Old Mon, Apr-29-2013, 10:57:05 PM   #21
egebhardt
egebhardt's Avatar
Default Re: Center Driveshaft Bearing Removal
I've revisited this problem a few times since.
If you look at the CSB, you can see where a snap-ring will come off and a shield will slide away.
Then you find a rubber seal on the bearing itself. Pick that seal out carefully.
Look inside and you'll probably find nice clean dry bearings. Keep in mind, my cars are all dry California cars.
I packed in more grease and put it back together.
If it's dirty and rusty in there, you probably need a new one.
This "Re-Pack" alternative does not require separating the driveshaft.
I'm sure I'll get flamed for this procedure, but when you have high-quality bearings that are clean, adding grease seems very reasonable. If it is rusted and pitted, well......., replace the CSB. I used common sense and saved time and a little money. I haven't had driveline noises or wobbles yet.
97 Byzanz on Magma 4dr - Sold 7.7.17 Jerad in CO
Old Tue, Apr-30-2013, 12:54:17 AM   #22
Jrrrrrrr
Unregistered User
Jrrrrrrr's Avatar
I don't see any reason this is a hackish method. If the rubber surround is good, and if the ball bearings and races inside are good, and because you're already in there, repacking the CSB with grease is fine.
Marring the drive shaft or any other sort of abuse that throws off the driveshaft's balancing is a different thing, obviously.
Old Tue, Apr-30-2013, 01:16:07 AM   #23
OahuMPower
:FACEPALM:
OahuMPower's Avatar
"usually" the bearing isnt the problem, it's the shitty rubber surround.
If I'm going to be in there opening that shiet up.. it's getting replaced
bearing, center, driveshaft, removal
Anyone replace their driveshaft center support and bearing? KNanthrup E46 M3 (2001-2006) 8 Sun, Aug-23-2009 06:58:42 PM
Brand new guibo and center support bearing M3_Dust E36 / E30 - Parts for Sale/Wanted 4 Mon, Aug-04-2008 07:43:02 PM
Center Support with Bearing Assembly for Driveshaft, degoballer E36 M3 (1992-1999) 7 Thu, May-31-2007 01:42:21 PM
Driveshaft Center Bearing Zummie E36 M3 (1992-1999) 2 Sun, Nov-20-2005 06:26:07 PM
Center Bearing Assembly - replace after x miles? bigneil E36 M3 (1992-1999) 1 Thu, Aug-25-2005 11:19:30 PM
Discussing Center Driveshaft Bearing Removal in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
