Old Thu, Sep-26-2013, 02:29:35 PM   #91
curiouz_g
Reputation: 0 curiouz_g is on a distinguished road
Default Re: Starter motor removal
Originally Posted by NetFixer View Post
If the rear of the bolt is accessible, spray it with some wd40 or PB, then tap it with a punch and hammer. Let it sit. Go to sears and check these out. Looks like they can remove striped bolts. Get one with same size and one smaller. Here's a link for reference.
http://www.sears.com/craftsman-12-pc...1&blockType=G1
If you're doing work under the car, you could jack up the transmission a little and that will give you room to put a vise grip on it and try to get it out that way. But if you jack, you will need to remove cooling fan so it doesn't hit the radiator.
Thanks for the advice. I'll try that as soon as I get home from work today.
Daily grinder: 2008 BMW 335I
All weather warrior: 2011 Acura RDX
Weekend thrasher: 2004 BMW M3 6spd Vortech Supercharged VT550+ (500whp @ 9lbs on ONLY 93 )
Toy: 2008 BMW M3 Sedan 6 speed AA Supercharged
Jump to top curiouz_g is offline   Reply With Quote
Old Fri, Nov-06-2015, 12:44:03 AM   #92
ynot3000
Reputation: 0 ynot3000 is on a distinguished road
sorry bring a old post back from the dead. I'm working on replacing my starter and I got the one bolt out from behind the engine. The other bolt is starting to get stripped. I got the bolt out sockets but haven't used them yet. Dose anyone have any ideas on getting this bolt out?
Jump to top ynot3000 is offline   Reply With Quote
Old Tue, Oct-09-2018, 03:17:12 AM   #93
El Segundo
Reputation: 0 El Segundo is on a distinguished road
Default stupid engineering for sure
I'm embarrassed for BMW engineers. There is no reason for this being engineered this way. To change a starter, you have to disassemble the lower end on the engine, disconnect the transmission remove the exhaust, pull everything out of the the engine bay above the motor, remove intake manifod and even then the ridiculous torq E12 bolt heads will not break lose with a 4 foot schedule 80 1.5 inch outside diameter just bends after flooding the entire area with penetrating oil.
I thought Porsche engineers spent too much time inserting things where they don't belong. BMW engineers have their heads inserted in the same place. This will be my last M3 for sure, there are so many well engineered cars out there it is easy to see why BMW as a company has been lost for so many years with little to no chance of ever being relevant again.
Jump to top El Segundo is offline   Reply With Quote
Old Tue, Oct-09-2018, 03:20:12 AM   #94
icecream
Registered Apples
icecream's Avatar
Default Re: stupid engineering for sure
You have to remove the fuel tank too...and all 5 wheels.
Old Tue, Oct-09-2018, 03:41:23 AM   #95
bimmerfan08
bimmerfan08's Avatar
Is replacing the starter really this involved? Or are people taking unnecessary steps to remove theirs?
Old Tue, Oct-09-2018, 03:53:35 AM   #96
e46Dan
Reputation: 0 e46Dan is on a distinguished road
It's not bad if you have the right tools. I can get it off in less than ten minutes but I don't have the stock house clamps on the manifold. The most difficult part is loosening the bolts holding the starter. Craftsman makes some bendable ratcheting wrenches that make it less painful.
Jump to top e46Dan is offline   Reply With Quote
Old Tue, Oct-09-2018, 03:58:43 AM   #97
Go_diego_go
Go_diego_go's Avatar
Reputation: 0 Go_diego_go has disabled reputation
Here is a solid DIY. I just did this a couple of days ago and the video details every step of doing this above the car. The 2 bolts to get to are a PITA but doable with the right tool.
2006 ///M3 Imola on M-Texture Alcantara -Current Journal
2002 ///M3 Imola on Dove -Sold
1995 ///M3 Alpine White on Dove -Sold
Jump to top Go_diego_go is offline   Reply With Quote
Old Tue, Oct-09-2018, 06:27:25 PM   #98
schoonerm3
Reputation: 0 schoonerm3 is on a distinguished road
Ireland
Its not that hard but if the bolt head strip your in a lot of trouble.
Especially if its the upper of the two.
You dont need to do anything from the underside. Its all done from above.
If you have the correct tools for removing and refitting the intake manifold clamps your going to be alot faster.
There is a little bast1ard of a coolant hose that is very sensitive to being moved and it will leak so i would advise buying a spare 64216902680
I rounded the lower of the two bolts and I had to go in with a little die grinder and small cutting disc and take the head off of it. Ground it flat to the gearbox and then was able to pull it straight out. Took me 4-5 hours
Jump to top schoonerm3 is offline   Reply With Quote
motor, removal, starter
Starter removal/installation DIY tilolite E46 M3 (2001-2006) 12 Wed, Dec-16-2009 07:07:18 PM
starter removal plz help!!! andresvillanu20 E36 M3 (1992-1999) 12 Wed, Sep-03-2008 07:13:25 PM
fs: M3 starter (new, never used) Benihana E36 M3 (1992-1999) 3 Sun, Sep-17-2006 10:33:23 PM
Thread Removal and Notifying The Thread Starter E90_GEN Member Notes and Requests to Admin/Mods 5 Sat, Feb-19-2005 06:19:47 PM
M3 Starter miduso E36 M3 (1992-1999) 6 Wed, Feb-19-2003 07:43:30 PM
Discussing Starter motor removal in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
