Old Tue, Jun-19-2018, 10:04:45 PM   #21
M3_Pilot
Default Re: A good example of why my engine internals have remained stock
I'd definitely agree that it's a case-by-case thing. Some scenarios likely fall down to subcontractors not meeting requirements. It's not uncommon knowledge that a good deal of parts are really the auto manufacturer saying "Hey, ATE, we need a part that does X, Y, and Z for less than $$". If you ask any "prime contractor", their opinion would be that their engineering is perfect - it's just sub-contractors not meeting requirements.
When things normal humans call "failures" after ~100,000 miles happen, I think a good deal of automotive engineers would say that's perfect - the design met requirements, no more, no less.
Specifically in regard to BMW, I think they make a good deal of assumptions on the kind of roads and conditions their product will be used on. For example, rather than saying "man, we didn't design these strut towers properly", BMW says "you're driving on rough roads that aren't what we consider normal... here's a 'rough road package' with plates to keep that from happening on your shitty non-German roads." Ditto with bearings - my understanding was that BMW first blamed owners for not warming up the car properly.
Thatís a great observation. Looking at it from an engineering perspective, itís amazing how advanced most combustion engines have become. And then to demand emissions regulations, more performance, and then longetivity - Iíd say this engine is nothing short of an engineering marvel.
2004 Jet Black/Cinnamon 6MT
@jet.m3
Jump to top M3_Pilot is online now   Reply With Quote
Old Tue, Jun-19-2018, 10:22:17 PM   #22
Drewster
Drewster's Avatar
Especially since the car came out in 2000, meaning the engine was probably engineered ~1998.. when many cars still used distributors.
Originally Posted by oceansize View Post
Thanks for the input as I've been pondering the RACP and bearing situations and how them came to be and these responses spurred new thoughts. I work in software development. Mostly analytics, big data (I've come to hate that term), and stats but do a fair amount of work on what I suppose could be best termed OLTP. In my world the "we didn't anticipate X set of conditions" is unacceptable although it certainly happens to me more often than I care to admit. For some reason I really hadn't considered the auto industry had starting parameters of what constituted an acceptable set of driving conditions or circumstances and anything outside of that was deemed not their responsibility or at least so far outside the norm they couldn't account for it within a reasonable cost. The more I think on it the more I believe that in the world of mass production coupled with this level of engineering it is likely unavoidable to a degree.
I agree it *should* be unacceptable.. and yet, GM's C7 Z06 overheated in the hands of amateurs at standard tracks.... humans be human
Old Tue, Jun-19-2018, 10:29:55 PM   #23
Volke
Reputation: 0 Volke is on a distinguished road
In general for hardware, unless it's aerospace or safety critical, you don't design to or test to worst case conditions. You come up with a composite application profile that represents how your average customer will use your product and design/test to that. Also, the design metrics usually allow for a certain amount of failures before the target life. For example, when building a new engine, BMW may decide they want a B10 life of 100,000 miles and a B50 life of 150,000 miles. This means that they are okay with 10% of the population failing before 100,000 miles and 50% before 150,000 miles.
EDIT: On top of B10 lifes, they may also say they only want a 90% confidence interval when determining how many samples they need to test and for how long to verify that the design meets the requirements.
Peter
Mechanical Engineer
Jump to top Volke is offline   Reply With Quote
Old Tue, Jun-19-2018, 11:18:43 PM   #24
Texaz3
Came out on a 2006 model, so a bit later than 2000. Still.
Old Wed, Jun-20-2018, 01:04:07 AM   #25
mrgizmo04
mrgizmo04's Avatar
You hit the key in your edit...confidence interval. There is an inherent measure built in accepting that some will fail, otherwise like you said, you would have to model and test to worst.
I think finite element has become pretty popular in auto industry in mid 80s, so I'm not sure where the disconnect happened with some failures on these cars, but budgets and timelines always put pressure.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Wed, Jun-20-2018, 02:47:25 PM   #26
Kcalhoun27
Reputation: 0 Kcalhoun27 is on a distinguished road
In aerospace at least, the old saying is that its built to run, not to be fixed. So in a perfect world, the object is just operated. You try to build it with the thought in mind that it will fail and should have some failsafe to that end, but its kind of unreasonable to run a motor for 50000 hours just to see what might happen. Not to say that high hour testing isnt done. Eat a bird on takeoff and all those parameters are out the window, because even though they did BASH testing, you cant do that at every hour mark. And you cant account for secondary issues that arise and cause catastrophic damage.
I think the same could be said for the engines. Driving styles are so varied, drive times are varied. Would a car with almost entirely highway miles at 65mph have the same type of wear as a car that is tracked? Of course not. But what about someone who only does short trips? Or maybe you drive twice a month, but you go romping everytime. The variation is just impossible to account for, so they do their best to simulate failure in many arenas.
Like stated, i think this engine is a marvel, and even with the failures we know about, they did a great job. Likewise, the racp should have been fixed from e36-46, but even if they had reinforced it heavily, the power jump from the s52 to the 54 was enough that it might not have mattered
Just my 0.02
Jump to top Kcalhoun27 is offline   Reply With Quote
Old Wed, Jun-20-2018, 02:51:21 PM   #27
Just my 0.02
They actually did fix the subframe failure between the e36 and e46. On the e36, it's the subframe itself that fails. On the e46, it's the mount points the subframe attaches to that fails.
Totally fixed!
I, too, find the s54 remarkably reliable for what it is and the variety of conditions it's subjected to.
Old Wed, Jun-20-2018, 03:12:58 PM   #28
Drewster
Drewster's Avatar
Remarkably reliable... with a hint of irony. I've actually lost a main coolant hose on track, and the engine didn't start to overheat until I got back to the pits. That was the first time I thought "damn.. what an engine". If she loses one little VANOS tab, though... :
Old Wed, Jun-20-2018, 03:20:06 PM   #29
Kcalhoun27
Totally fixed!
Lol, when youre right, youre right.
Despite their failing to fully fix the issue, im still impressed. I still love the car. Even counting the things they got wrong, they still got so much more right. If rod bearings being routine maintenance is the price for admission, im in.
Everytime i drive this car, my only regret is waiting so damn long to buy one
Old Wed, Jun-20-2018, 07:07:07 PM   #30
nowanker
"He's no wanker!"
I'm sure every manufacturer has a room full of actuarials (right term?) crunching data to determine the most profitable Manufacturing Cost/Warranty Repair Cost ratios.
Marketing probably adds their input on Acceptable Failure Rate/Brand Tarnishment ratio.
That paper (what I could understand of it!) was some impressive engineering, and without a doubt, BMW can make excellent engines. But just because the engineers have done their homework on how to make the best part is no guaranty at all that those parts are going into production.
And unforseen things do happen (M-Clunk? Sudden Exploding S54 Syndrome?), Then I guess corporate decides whether to own up and either make repairs, blame the owner, or just tap-dance around it.
Discussing A good example of why my engine internals have remained stock in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
