Old Tue, Feb-28-2012, 02:01:54 AM   #11
white-hot
is lurking around the corner
white-hot's Avatar
Default Re: Recommended differential Fluid
Originally Posted by das borgen View Post
what the fcuk is Mobile 1?
Mobile Alabama is number 1?
Old Tue, Feb-28-2012, 02:35:35 AM   #12
das borgen
Off-Topic King
das borgen's Avatar
Reputation: 0 das borgen is on a distinguished road
I mean......they do have leprechauns and bed intruders
Jump to top das borgen is offline   Reply With Quote
Old Tue, Feb-28-2012, 02:43:19 AM   #13
what the duck is Mobile 1?
Old Tue, Feb-28-2012, 02:48:56 AM   #14
das borgen
Off-Topic King
das borgen's Avatar
for the sake of your soul, I pray that you never go youtube or google "Dolan Duck"
no typo there
Old Tue, Feb-28-2012, 04:00:01 AM   #15
jwdunn
jwdunn
Reputation: 0 jwdunn is on a distinguished road
Smile Re: Recommended differential Fluid
Thanks for the Help guys, and the feedback on my spelling. i'll look into getting some MOBIL1
thanks
Jared
Jump to top jwdunn is offline   Reply With Quote
Old Tue, Feb-28-2012, 04:27:14 AM   #16
KBuva06
Reputation: 0 KBuva06 is on a distinguished road
how often is the diff fluid to be changed
Jump to top KBuva06 is offline   Reply With Quote
Old Tue, Feb-28-2012, 11:12:40 AM   #17
Richardsperry
95 SC M3
Richardsperry's Avatar
Every inspection 2, or about every 30K miles. Just like the transmission fluid. (old school maintenance schedule)
Old Tue, Feb-28-2012, 08:14:38 PM   #18
KBuva06
thanks.
I'm getting an oil change tomorrow to get ready for upcoming season and figured I'd have diff oil done as well. how extensive of a job is this as i'm not familiar with it? is it as simple as putting it up on a lift, draining it, then refilling it or does it involve more?
same question for tranmission fluid. aka, what would the labor be for these two extra maintenance items.
Old Tue, Feb-28-2012, 08:20:16 PM   #19
salty
salty's Avatar
Reputation: 0 salty is on a distinguished road
It is easy enough. get new crush washers, remove the fill plug before you remove the drain. You will need a short 14mm allen key. Often a box end wrench turning it works best as there is not room for a ratchet handle if you have a 14 mm allen socket.
Filling can be tricky. Make sure the car is level. Fill till lube comes out the fill plug. I use a funnel with a long vinyl hose attached and mount it near the back of the trunk with clamp. A fluid pump will work. I wish someone would make a diff lube bottle with built in pump.
Bob S
EX 98 M3/4/5 Cosmos owner, 2007 Subaru Forester XT daily, 2003 325 IT, 1999 10AE Miata, 1971, 2800 CS (In the Garage getting refreshed) 1966 Corvair 500/140, 1972 BMW 2002 Malaga.
Jump to top salty is offline   Reply With Quote
Old Wed, Feb-29-2012, 11:14:17 AM   #20
Richardsperry
95 SC M3
I don't know what the book time is, but I would guess it's about a 1/2 hour each.
You need 2 qts each of ATF for the tranny and 75-90, 75-140 (either is fine) gear oil for the diff.
differential, fluid, friction, redline, royal purple
Discussing Recommended differential Fluid in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
