Old Tue, Nov-13-2018, 11:01:51 PM   #1
Texaz3
Default Squeaky belt/pulley/tensioner - help diagnose
I have developed a squeak which is coming from a tensioner or a pulley, so without buying a bunch of parts how do I go about figuring out which one is it? Or do I just replace all?
Old Tue, Nov-13-2018, 11:17:41 PM   #2
NolliM3
NolliM3's Avatar
Default Re: Squeaky belt/pulley/tensioner - help diagnose
I would place my money on the idler pulley...encircled in green. A better-diagnosis would be to use a mechanic stethoscope.
File Type: png Screen Shot 2018-11-13 at 6.08.31 PM.png (370.3 KB, 28 views)
1995 Alpine White...X-Brace, Fan delete, Cold Air Intake, Coilover F 450 R 450
Old Wed, Nov-14-2018, 12:17:00 AM   #3
omairtheman1
Reputation: 0 omairtheman1 is on a distinguished road
Replacing all tensioners and belts is less than 200 dollars with all parts considered.
I highly suggest that you replace everything while you're in there.
Jump to top omairtheman1 is offline   Reply With Quote
Old Wed, Nov-14-2018, 12:57:02 AM   #4
I agree with Omair. I gave up picking away at these common failures and just do everything when due.
My answer is to do it all new.
Old Wed, Nov-14-2018, 12:57:33 AM   #5
bluptgm3
Idler pulley is actually #14, it can be identified in the image by the off-center fastener hole.
The tensioner pulley #6 has the attach fastener hole on center.
The bearings #5 on the pivot shaft are not sealed. They can get dirty and seize causing the tensioner action to become sluggish or non existent allowing the belt to slip, most likely on the alternator pulley.
I have brinelled the pivot shaft with bad bearings attempting to release pressure during belt installation.
Old Wed, Nov-14-2018, 02:44:50 PM   #6
Reauxtide
Reputation: 0 Reauxtide is on a distinguished road
I replaced my idler pulley last year. I was sure that was the one squealing after I used a stethoscope. It wasnít.
I just ended up ordering all new tensioners, pulleys, and belts. Perfectly quiet again.
It just didnít seem worth it to keep troubleshooting when they all had 100k on them anyway.
Jump to top Reauxtide is offline   Reply With Quote
Old Wed, Nov-14-2018, 03:14:21 PM   #7
fattycharged
can't even
fattycharged's Avatar
Reputation: 0 fattycharged has disabled reputation
Zimbabwe
FCP euro, replace all
Topo Chico
Jump to top fattycharged is offline   Reply With Quote
Old Wed, Nov-14-2018, 03:19:58 PM   #8
huxcrunner
Reputation: 0 huxcrunner is on a distinguished road
There is the water on the belt trick to rule out any misalignment/belt issues with it causing the pulley to have a side force but agreed you should probably replace them all it will make a huge difference immediately and its not very hard to do. I just did mine. Also suggest the Conti gatorback belts if youre going to go all in that stops all belt noise.
Jump to top huxcrunner is offline   Reply With Quote
Old Wed, Nov-14-2018, 04:55:59 PM   #9
propchef
Toodle-oo Motherf**kers
propchef's Avatar
Reputation: 0 propchef is on a distinguished road
I just ordered this yesterday.
https://www.fcpeuro.com/products/bmw...-11287636378kt
It's my weekend project.
Originally Posted by AllwaysLow View Post
x2 and some Chicago style pizza
Originally Posted by M3Dom View Post
He's suffered enough.
Originally Posted by EKaru View Post
STFU Klong!!!!! Go Fuk Yourself!
Jump to top propchef is offline   Reply With Quote
Old Wed, Nov-14-2018, 05:16:15 PM   #10
Texaz3
All right gents, sounds good, I'll just replace all.
Thanks!
Discussing Squeaky belt/pulley/tensioner - help diagnose in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
