Old Thu, Mar-05-2009, 09:45:04 PM   #1
syazoo
syazoo's Avatar
Reputation: 0 syazoo is on a distinguished road
Default Reinforcement plate removal
I searched and did not find a clear answer.
Is it fine to:
A: Have the car on ramps with weight on the front wheels and remove the reinforcement plate.
b: Have only the front end of the car on jacks and remove the reinforcement plate.
..... with the idea in mind of not screwing up the alignment.
Thanks boys.
Jump to top syazoo is offline   Reply With Quote
Old Thu, Mar-05-2009, 10:06:50 PM   #2
JeST
Old Skool
JeST's Avatar
Reputation: 0 JeST will become famous soon enough
China
A. Yes, it's fine
B. Yes, it's fine.
The reinforcement plate is just a reinforcement plate it has nothing to do with your alignment.
1988 M3 - Henna/black on black alcantara
2012 Ducati 848 Evo Corse
2011 X5M
Jump to top JeST is offline   Reply With Quote
Old Thu, Mar-05-2009, 10:34:58 PM   #3
Uber-Dinan s2
Uber-Dinan s2's Avatar
Reputation: 0 Uber-Dinan s2 is on a distinguished road
Done both ways with no problems!
Jump to top Uber-Dinan s2 is offline   Reply With Quote
Old Thu, Mar-05-2009, 10:40:49 PM   #4
syazoo
syazoo's Avatar
Thanks guys.
Old Sun, Nov-07-2010, 01:11:47 AM   #5
mpower22
CPV O-Ring Guy
mpower22's Avatar
Thanks, just the answer I was looking for. I plan on using ramps when removing this.
///M3 - Dream Car: Acquired
15-Year Member
2003 M3Laguna Seca Blue/6MT/Black Leather Cloth Interior/Full [CSL] Exhaust/evolve-R
Old Sun, Nov-07-2010, 01:34:13 AM   #6
Serious
Now Rated PG-13
Serious's Avatar
Reputation: 0 Serious has a spectacular aura about
Originally Posted by JeST View Post
A. Yes, it's fine
B. Yes, it's fine.
Actually it does, it's considered a structural component of the suspension which is why bmw recommends an alignment anytime it's removed.
Now to be realistic this isn't necessary at all, I've taken that plate off 20x and never had a problem. The only time might actually have a problem is if you somehow removed it with the chassis loaded (ie only jacked up drivers side) but to be honest I doubt the bolt holes would even line up if you actually managed to get the plate off with the car up like that.
You're fine with either way you have planned.
BTW BMW also recommends the bolts are replaced each time it's removed but that's really not necessary either.
Jump to top Serious is offline   Reply With Quote
Old Mon, Nov-08-2010, 02:26:19 AM   #7
mpower22
CPV O-Ring Guy
mpower22's Avatar
Thanks alot for chiming in on this one. Appreciate the input from experience. And yes, I did purchase new bolts for this.
15-Year Member
Old Mon, Nov-08-2010, 12:17:05 PM   #8
mugenh22a4
เป็นคนจีน
mugenh22a4's Avatar
Reputation: 0 mugenh22a4 is on a distinguished road
Hong Kong
Pardon my ignorance. What's the reinforcement plate?
2008 ISF, Smokey Granite Mica on Black
[IMG]http://img25.imageshack.us/img25/780/dsc3038mod.jpg[/IMG ][IMG]http://img641.imageshack.us/img641/6913/dsc2821edited.jpg[/IMG ]
Jump to top mugenh22a4 is offline   Reply With Quote
Old Mon, Nov-08-2010, 01:14:22 PM   #9
mpower22
CPV O-Ring Guy
mpower22's Avatar
Not at all, its not a piece typically removed. It is the silver aluminum plate on the bottom of the car that runs under the engine connecting the suspension. It's right behind the engine splash shield.
15-Year Member
Old Mon, Nov-08-2010, 01:49:48 PM   #10
mredwin25
mredwin25's Avatar
Reputation: 0 mredwin25 is on a distinguished road
I've taken it off a million times in many different ways and bolts always line up perfect.
E90 Jerez M3
335i Vert
Jump to top mredwin25 is offline   Reply With Quote
plate, reinforcement, removal
Front reinforcement aluminum plate Reinstall (Torque Protractor) M3Seeto E46 M3 (2001-2006) 3 Sat, Jan-17-2009 05:14:29 AM
WTB:front axle support reinforcement plate dt789 Parts for Sale/Wanted 6 Sun, Aug-03-2008 09:49:49 PM
Anyone done Turner's E46 Front Subframe Reinforcement Kit? Requires engine removal? gixxer E46 M3 (2001-2006) 0 Tue, Oct-23-2007 06:08:37 PM
Z3 Reinforcement Plate Techno ///M3 E36 M3 (1992-1999) 1 Mon, May-07-2007 08:44:31 AM
front plate removal DIRep972 E36 M3 (1992-1999) 6 Sat, Mar-11-2006 01:42:52 AM
Discussing Reinforcement plate removal in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
