Old Fri, Jun-22-2018, 05:33:41 AM   #1
MVAM3
Reputation: 0 MVAM3 is on a distinguished road
Default Battery charge dying with hours
Hi all,
I've been dealing with an interesting problem lately and i'm wondering if anyone more familiar with the electrical systems in our car could help out.
Over the last few weeks I've had intermittent issues starting the car after it sits overnight, it started with the car just struggling to start and progressed so that now if it sits for more than an hour, it just tries to start then the starter just clicks. Obviously this points to 3 more common issues, alternator, battery or parasitic drain.
The alternator is new and produces 14.3V even while underdriven. the battery is about a year old and gives 12.4V immediately after driving, but that voltage drops to about 11.5V within an hour (perhaps the battery can't hold a charge?). Lastly the parasitic draw test shows that the battery draw is about 10Ma while the car is in sleep mode, so i assume there is no significant draw.
To me, everything points towards the battery, which i plan to get load tested ASAP, but if anyone has any other ideas, i'd appreciate any help.
The battery is a red top Optima -35, is there any known issues with these?
Thank you all!
Jump to top MVAM3 is offline   Reply With Quote
Old Fri, Jun-22-2018, 06:52:49 AM   #2
johndoe
S54 Addict!
Reputation: 0 johndoe is on a distinguished road
Namibia
Default Re: Battery charge dying with hours
I'd say replace your battery sir..
Jump to top johndoe is offline   Reply With Quote
Old Fri, Jun-22-2018, 07:20:14 AM   #3
mrgizmo04
mrgizmo04's Avatar
+1
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Fri, Jun-22-2018, 09:01:58 AM   #4
MVAM3
Thanks guys, sounds like that might be the case.
Old Sat, Jun-23-2018, 02:29:29 AM   #5
RedM3/4
You definitely shouldn't see the battery drop under 12v in a day. A week maybe, a day, at 10ma, it's bad.
ADS
Old Thu, Jun-28-2018, 03:42:46 AM   #6
MVAM3
Thanks everyone. Got a new battery and everything seems to be working perfectly.
Discussing Battery charge dying with hours in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
