Old Sun, May-15-2011, 08:42:16 AM   #41
ImolarotII
Red on Red
ImolarotII's Avatar
Reputation: 0 ImolarotII is on a distinguished road
Default Re: Differential Seal Leak (with pictures)
Originally Posted by Dan Rodriguez View Post
It looks like a bad driver's side diff output seal.
This is the part you need: http://www.pelicanparts.com/cgi-bin/...5%29%2C%20Each
These are the two DIYs that I bookmarked for later use: http://m3forum.net/m3forum/showthread.php?t=218070
http://m3forum.net/m3forum/showthread.php?t=230322
I have the same leak, although not as bad as yours. I have the parts waiting to install. It just hasn't been a priority yet.
Thank you for info! When do I know if I my diff needs a rebuild? Not saying that someone inspected it and I was recommended to do it but, what are the signs of a bad diff?
I know the M3 has a slight clunk once in awhile. But is there any other test I can do?
Honestly, driving the car is fine, I never knew the leak until I had an oil change today, lifted the car up and saw that.
Thank you!
Jump to top ImolarotII is offline   Reply With Quote
Old Sun, May-15-2011, 03:14:11 PM   #42
Dan Rodriguez
Dan Rodriguez's Avatar
Reputation: 0 Dan Rodriguez is on a distinguished road
I'm sure your diff is fine. This seems to be a very common leak. Most of the diff problems I have read about are simple groaning and grinding. And most of those problems are solved by draining the fluid and filling it with OEM diff fluid. I would just fix the leak if it bothers you (that's what I plan on doing). If it doesn't bother you much, I would just keep an eye on the diff fluid level and continue to drive it. There are plenty of people driving around with diffs like yours and mine. I'd bet that most of them do not even know it.
Jump to top Dan Rodriguez is offline   Reply With Quote
Old Sun, May-15-2011, 07:27:46 PM   #43
ImolarotII
Red on Red
ImolarotII's Avatar
Got it!
This sounds stupid but, how do you check your diff fluid level? I'm going to assume you need to drain it?
Old Sun, May-15-2011, 08:25:30 PM   #44
I M Legend
From the picture it looks like that's the passenger side. I'm not an expert but I can't really tell where it's leaking from that particular picture. But if it is, I would say it's the passenger side since we can't even see the driver's side in that picture.
Jump to top I M Legend is online now   Reply With Quote
Old Sun, May-15-2011, 08:28:14 PM   #45
I M Legend
Originally Posted by ImolarotII View Post
Got it!
With the car level, you unscrew the top filler screw and stick your finger in, if you touch fluid then you're full. If not then fill until the fluid overflows out. There are two hex screws in your picture...it's the one on top.
Old Mon, May-16-2011, 03:39:24 AM   #46
Dan Rodriguez
You're right. It's on the passenger's side. Which is a good thing as that is the easier seal to change.
Old Tue, May-17-2011, 07:58:24 AM   #47
ImolarotII
Red on Red
ImolarotII's Avatar
Not sure if this is a good picture, but this is the passenger side.
Driver side
Old Thu, Sep-29-2011, 06:19:06 PM   #48
love67
Reputation: 0 love67 is on a distinguished road
hello,
sorry for bring the post up again
I have a bad leak as well on the drive side.
I have the BMW motorsport 4.1 diff, does it use the same seal as the OEM seal? if so, i just need to get the seal that you guys mentioned before???
please help
thanks
Nick
Jump to top love67 is offline   Reply With Quote
Old Thu, Sep-29-2011, 09:27:54 PM   #49
Mr. Wolfe
Anti-Bling
Mr. Wolfe's Avatar
Originally Posted by love67 View Post
hello,
please help
thanks
Nick
Yes Nick, OEM seal. Make sure you do not tap it in too far. If you do, it will leak again. Good luck. I have had zero leakage since changing mine.
Mr. Wolfe
Old Fri, Sep-30-2011, 02:28:52 AM   #50
love67
thank you very much Mr. Wolfe
this is the only part that i need right?
thanks again
differential, leak, pictures, seal
Discussing Differential Seal Leak (with pictures) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
