Old Thu, Mar-23-2006, 11:48:03 PM   #1
bigneil
bigneil's Avatar
Reputation: 0 bigneil is on a distinguished road
Default Blower Motor Resistor vs Final Stage Unit
I bought two new parts hoping to fix my A/C (a new blower motor in 2004 makes that an unlikely culprit).
I bought the Final Stage Unit and Blower Motor Resistor - below is the DIY for the FSU, but where does the BMR go?
http://forums.bimmerforums.com/forum....php?p=3349096
Jump to top bigneil is offline   Reply With Quote
Old Fri, Mar-24-2006, 11:15:55 AM   #2
bigneil
bigneil's Avatar
Someone must have done this simple DIY....
Old Fri, Mar-24-2006, 11:44:47 AM   #3
PurpleM3Pursuit
E36 on the way out... E92 on the way in..
PurpleM3Pursuit's Avatar
Reputation: 578 PurpleM3Pursuit has a reputation beyond reputePurpleM3Pursuit has a reputation beyond reputePurpleM3Pursuit has a reputation beyond reputePurpleM3Pursuit has a reputation beyond reputePurpleM3Pursuit has a reputation beyond reputePurpleM3Pursuit has a reputation beyond repute
not yet.. and my bentley isn't handy.. otherwise i would have it for ya..
Alex... or PM3P... being a good Leader for YOU!
E92 M3 AW/BL Competition
BMWCCA# 368302
Also in the fleet:
'75 Porsche 911 Carrera
'85 Chevrolet Camaro Z28
'87 Porsche 951
'95 BMW 325i DM #422
'15 F150 EB SCrew
Jump to top PurpleM3Pursuit is offline   Reply With Quote
Old Sat, Apr-01-2006, 12:23:20 AM   #4
bigneil
bigneil's Avatar
Well I replaced my final stage unit (turns out the resistor was only for dial-style climate control). It was extremely simple - just remove the dash panel under the steering wheel (3 screws) and you can actually access it directly, or you can remove the knee bolster (3 10 mm bolts). The Final stage unit is simply held on by two star-screws (I used an Alan key to turn them), and an electric plug. Anyhow the whole job took 15 minutes and I turned the key and said a prayer - voila! My AC works like new again!
Note: the new style ones have many more, smaller pins than the old one.
DIY: E46 M3 Final Stage Unit / Resistor Location zshiek Faults, Fixes and DIY 10 Sat, Oct-30-2010 07:00:07 AM
Blower motor or final stage resistor? mighty-dog E36 M3 (1992-1999) 2 Tue, Nov-28-2006 12:12:47 AM
Blower Motor Resistor rokayama General BMW Discussion 1 Mon, Jul-31-2006 07:03:36 AM
WT heck is the Final Stage Resistor (blower motor) on my 99 M3?! magas E36 M3 (1992-1999) 5 Sat, Jun-19-2004 06:01:40 PM
final stage blower resistor install??? punkska20 E36 M3 (1992-1999) 1 Fri, Jul-25-2003 07:46:52 PM
Discussing Blower Motor Resistor vs Final Stage Unit in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
