Old Tue, Mar-09-2010, 09:11:19 PM   #21
dsm918
dsm918's Avatar
Reputation: 0 dsm918 is on a distinguished road
Originally Posted by .333 snubnose View Post
but if I remember correctly (it's been a couple years), you do not have to remove any connections from the starter before removing intake manifold. In your DIY, pictures 11c and 11d show the power lead going to the starter and claims that you must blindly remove the connection before manifold will come free. I do not remember doing this step, and correct me if I am wrong, but you only need to unhook the harness from the rear of manifold as shown in picture 9.
05/18/2010: You are correct. I have updated the DIY above.
Originally Posted by deilenberger View Post
This is a WONDERFUL DIY.. it's going up as a sticky, and I will be thinking about moving it to the DIY forum (where things like the valve-adjustment DIY live.)
Thanks MUCH for the effort and time to document this. I particularly like the linked photos showing what connects to what.. I've never seen that done before and it's a great idea!
Thanks. I am glad that photo helped cuz I was concerned it might confuse some people more than it would help. Reason I even decided to do that was beacuse I totally missed the drain connection when I yanked the intake out. Luckily for me, it just unplugged instead of breaking
16 F80 AW/SO M3
09 E90 SG/Black M3
03.5 CB/Black M3
00 GSXR 600 (Track Star)
90 Nissan 300ZXTT
92 Eclipse GSX - 11.841 @ 117.11
Jump to top dsm918 is offline   Reply With Quote
Old Fri, Mar-12-2010, 07:42:47 PM   #22
erc430
erc430's Avatar
Reputation: 0 erc430 is on a distinguished road
Thanks for this diy. I am getting ready to tackle this job this weekend.
Jump to top erc430 is offline   Reply With Quote
Old Fri, Mar-12-2010, 08:31:09 PM   #23
Highpower11
Highpower11's Avatar
Reputation: 0 Highpower11 is on a distinguished road
Superb DIY! I always wondered how the intake/trumpet clamps were removed.
___________________
06 /// M3 ZCP, 6MT, Interlagos Blau Metallic \ M-Alcantara\ Volk RE30\ VMR 701 (winter)\ CDV delete\ ESS ECU Tune\ RPI Scoops\ BMC Filter\ Turner aluminum Race Pedals\ Rogue FR 10mm spacers\ Rogue RSM\ Vogtland Springs\
\ V1 Hardwire\ DICE/iPhone\ Smoked corners\ painted reflectors\ ZHP illuminated Alcantara shift knob\ HID fog's\ LightWerkz TFX\ Nav, Power seats & Sunroof delete\ Coming Soon: Euro Headers & Cats
Jump to top Highpower11 is offline   Reply With Quote
Old Sat, Mar-13-2010, 08:27:17 PM   #24
fiveride
Reputation: 0 fiveride is on a distinguished road
thank you so much for this! unfortunately i think i need to do this when the rain stops. hopefully monday or tuesday.
very generous of you, thanks again!
Jump to top fiveride is offline   Reply With Quote
Old Sat, Mar-13-2010, 10:06:17 PM   #25
yaja23
M Addict
yaja23's Avatar
Great job on the diy.
Old Sun, Mar-14-2010, 05:19:58 AM   #26
M3PowerPlay
PowerPlay
M3PowerPlay's Avatar
Reputation: 0 M3PowerPlay is on a distinguished road
Default Bravo
Excellent thread! In preparing to install my supercharger,this will certainly come in handy. Thanks!!
Bilstein PSS9's - BBS LM-R's - Toyo Proxes T1R's - Powerflex Rear Trailing Arm Bushings - Smoked Corners & Markers - Black Gills & Kidney Grills - Evosport Headers - Custom Performance Innovations CRT - VF-Engineering Street Sport Kit - 50% Tint - DICE - Vorsteiner CSL Trunk Lid[B]
Jump to top M3PowerPlay is offline   Reply With Quote
Old Sun, Mar-14-2010, 04:05:26 PM   #27
erc430
erc430's Avatar
Thanks again for the diy!!! I just got done replacing my starter using this diy.
To remove the starter bolts from the top of the engine bay I used a ratcheting E12 torx wrench and really had to muscle it to break them loose.
http://www.amazon.com/Gear-Wrench-92.../dp/B000HBF5LQ
or
http://cgi.ebay.com/BLACKHAWK-PROTO-...item2ea8075883
Old Mon, Mar-15-2010, 01:45:06 PM   #28
dsm918
dsm918's Avatar
or
Thanks for posting that It'll come in handy if I have to do my starter. The wrench you posted is flat. I was under the impression it would need to be angled. How hard was it to get the bolts out? How hard was it to get the thread for the starter bolts started when you were installing the new starter? Looked like there might be a space constraint!
Please comment.
16 F80 AW/SO M3
09 E90 SG/Black M3
03.5 CB/Black M3
90 Nissan 300ZXTT
Old Mon, Mar-15-2010, 03:23:59 PM   #29
erc430
erc430's Avatar
The hardest part was breaking the torx bolts loose with the wrench since I did not get much leverage from a short wrench and there was no room for a cheater bar.. Once the bolts are about half way out you can separate the starter from the bell housing with a small pry bar and it will pull the bolts against the bell housing again to give you room to finish loosening them.. The space is tight, but it can be done with a flat ratcheting torx wrench.. At first I tried to get a torx socket back there, but there was not enough room behind the bolts for that... Once I put the new starter in starting the bolts by hand was no problem. I used a e12 torx wrench from a set of blackhawk torx wrenches found on ebay.
Old Mon, Mar-15-2010, 03:36:51 PM   #30
asianscion
Screen name not related to the car
Reputation: 0 asianscion is on a distinguished road
This is great! Some of the pictures may help in getting other jobs done as well, so I may be referencing this often.
GSXR///SMG///AMG
Jump to top asianscion is offline   Reply With Quote
car, cleaning, cleaning>>>, diy, diystarter, intake, intermittent, issue, issuecomplete, removal, replacement, starter, starting, terminal
Discussing Intermittent Starting Issue-Complete DIY-Starter Replacement (Intake Removal) in the Faults, Fixes and DIY Forum - Please share your experience and knowledge with other members by contributing your own DIY, or by helping another member find the elusive fix! at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
