Old Tue, Dec-21-2010, 08:48:19 PM   #1
jcreme
Mechanical? Engineer?
jcreme's Avatar
Reputation: 0 jcreme has disabled reputation
Default Rattly bad-idler-pulley sound coming from tranny area?
I've got a weird, rattly bad-idler-pulley sound coming from tranny area. Only on startup, when idling hot or cold., It goes away after about 20s. Anyone know what that is?
Original Owner 2003.5 IR 6MT
Jump to top jcreme is offline   Reply With Quote
Old Wed, Dec-22-2010, 12:21:55 AM   #2
Maester
Maester's Avatar
Reputation: 0 Maester is on a distinguished road
Default Re: Rattly bad-idler-pulley sound coming from tranny area?
If it's a manual, I would suspect a bad throwout bearing... Sounds like mine did before I swapped mine...
< Bmer day of fun - Me and Raiku898
- 2001 M3 Convertible "Bellatrix" or "Bella" for short- Imola Red on Black - Full Ground Control coil over kit - Turner anti says & adjustable end links, Quad TFX, Dynavin - 123,000 Miles and counting
- 1970 MGB GT - Grampian Grey - Autumn Leaf Interior
Jump to top Maester is offline   Reply With Quote
Old Wed, Dec-22-2010, 04:23:31 AM   #3
s65e90
Reputation: 0 s65e90 is on a distinguished road
def sounds like a bad throw out bearing. Does the noise go away with the clutch in? is it all the time?
<<Sold
Hartge // elf // AFE
Jump to top s65e90 is offline   Reply With Quote
Old Thu, Dec-23-2010, 05:25:36 PM   #4
jcreme
jcreme's Avatar
Thanks guys. That def sounds like what it is.
Maybe a new clutch and flywheel while I'm at it? Santa?
Old Tue, Dec-28-2010, 05:27:27 PM   #5
M302_IMOLA
"Just Six"
M302_IMOLA's Avatar
Reputation: 0 M302_IMOLA is on a distinguished road
Is it a rattle or whistle/shrilling noise? I was getting a whistle/shrilling noise upon cold startup that went away when the car warmed up and it turned out being my idler pulley. The bearings in the pulley eventually seized up and shredded my drive belt. Hope this helps.
02' IR/IR
Current Mods: Painted front reflectors, matte black fender gills, carbon fiber roundels, Depo smoked corners, 19" Ruff Racing wheels wrapped in Hankook Ventus V12's (245/35F & 275/30R), Status Gruppe coilovers (7K/8K), RE RSM's, Powerflex RTAB's & FCAB's, DICE, CSL Rep Diffuser, CF Hamann Rep Lip, Magnaflow exhaust, Ebay headers, Streamline filter, Afe elbow, RPI scoops, ZHP knob, and EE LED tails.
WTB: OEM Front strut bar, Evolve stage II tune, 4.10's, and CF CSL rep Bootlid
Jump to top M302_IMOLA is offline   Reply With Quote
Old Tue, Dec-28-2010, 08:39:41 PM   #6
Foo2rama
2004 E46 M3
Foo2rama's Avatar
Reputation: 0 Foo2rama is on a distinguished road
If it is an smg, the smg pump hose leaking can cause this.
2004 Mystic Blau Imola Rot ///M3 Coupe Manual converted from SMG in Dec 2017
Jump to top Foo2rama is offline   Reply With Quote
Old Tue, Dec-28-2010, 09:23:59 PM   #7
jcreme
jcreme's Avatar
Thanks guys. Idler pulley were the first thing I checked. All ok.
It's a 6MT. Throw out bearing is a good call.
Old Wed, Dec-29-2010, 01:30:12 PM   #8
M302_IMOLA
"Just Six"
M302_IMOLA's Avatar
How did you check this pulley? I tried spinning mine and all seemed well, but it was indeed a faulty pulley. This pulley spins at such high rates of speed when the car is running you can't reproduce this by hand. I think the pulley only cost me around $30 so this is a cheap replacement part.
02' IR/IR
area, badidlerpulley, coming, rattly, sound, tranny
Discussing Rattly bad-idler-pulley sound coming from tranny area? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
