Old Wed, Dec-30-2009, 12:37:04 PM   #1
Ctm306
Ctm306's Avatar
Reputation: 0 Ctm306 is on a distinguished road
Default Side marker and hood vent removal
I know I saw a thread on this but it does not come up in the search.
Anybody remember this how-to ?
Having clear bra installed next week and would like to get these pieces out
2009 Alpine White/Carbon Roof/Black/Carbon Black Trim/DCT/Tech/Prem/Cold weather/19"/V1/Blinder/Cheetah/VentureShield
2006 M3 SOLD
but not forgotten
Jump to top Ctm306 is offline   Reply With Quote
Old Wed, Dec-30-2009, 01:56:18 PM   #2
MoPower
Reputation: 0 MoPower is on a distinguished road
Typically clear bras only cover the front portion of the hood and fenders. It shouldn't require you to remove those vents unless you specifically ask them to cover the entire hood and fenders.
'09 Porsche Cayenne- wife
'06 M3 Coupe 6MT
'06 S2000- sold
Jump to top MoPower is offline   Reply With Quote
Old Wed, Dec-30-2009, 10:43:06 PM   #3
Ctm306
Ctm306's Avatar
Yes this is true, and in my case the whole hood and fenders are being covered!
2006 M3 SOLD
but not forgotten
Old Thu, Dec-31-2009, 12:31:18 PM   #4
Ctm306
Ctm306's Avatar
Anybody?
2006 M3 SOLD
but not forgotten
Old Thu, Dec-31-2009, 12:37:56 PM   #5
Ctm306
Ctm306's Avatar
OK, I found the side marker removal on youtube. Here is the link for anybody else who might need it. http://www.youtube.com/watch?v=jHMtTQ50B5g
Still need help on the hood vents.
2006 M3 SOLD
but not forgotten
Old Thu, Dec-31-2009, 11:39:57 PM   #6
Ctm306
Ctm306's Avatar
Default Hood vent removal
I can see that the top ring somehow snaps out of the hood but I don't want force it 'till I know how it works. Still hoping someone has done this and can help.
2006 M3 SOLD
but not forgotten
Old Fri, Jan-01-2010, 01:01:09 AM   #7
Ctm306
Ctm306's Avatar
Ok, I found this over at M3Post Quote:
"nkweisberg
Figured out how to do it. Pull off rubber grommet from inside of hood. Take plastic wedge and going from the inside of the hood press up on the tabs holding the painted hood vent ring in place. Work your way around releasing all of the tabs. Then remove the hood vent from the outside but lifting up. Take out the black mesh inner piece and put this in the new vent surround. Then press it down into the hole in the hood until all of the tabs lock in place. Reinstall the grommet and repeat on the other side.
Just be careful releasing the tab so you dont snap any off. "
2006 M3 SOLD
but not forgotten
Old Fri, Jan-01-2010, 02:55:06 AM   #8
Jeff M3
Super User
Jeff M3's Avatar
Reputation: 0 Jeff M3 is on a distinguished road
"you just have to out enough pressure on here and enough cushioning on this spot so you dont f*ck it up"
for some reason I got a nice lol out of that
MODS: Some csl stuff, some stoptech stuff, and an intake plus a loud exhaust, oh also a cracked up chassis! YAY THANKS BMW! Repaired with Redish Plates and CMP reinforcement kit (Plates aren't enough people, get a Vince bar or CMP kit ASAP! Video series on the repair coming soon! www.youtube.com/jeffe46m)
Jump to top Jeff M3 is offline   Reply With Quote
Old Sat, Feb-05-2011, 12:44:33 AM   #9
adambullet
Reputation: 0 adambullet is on a distinguished road
Default Re: Side marker and hood vent removal
hi. can i please get some help from anyone in here? i need some stuff online for my truck. my friend recommended vents from 3D Carbon.. you think i should go for it?
_________________________________
1999 jeep grand Cherokee Limited
Eclipse CD7000
1995 Mazda Protege
Eclipse CD7100
Jump to top adambullet is offline   Reply With Quote
Old Sun, Feb-20-2011, 04:39:05 AM   #10
Snow M3
Reputation: 0 Snow M3 is on a distinguished road
I just replaced mine with CF hood vents and I also looked around for instructions. There are several videos out there but the one that worked the best was from .
I saw one where the approach was from below the hood and I don't think that's necessary at all and it just adds work. I was able to pop it off from the top only, working my way around the front end (thin rim) part. I will warn that the hood vent is latched on the back end side (the wider rim end) so trying to pry it up from the back end side could easily break the tab. I cracked mine on the first side and quickly learned to change the approach. I wish this was a warning on some of those threads. No big deal and I was able to superglue it. It would work just fine if I decided to switch them back.
The picture shows those tabs on the rear end side of the vent and you can see the small vertical crack through both holes.
My CF vents are from AutoTecknic and the fit is only OK. The front end part doesn't seem to be perfectly flush. Has this been a problem with anyone? I will try to re-install it and see if they fit better.
SNOW M3
A Simple Man with Simple Needs
2011 M3 Coupe ZCT MW Bamboo / Mods: CF rear spoiler, CF mirror caps, CF hood vents, CF reflectors, CF Front Lip Spoiler
Jump to top Snow M3 is offline   Reply With Quote
hood, marker, removal, side, vent
Discussing Side marker and hood vent removal in the E90 M3 (Sedan) | E92 M3 (Coupe) | E93 M3 (Convertible) (2008-2013) Forum - {Engine: S65 - Max Hp: 414 hp (420 hp Euro) at 8,300 rpm / 295 lb/ft at 3,900 rpm} at BMW M3 Forum.com (E30 M3 | E36 M3 | E46 M3 | E92 M3 | F80/X)
