Old Sun, Oct-17-2010, 02:48:50 PM   #21
enigmaticdream
Reputation: 0 enigmaticdream is on a distinguished road
Unless I'm interpretting the incorrect seal, you should be using RTV sealant and not the gasket.
http://www.turnermotorsport.com/html...ID=33121214719
I was just so happenning to be on turner's site yesterday looking at diffs and read the info on the link above.
I hope that helps!
1987 325is Delphin/Schwartz
1988 M3 Zinno/Natur
2007 335i Silver/Silver
Jump to top enigmaticdream is offline   Reply With Quote
Old Sun, Oct-17-2010, 04:04:59 PM   #22
Mr. Wolfe
Anti-Bling
Mr. Wolfe's Avatar
I think I am looking at replacing #11 in the following picture. The diff itself isn't leaking, but where the axle bolts into the diff.
http://realoem.com/bmw/showparts.do?...65&hg=33&fg=05
Mr. Wolfe
Old Sun, Oct-17-2010, 04:33:43 PM   #23
Fuerza
strength
Reputation: 0 Fuerza is on a distinguished road
How are your mounting bolts? I was reading on the fanatics that the mounting bolts could potentially back out causing some serious damage. I know you swapped diffs with someone that had 4.10's, did you use anything on the mounting bolts to prevent them from backing out?
Jump to top Fuerza is offline   Reply With Quote
Old Sun, Oct-17-2010, 06:32:30 PM   #24
tjpatte
Reputation: 0 tjpatte is a jewel in the rough
Originally Posted by MY02M3DINAN View Post
The rear diff cover correct?
Yep, towards the top.
Tom
2004 Mystic Blue M3
Jump to top tjpatte is offline   Reply With Quote
Old Sun, Oct-17-2010, 08:01:47 PM   #25
00 XE7EN
00 XE7EN's Avatar
Reputation: 0 00 XE7EN is on a distinguished road
Bangladesh
i have the same slow leak issue already mentioned. didnt catch it until recently. who knows how long it's been like that, but no problems so far.
2002 E46 M3
BMW Individual: SterlingGrau Met./Black
6 speed
AA Gen IV exhaust/SS unresonated section 2/CPI Section I/AP V2 headers/Evolve Tune/UUC SSK/JIC Cross Coilovers/
Jump to top 00 XE7EN is offline   Reply With Quote
Old Mon, Oct-18-2010, 12:03:22 AM   #26
MY02M3DINAN
MY02M3DINAN's Avatar
Reputation: 0 MY02M3DINAN is on a distinguished road
Mr. Wolfe
I'm talking about replacing #7.
The #11 seals are a piece of cake to replace.... about 20 minutes each.
Seepage is normal for these, dripping is not.
2002 TiAg M3 Cabriolet
Dinan S-M3 Kit
{Throttle Bodies/CAI/MAF/Stage 4 software}
Dinan Strut tower brace & Front sway bar
Auto Solutions SSK
UUC Motorwerks "Rasp-X" mid-pipe
Urethane RTAB's/FCAB's/RSM's
Hawk HPS Brake Pads
CDV delete
V1 Hardwired
THIS CAR IS NOW FOR SALE!
Jump to top MY02M3DINAN is offline   Reply With Quote
Old Mon, Oct-18-2010, 12:22:40 AM   #27
tjpatte
When I put mine back in I just torqued them to factory specs, 128ft-lb for the front and 48 ft-lb for the rear bolts, and check them again in about 500 miles. If they loosen up then I will look at blue locktite or something.
Tom
2004 Mystic Blue M3
Old Mon, Oct-18-2010, 12:25:43 AM   #28
tjpatte
I think you just pry out the flanges to do #11, but had to unbolt the diff and wiggle it around to get the axles in. Has anyone been able to put the shafts in without moving the diff and just disconnecting the lower control arms?
Thanks.
Tom
2004 Mystic Blue M3
Old Mon, Oct-18-2010, 02:24:43 PM   #29
Mr. Wolfe
Anti-Bling
Mr. Wolfe's Avatar
I have not looked at the car since Friday. I will dig into this sometime this week. I guess I just figured it was the axle being that all of the spray was on one side of the car. I guess the drive shaft spinning in 1 direction could also cause that.
I will keep this post updated.
Mr. Wolfe
Old Tue, Nov-16-2010, 11:28:42 PM   #30
nschmdbrg
Reputation: 0 nschmdbrg is on a distinguished road
Why is seepage "normal"? I just had my seals replaced under cpo (car only has 20,000 miles). Is this another item that needs to be periodically inspected on these cars? The purpose of a seal is to prevent fluid from leaking... are there any after market seals that perform better than OEM?
Jump to top nschmdbrg is offline   Reply With Quote
differential, leak, pictures, seal
Discussing Differential Seal Leak (with pictures) in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
