Old Mon, Sep-04-2017, 01:35:51 AM   #11
Speed Monkey
Bananas, Just Bananas
Speed Monkey's Avatar
Reputation: 0 Speed Monkey is on a distinguished road
Default Re: Rumble in 2nd Gear Full Throttle/Heavy Load
Ignition coils for a vibration originating from the rear end.... Whut?!
OP, if you have not replaced the driveshaft bushing, I'd wager this is the gremlin that's the root of your problem. It looks like this:
It costs a whole whopping $9 dollars! - from ECS. This little devil slips on the nose of the driveshaft. Since you've been driving the car and giving the center support bearing a good workout in trying to minimize the driveshaft vibration, replacing that would be a good preventative measure. Lastly, having a worn driveshaft bushing feels like having a bad center support bearing. Have fun underneath your sled... .
Jump to top Speed Monkey is offline   Reply With Quote
Old Mon, Sep-04-2017, 11:34:48 PM   #12
trumpsterfire
Reputation: 0 trumpsterfire is on a distinguished road
Should have mentioned already replaced this as well. I did this with the center support bearing. I gotta feel like it's cv joint or the half shafts.
Jump to top trumpsterfire is offline   Reply With Quote
Old Tue, Sep-05-2017, 12:32:39 PM   #13
Fissionx
Applied Physics
Fissionx's Avatar
Reputation: 0 Fissionx is on a distinguished road
Originally Posted by deadlysyns View Post
had same problem, replaced drive shaft bearing and guibo but still had problem, replaced driveshaft and all is good now.
Same here
Dan - 2005 BMW M3 SMG 170km stock
Jump to top Fissionx is offline   Reply With Quote
Old Tue, Sep-05-2017, 01:18:45 PM   #14
F1Dryvr
Reputation: 0 F1Dryvr is on a distinguished road
Driveshaft CV Joint. Youtubes online on how to repack with grease. Or the Assembly is roughly 200$ if you want to save about 4-5hrs, half a bottle of go jo, 20 or so rags and a t-shirt....unless of course youve done this a few times.
On mine the cause was the 5$ Red gasket that broke apart between the shaft and the diff flange. Be sure to put a new one of these in as well.
Jump to top F1Dryvr is offline   Reply With Quote
Old Tue, Sep-05-2017, 07:08:05 PM   #15
trumpsterfire
I have a feeling that gasket may be bad on mine. When i did the subframe job i don't remember seeing when reassembling. I'm guessing if that's gone then all the grease will just leak out over time.
Old Tue, Sep-05-2017, 07:38:10 PM   #16
F1Dryvr
yes, there will be a telltale sign of LOTS of grease spinning out of it radially all over the rear of the car...
Old Thu, Sep-07-2017, 01:29:58 PM   #17
trumpsterfire
Got the old CV joint off. It seemed ok at first but moving it certain directions seemed to make it bind up. After cleaning it and taking it apart it seems like some scoring happend and maybe this explains the issues. I ordered a new joint so i'll update when its installed.
Old Sat, Sep-09-2017, 03:21:02 PM   #18
TheM
Reputation: 0 TheM is on a distinguished road
Originally Posted by FaWaZ91 View Post
Might be a bad coil
No. He said it happens in second gear only. How could a coil misbehave in only one gear?
2002 M3 SteelGray/Cinnamon, TCKline, Besian, ACT clutch
A pair of Ducatis
Jump to top TheM is offline   Reply With Quote
Old Sat, Sep-09-2017, 03:25:13 PM   #19
EricSMG
40 something
The only catch here is that since you've dissembled the driveshaft you probably need to have it re balanced.
I would also take a very close look at the center u-joint - if there is much play the DS is junk.
'04 SG/Black 6MT || '04 JB/IR SMG
Jump to top EricSMG is online now   Reply With Quote
Old Sun, Sep-10-2017, 04:54:13 AM   #20
F1Dryvr
I reassembled mine and had no issues w balance or vibration after.
Also u might give it a trial at repacking w grease and see if the binding is gone when reassembled. Not sure how bad te scoring was...
Discussing Rumble in 2nd Gear Full Throttle/Heavy Load in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
