Old Thu, Jun-21-2018, 05:15:30 AM   #31
TrackRat951
Reputation: 0 TrackRat951 is on a distinguished road
Default Re: Breakthrough discovery about the Spal 30102082 Fan! The Most powerful sealed fan
Originally Posted by Cronenberged View Post
Thanks for reaching out to SPAL. Good stuff!
No problem. I contacted them, when I was considering eliminating my mechanical fan, as I wanted to know if there was a better option, if the 2049 wasn't enough.
So far, I haven't seen my engine coolant outlet temps go much over 200F in stopped traffic. This was with 100F ambient temps, and it was very brief. I would like to update the ECU to have the fan hit 100% duty cycle at slightly lower temps.
Jump to top TrackRat951 is offline   Reply With Quote
Old Thu, Jun-21-2018, 07:15:46 AM   #32
0-60Motorsports
Established 1998....
0-60Motorsports's Avatar
Bahrain
This fan will be good for the extreme heat we face here in the Middle-east. 125f nowadays lol
Old Thu, Jun-21-2018, 09:48:12 AM   #33
daveishi
Reputation: 0 daveishi is on a distinguished road
But will it still fit with, say, a CSF triple pass?
2004 Mystic Blue Metallic/Grey Black 6MT
FS: ESR Forged RF2 18x10 +25 Hyper Black with 265/35-18 RS3http://www.m3forum.net/m3forum/showthread.php?t=597765
Jump to top daveishi is offline   Reply With Quote
Old Thu, Jun-21-2018, 12:16:37 PM   #34
bigjae1976
Iíve got a SPAL fan on my CSF radiator. Not sure if itís the same exact model.
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Thu, Jun-21-2018, 02:14:41 PM   #35
Radekxpl
Radekxpl's Avatar
Reputation: 0 Radekxpl is on a distinguished road
Poland
Originally Posted by TrackRat951 View Post
According to Brent Chuck, Application Engineer at SPAL:
The 2082 is going to be an upgrade over the 2049. The 2082 will begin to outperform the 2049 at any static pressure greater than 0.4InH20, most automotive systems are 0.5 to 1 inH20. So itís safe to say the 2082 will be an upgrade compared to the 2049. It is also worth pointing out the 2082 will draw more current than the 2049. With both of these fans we recommend a 40 amp fuse.
Great info thanks for contacting Spal
0.4inH2o = 10mmH2o
0.5inH2o = 12.5mmH2o
1.0inH2o = 25mmH2o
with this in info;
At 12.5mmH2o
2049 is pushing 1280 cfm
2021 is puching 1280 cfm as well
2082 is pushing 1499 cfm
At 25mmH2o
2049 is pushing 0 cfm
2021 is pushing 378 cfm
2082 is puching 596 cfm
Given this info you can clearly see 2082 blows the other 2 fans out the water
2006 M3 Silver Grey
Mod list: TTFS Custom Tune, Headers Sec 1 AR20, M-Track Mode programmed, IAT relocated, Upadted cam bolts with S62 pressure springs and diaphragm, sub-frame reinforced foam/epoxy Vince bar & plates, 996 Brembo brakes PFC 08 pads, CDV delete, F10 M5 shift knob, CSL diffuser, black chrome grillies, smoked corners tinted windows, asymmetrical mirrors, Hardwired Bell Pro 300, D/A pulleys, AVANT-II, Dinan CAI, SDW RTAB, TCkline 500/600 GC Weight Jacks, GC Street Camber Plates, Beisan Oil Pump Disk, ECS camber arms, N15 SPAL 2082 fan, Micro-blue rod bearings, ZHP .712 Yellow tag rack.
Jump to top Radekxpl is online now   Reply With Quote
Old Thu, Jun-21-2018, 03:38:00 PM   #36
cozmo kraemer
cozmo kraemer's Avatar
Reputation: 0 cozmo kraemer is on a distinguished road
Originally Posted by mrgizmo04 View Post
@nervous24 and @cozmo kraemer, did you remove ac and the condenser and just leave the aux fan in, or is aux fan still on the condenser? Reason I ask is condenser acts as airflow block to the radiator.
Edit - and are you running the car as daily seeing stop and go traffic and sitting idling or mostly moving at the track with plenty of air flow?
AC and condenser are still in the car and functional. I have never had an issue on track either. I had to back off one time at Chuckwalla in 100+ degree ambient temps, but every single e46 had to back off then. I think that is more the limitations of the radiator/oil cooler, than any sort of fan. Removing the AC would help that situation, but this is a street car that gets tracked. Not the opposite.
2004 E46M3 - BBS RGR - RE11, BMW Motorsport 3.91, Eibach Pro Street S Coilovers (500/600), GC plates, SSV1 Headers/CPI slip fit catted/resonated section 1, Karbonious CSL intake, Shrick 280/272 cams, CSL DME Conversion, TTFS tune, OEM CSL front and rear seats
2010 - X5 4.8 Msport - the boring daily driver
My Journal
Previous - '95 M3, '94 FD RX7 (single turbo and LS6 swapped), '98 Integra Type R, '89 325i, '91 318, etc
Jump to top cozmo kraemer is offline   Reply With Quote
Old Thu, Jun-21-2018, 04:58:22 PM   #37
mrgizmo04
mrgizmo04's Avatar
Good to know. Thanks. Mechanical fan delete WITHOUT an electric fan replacement sounds like works even in hot weather for street driven cars, leaving ac condenser/aux fan in place...
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Thu, Jun-21-2018, 05:10:01 PM   #38
nasieg
nasieg's Avatar
Originally Posted by Radekxpl View Post
Itís all about a preference, with N15 Design fan mount it looks real clean like a OEM + look to me, Iím not sure that pictures do justice. But again everyone has different taste.
I know it looks OK either way. What I meant though, is that the shroud should help cooling, because it draws the air more evenly over the radiator.
My Journal
Besian VANOS, Euro Headers & Section1, TTFS tune, TMS under-dive pulleys, TC Kline S/A Coil Overs, Brembo 996 Calipers, ECS 2 Piece Rotors, Rally Road/P0lar Adapters, SS Brake Lines, Motul 600,Hawk HT-10 Pads, Braille Lightweight Battery, Hotchkis Sway Bars, SR2 CF Sunroof Panel,Apex ARC-8 & Sportline CS8's, Recaro Sportser CS Seats,SAP delete,Lightweight Cabin Filter Housing, SG CSL Diffuser, OEM CSL Trunk, Modified Stock Muffler
Jump to top nasieg is online now   Reply With Quote
Old Thu, Jun-21-2018, 05:23:59 PM   #39
daveishi
And if you get it on eBay as OP provided you can now save $15 with coupon PSUPERSUMMER
Old Thu, Jun-21-2018, 05:26:14 PM   #40
Radekxpl
Radekxpl's Avatar
Poland
Good looking out it's always good save money
2006 M3 Silver Grey
Discussing Breakthrough discovery about the Spal 30102082 Fan! The Most powerful sealed fan in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
