Old Thu, Jul-12-2018, 01:41:03 AM   #1
derek2079
derek2079's Avatar
Reputation: 0 derek2079 is on a distinguished road
Default Check control error headlight
Why does my check control say my low beam is out when it’s not?
Factory headlights. Were replaced recently. Both work.
Jump to top derek2079 is offline   Reply With Quote
Old Thu, Jul-12-2018, 04:14:57 AM   #2
Texaz3
Default Re: Check control error headlight
Try disconnecting the bulb and plugging it back in.
Old Thu, Jul-12-2018, 04:15:38 AM   #3
derek2079
derek2079's Avatar
I did that.
Old Thu, Jul-12-2018, 06:06:00 PM   #4
Nate047
Nate047's Avatar
Maybe try pulling out the bulbs and look at the sockets, see if there's any corrosion on there or on the headlight housing. I had an issue like this with one of my taillights. Ended up replacing the actual taillight.
Old Mon, Jul-16-2018, 09:28:39 PM   #5
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Did you have hids installed prior?
Old Mon, Jul-16-2018, 10:11:45 PM   #6
derek2079
derek2079's Avatar
Yes but there are no cancellers connected.
Old Mon, Jul-16-2018, 10:14:00 PM   #7
tofunin
Reputation: 0 tofunin is on a distinguished road
I would just bypass the check control module. There is a DIY over on bimmerforums.
Jump to top tofunin is offline   Reply With Quote
Old Mon, Jul-16-2018, 11:11:11 PM   #8
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Then the shunt on the main beam check circuit is probably broken.
Old Tue, Jul-17-2018, 01:34:51 AM   #9
derek2079
derek2079's Avatar
I tried with no avail.
Old Tue, Jul-17-2018, 07:30:55 AM   #10
tofunin
It shouldn't show low beam failure if the bypass was done correctly.
Discussing Check control error headlight in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
