Old Sun, Jul-25-2010, 04:24:41 PM   #21
m3freak86
JERSEY STRONG
m3freak86's Avatar
Reputation: 0 m3freak86 is on a distinguished road
Great write up! Thanks again. I'm sure this will come in use in the future for me.
2013 SWP Subaru WRX Hatch (gone)
WRX Journal
2004 Carbon Black///M3 (gone)
Mods and Specs
My Exhaust Obsession
My Journal
Jump to top m3freak86 is offline   Reply With Quote
Old Sun, Jul-25-2010, 05:09:17 PM   #22
TRACK-CZAR
TRACK-CZAR
TRACK-CZAR's Avatar
Reputation: 0 TRACK-CZAR is on a distinguished road
Originally Posted by skelzy View Post
Good job..... The only part of your process that scares me is the shop vac blowing into the coolant resevior. I see the shop vac hose fits nicely over the cap but your essentially blowing debris back into your resevior. I would try rigging my air compressor first of something that wont contaminate the coolant... Otherwise, kudos for being creative....
I agree. I searched for my air nozzle for 30 minutes before giving up and going with the vac. You are correct that in saying that before you use your vac for this, be sure to clean the $#%! out of it.
GONE: 2005 IB ZCP,
NEW: 1997 M3 Sedan, Track Car
Jump to top TRACK-CZAR is offline   Reply With Quote
Old Sun, Jul-25-2010, 05:34:43 PM   #23
TRACK-CZAR
TRACK-CZAR
TRACK-CZAR's Avatar
Originally Posted by fergraz View Post
Thanks! Very good DIY but some pictures are missing at this moment.
I just checked.....I see all the pics I put in there. There are no pics from about #30 on, mostly just putting stuff back on.
GONE: 2005 IB ZCP,
Old Mon, Jul-26-2010, 02:29:40 AM   #24
AltF4
In for pics...
AltF4's Avatar
Reputation: 0 AltF4 is on a distinguished road
Default Did this today...
First off, thank you for such a thorough DIY! I've been thinking about doing a coolant flush for a while now. Read all the DIYs and the horror stories about how messy it is and how you'll get a coolant bath before it's all done.
I used TRACK-CZAR's and Function7's method as described here. I will vouch that it IS indeed messy. I just can't help to think that either the BMW techs that service M3's accomplish this another way (suction maybe?) or not. Maybe it's just the way the coolant system had to be designed. I've worked on many cars doing all sorts of jobs but this seems to be the most bizarre to me. But I digress...
I'd like to add a few points to this DIY that might be helpful. It might be a good idea to wrap the belts with some sort of plastic. The belts will still get a little coolant on them but it's always been best practice to prevent it. Since I just replaced the belts I wanted to protect them (looking straight down on where the temp sensor goes, it's been removed in this pic):
I also placed some towels around the engine bay when I did the blower method. The blower worked GREAT by the way. A lot more coolant came out then I really thought would. Here is an action shot for you guys:
And here is a video. I took this video after a good 3-4 minutes of blowing. Much more came out when I first started:
http://www.youtube.com/watch?v=KQYIQlghfpk
Also, on my '02, the VANOS cannister bolt is 10mm and the engine bolt is 13mm. The VANOS clamp was a little difficult to separate from the canister itself. There is a rubber lining/sleeve around the canister that kind of fused itself to the clamp. I had to CAREFULLY use a pry bar and gently release it from one side of the clamp:
Another thing, I dropped my oil cooler to prevent coolant from splashing any more than it had to. it's very simple to drop it and move it out of the way while the oil lines are still attached:
And yes, I went bare concrete garage floor. lol! But I keep my garage in such a way that I simply hosed off what didn't get caught, which wasn't much really.
Lastly, I hosed the engine down before starting it up as I didn't want coolant flung all over the garage by the fan. It made for a little extra work but kept things relatively tidy.
- Brian
2002 E46 M3 ~ SMGII
VMR V710 : TR MT1 : ZCP Brakes : StopTech : PFC : AR20 : UUC / Corsa
Ground Control Susp/Sway : RE FCAB : DICE : BW : AFE : PF : DEPO : Scoops
Coby Wheel : Black Trimming : Custom Alcantera / Brushed Alum Dove Grey
Jump to top AltF4 is offline   Reply With Quote
Old Mon, Jul-26-2010, 04:14:27 AM   #25
MadeInPhilly
Reputation: 0 MadeInPhilly is on a distinguished road
is it that difficult to remove the lower rad hose? with this method the coolant is splashing vertically up into the engine area.
Jump to top MadeInPhilly is offline   Reply With Quote
Old Mon, Jul-26-2010, 10:47:08 AM   #26
fergraz
fergraz's Avatar
Reputation: 0 fergraz is on a distinguished road
Puerto Rico
Sorry, but I see this on my browser:
2002 SMG ///M3 Tiag/Gray leather All Stock with 3x,xxx Miles
Jump to top fergraz is offline   Reply With Quote
Old Mon, Jul-26-2010, 12:33:23 PM   #27
cncmastr
M-Texture Alcantara
cncmastr's Avatar
Reputation: 0 cncmastr is on a distinguished road
Well done sir!
I too just drained the fluid through the temp sensor rather than removing the lower hose connection.
2006 Interlagos Blue BMW ///M3 | ZCP | Xenon | Nav | Premium | M Texture Alcantara | Euro Headers & Cats | TTFS | CSL Airbox w/Flap | Shrick 288/280 - 350whp 275wft-lbs
Collection of my DIY Guides here
Personal Blog
http://www.obsessedmotorsport.com/blog
Jump to top cncmastr is offline   Reply With Quote
Old Mon, Jul-26-2010, 11:51:43 PM   #28
Monsoon
Simple is the New Mod
Monsoon's Avatar
Reputation: 0 Monsoon is on a distinguished road
Great write up and thanks! But one question. On step 35 you have it written -
35. I opened and closed the bleed valve a few times. Ultimately, I stopped seeing fluid come out.
Don't you mean that you opened and closed it until all the "air" got out? I would think this would be a bleed valve to let air out. I've never done this, so I'm just asking for my own good.
Thanks again for the great write up!
Jump to top Monsoon is offline   Reply With Quote
Old Tue, Jul-27-2010, 04:36:17 AM   #29
ILLuSioNz X
Built, not bought
ILLuSioNz X's Avatar
Reputation: 0 ILLuSioNz X is on a distinguished road
this thread is so helpful, i'll be checking back here in a few months when it's time to do my coolant flush.
-Chauncey
2003 E46 M3 COUPE
Engine/Transmission: "Bolt-on's"
Wheels/Tires: 18 TE37SL & Falken RT615K
Suspension: TRM Coilovers 780F/895R|OEM Front & Turner Rear Reinforcement Plates|RE Rear Spring Perch Reinforcement|GC Race FCABs|GC Monoball RTABs|Godspeed LCAs|Turner Monoball Upper CAB|Turner Sway Bars|Turner Subframe Reinforcement (installed by Coinage)|Turner Solid Subframe, Differential, Motor and Transmission Mounts
Braking: Rotora 4-Piston Calipers|S/S Lines|Ate Dot4|Powerslot Rotors|Ferodo DS2500 Brake Pads
The Official Supercharger Kit Maintenance/Replacement Parts Thread (VF, AA and ESS)
Jump to top ILLuSioNz X is offline   Reply With Quote
Old Tue, Jul-27-2010, 05:11:33 AM   #30
AltF4
In for pics...
AltF4's Avatar
I left the bleeder open just enough until the bubbles were gone. I'm sure that's what he meant. I also had to add about another 1/2 gallon of distilled water. Makes me wish I had two gallons of coolant to get an even 50/50 mix. I'm sure it's fine though.
2002 E46 M3 ~ SMGII
coolant, diy, easy, flush, method
Discussing Coolant Flush DIY - Easy Method in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
