Old Mon, Mar-02-2009, 09:45:33 PM   #1
OptionLessM
Reputation: 0 OptionLessM is on a distinguished road
Default Shift Knob Removal
I am utterly astounded at this freaking thing! I have had at least four people nearly explode a hernia trying to remove the knob. two of which are college athletes who can produce more than enough strength with their arms. I am about to get a buzz saw and just screw selling the knob. I understand that its supposed to take a solid pull, but I think mine might be an exception.
Can anyone think of any tricks/secrets to making this easier? I have tried prying it with a hammer, wedging a screwdriver under it, hammering the sides of it. It will not come loose. I did all of that while having someone pull as hard as possible straight up.
Jump to top OptionLessM is offline   Reply With Quote
Old Mon, Mar-02-2009, 09:48:26 PM   #2
deadlysyns
deadlysyns's Avatar
Reputation: 0 deadlysyns is on a distinguished road
Pull harder.
Jump to top deadlysyns is offline   Reply With Quote
Old Mon, Mar-02-2009, 09:48:34 PM   #3
The Dough
The Dough's Avatar
Reputation: 0 The Dough is on a distinguished road
United Nations
put it in 2nd gear and just pull backwards on it. you can do it. may the schwartz be with you.
SOH
Jump to top The Dough is offline   Reply With Quote
Old Mon, Mar-02-2009, 09:48:39 PM   #4
BMERDOC
Reputation: 0 BMERDOC is a glorious beacon of lightBMERDOC is a glorious beacon of light
I don't even weigh a buck 60 and I can get them all off. I'd bet a 20 someone glued or epoxied it because it was loose.
Jump to top BMERDOC is offline   Reply With Quote
Old Mon, Mar-02-2009, 09:51:49 PM   #5
OptionLessM
Thats not a bad thought, Im going to go get the hair dryer and heat it up a bit.
and thanks to the guy who said pull harder
Old Mon, Mar-02-2009, 09:53:22 PM   #6
JeST
Old Skool
JeST's Avatar
Reputation: 0 JeST will become famous soon enough
China
Right foot in passenger side footwell, left foot in the driver side. Pull up.
1994 Toyota Supra 6speed Red/Black
Big Single + Meth
Jump to top JeST is offline   Reply With Quote
Old Mon, Mar-02-2009, 09:53:42 PM   #7
Tp///M3
Got ///M?
Tp///M3's Avatar
Reputation: 0 Tp///M3 will become famous soon enough
Laos
Wow, I thought mine was tight but I was to pull it out. What I did was stood on the seats and pulled straight up. Looks like yours didn't want to come. Are you the original owner? I hope they didn't put locktight and glued the knob permanently. Be careful, I heard a lot people got bloody nose trying to remove the knob. GL.
04 CarbonBlack/ImolaRed
Jump to top Tp///M3 is online now   Reply With Quote
Old Mon, Mar-02-2009, 10:01:06 PM   #8
baller1792
baller1792's Avatar
Reputation: 0 baller1792 is on a distinguished road
did u try pulling out the sides first?
Jump to top baller1792 is offline   Reply With Quote
Old Mon, Mar-02-2009, 10:04:27 PM   #9
jon @ eas
jon @ eas's Avatar
Reputation: 0 jon @ eas has disabled reputation
Just keep trying on pulling up hard, maybe open up the sunroof just incase the knob goes flying after you pull it off... Just don't twist left or right, otherwise it'll break the internals. Just keep trying and if it eventually doesn't work then get a new shift knob, and then break of the original one.
Jon M. | european auto source (eas)
email: jon@europeanautosource.com web: www.europeanautosource.com
tel 866.669.0705 | ca: 714.369.8524 x31 | fax: 714.908.1796
Twitter | Flikr | Facebook | YouTube
Jump to top jon @ eas is offline   Reply With Quote
Old Mon, Mar-02-2009, 10:05:29 PM   #10
BMERDOC
I've had to replace windshields, rear view mirrors, dome lights, etc... for pullin' too hard. I can believe bloody noses too! Don't make it more expensive than it could be. Plan on buying a shift lever too. If you are lucky you may just get away with cleaning out the groove if it is glued.
knob, removal, shift
Help..shift knob removal SMG avo8686 E46 M3 (2001-2006) 4 Mon, Nov-20-2006 01:41:57 PM
Shift knob leather removal??? LagunaE46 E46 M3 (2001-2006) 5 Thu, Jun-01-2006 06:10:55 PM
shift knob boot removal ..need DIY LagunaE46 Faults, Fixes and DIY 3 Thu, Jun-01-2006 02:06:17 AM
leatherz shift knob or 330 performance shift knob? MaNaWaR E46 M3 (2001-2006) 1 Sun, Feb-27-2005 08:32:41 PM
Shift knob removal was far easier than advertised. astan100 E36 M3 (1992-1999) 17 Fri, Jul-16-2004 09:18:47 AM
Discussing Shift Knob Removal in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
