Old Thu, Apr-03-2014, 01:51:36 PM   #31
ThunderMoose
Default Re: Compression spring SMG dropping out of gear DIY
Originally Posted by jdamore44 View Post
U think we have it lined up ok now, just gettin that plug pressed in is a B*tch! Gave up late .. gonna try again later today
It is. You really need to fit a tool between plug and tunnel wall and try to lever it in. I think I lost two finger nails trying to remove.
#67 2017 NASA TX TT3 Champion
Old Thu, Apr-03-2014, 03:10:41 PM   #32
jdamore44
Reputation: 0 jdamore44 is on a distinguished road
Yeh thats the approach we are taking. Can get the bottom half seated. Top half isnt cooperating. The first time the tranny was on the ground and made it pretty damn easy. Ugh. I just put a new clutch in... got everything buttoned up and got a error code 59. Clutch actuation dynamics. As soon as I turned the key.. all connectors are hooked up... I cant get it to go in gear... so confused
Sent from my SPH-L710 using Tapatalk
1983 320iS - SOLD
1997 328iS Sport - SOLD
2003 Steel Grey Metallic M3 6MT Coupe, Black Interior
Jump to top jdamore44 is online now   Reply With Quote
Old Thu, Apr-03-2014, 04:31:58 PM   #33
kokgo20
kokgo20's Avatar
How any springs are there? part numbers? exact locations?
Build thread---------- INSTAGRAM ------------ROTREX REBUILD-------------Now offering custom digital gauges
2004 SMG PY/BLK - 600 TCKline - CPI Headers & resonated Sec1- Stoptech BBK 6 pod front & 4 pod rear with steel lines - 75mm Studs conversion - SDW monoball RTABs - AKG subframe bushings - Multi color AEs - FR-X 3.0 Projectors - Smoked Side markers - Euro bumper - V1 with hard wire & Stealth one - M Track Mod - ZCP steering rack - Dual LI - CSL Style diffuser - SCZA Exhaust - E9x Door handle LED retrofit - SCZA CSL bootlid - VEI systems custom air vent A/F & boost gauge - VEI custom air vent Water temp & oil pressure guage- Active Prima plus + TTFS tune - Mishimoto Radiator & Oil cooler - H&R front Sway - UUC camber arms - keyless & push to start system - clear bra - interiors red stitching contrast - Apex PS7s - 16" Spal fan
Jump to top kokgo20 is online now   Reply With Quote
Old Thu, Apr-03-2014, 05:13:43 PM   #34
jdamore44
Apparently there are atleast 3..*one for each pair of gears.. 1-2, 3-4, 5-6*. I just did the one I've read that breaks..
I replaced #6 (23311228397)
I've read the other's have done all of them....
[URL="http://www.realoem.com/bmw/showparts.do?model=BL93&mospid=47714&btnr=23_0956& hg=23&fg=15[/URL]
1983 320iS - SOLD
Old Thu, Apr-03-2014, 06:23:30 PM   #35
Zabalzae
Zabalzae's Avatar
Reputation: 0 Zabalzae is on a distinguished road
I replaced all of them while the transmission was out. Got them from bmwpartssource.com cheaper than ecs. Just got the part numbers from realoem.com
Jump to top Zabalzae is offline   Reply With Quote
Old Thu, Apr-03-2014, 09:44:35 PM   #36
jdamore44
Do you guys think that by having this mis aligned would cause me to have a Clutch Actuation Dynamics Error 59?
1983 320iS - SOLD
Old Fri, Sep-25-2015, 08:00:42 AM   #37
TerryFolev
Reputation: 0 TerryFolev is on a distinguished road
Bulgaria
Was misalignment the issue? Reviving an old thread because I am about to do springs on my car.
Jump to top TerryFolev is offline   Reply With Quote
Old Wed, Sep-30-2015, 11:11:11 PM   #38
JAVI'S M3
JAVI'S M3's Avatar
Reputation: 0 JAVI'S M3 is on a distinguished road
Default Compression spring SMG dropping out of gear DIY
UPDATE: I went straight to the spring that holds the pin (#6 on the diagram above) and found the spring broken in 3 places, I never been so happy to find a part of my car broken. I changed the pin and spring, used the same plug and now it runs like a champ. I still have the used GPS with 60k on it if any one is interested in buying it.
My issue is that my ///M keeps skipping 3rd gear only. Also takes a few seconds to get into 2nd. I'm trying the GPS first then go for the springs second. 4th and 5th are fine. Have not tried going into 6th yet.
Jump to top JAVI'S M3 is offline   Reply With Quote
Old Mon, Jan-04-2016, 07:04:43 AM   #39
aznbeayst
: RAT3D M :
Reputation: 0 aznbeayst is on a distinguished road
Originally Posted by DrPaul View Post
I had a problem with 3rd and 5th. Previous posters have mentioned replacing all three springs since it is a PITA to get to them. realoem.com shows 5 springs and one of them appears to be only available as a kit (#17). For those that have done this, which springs did you replace specifically by part number (23311228393, 23111222720, 23317511337, and 23311228405)? Thanks in advance!
Hey DrPaul can you confirm which springs you replaced? Did you replace all of them?
Can someone confirm this other diagram from realoem? It looks different than the one posted by DrPaul...
Based on this diagram, I thought I want to replace #6 and #7 but on DrPaul's diagram, the part numbers are different?
http://www.realoem.com/bmw/showparts...56&hg=23&fg=15
Thanks
Jump to top aznbeayst is offline   Reply With Quote
Old Mon, Jan-04-2016, 07:54:05 PM   #40
aznbeayst
: RAT3D M :
Thanks
help, thanks!!
compression, diy, dropping, gear, smg, spring
Discussing Compression spring SMG dropping out of gear DIY in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
