
https://flic.kr/p/HcB5Ue
And with the battery:
https://flic.kr/p/ZMTo3e
The panel does indeed fit over it. This reminds me, I have some wiring cleanup to do myself...
Old Mon, Dec-04-2017, 12:21:28 PM   #45
Jawse36
Jawse36's Avatar
Reputation: 0 Jawse36 is on a distinguished road
Great restoration, enjoying the progress!
Jump to top Jawse36 is offline   Reply With Quote
Old Mon, Dec-04-2017, 01:44:35 PM   #46
Bimma360
Reputation: 0 Bimma360 is on a distinguished road
The work in here is properly OCD. It's fantastic. I have to thank you for sharing all of the products and techniques in achieving this stuff. This will help me tremendously.
E30 Dinan Turbo
Jump to top Bimma360 is offline   Reply With Quote
Old Mon, Dec-04-2017, 08:39:59 PM   #47
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Since you’re as OCD as me, or I as you, pick a side, how about fitting the original battery vent now that an original battery is fitted?
Maybe it’s already in place, but it’s not pictured.
Jump to top M_Parallel is online now   Reply With Quote
Old Tue, Dec-12-2017, 07:00:12 AM   #48
bmwstephen
Reputation: 0 bmwstephen is on a distinguished road
braymond do you have any pics of your power steering pump and pulley mounted W/O belt? I want to see the clearance for the metal pulley over the shaft as mine appears to be extremely tight (although there isn't any rubbing against the surrounding bracket)
Jump to top bmwstephen is offline   Reply With Quote
Old Tue, Dec-12-2017, 07:37:15 AM   #49
I don't, but it should be tight and spin freely.
Old Tue, Dec-12-2017, 03:33:27 PM   #50
bmwstephen
What’s wrong with current set of front seats now? When is your eta to get them redone? I may gave a buyer lined up for your seats
Discussing 1998 Alpine White Sedan Build Thread in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
