Old Wed, Jul-11-2018, 02:29:32 AM   #1
walid.m3
walid.m3's Avatar
Reputation: 0 walid.m3 is on a distinguished road
Default Sluggish Performance at low rpm
Hey guys,
I want to ask forums before paying someone $125 to diagnose this issue. First off, I have no CEL. Therefore, I'm kind of clueless on where to start diagnosing on my own.
Anyways, car has a shake at start up idle however it idles at normal rpm. The rpm doesn't have unusually movements, and it stays steady at around 1k during a cold startup. I've noticed the car being more sluggish (low on power) at lower rpm, and then once I pass 3k rpm, I feel most of the power back. This occurs at all times especially at full throttle. MPG is down a lot around 15-16mpg. Car stalls, here and there when coming to a stop. Like it will dip to 500 rpm and sometimes it will bounce back to normal idle or stall.
Let me know your thoughts guys I would greatly appreciate the help.
Jump to top walid.m3 is offline   Reply With Quote
Old Wed, Jul-11-2018, 06:04:28 AM   #2
M3AZ
///M3AZ
M3AZ's Avatar
Reputation: 0 M3AZ is on a distinguished road
Default Re: Sluggish Performance at low rpm
http://www.beisansystems.com/faq.html
██████████████████ 2003 E46 M3
Old Wed, Jul-11-2018, 07:13:52 AM   #3
mrgizmo04
mrgizmo04's Avatar
Originally Posted by walid.m3 View Post
Hey guys,
Try to go to autozone or another place and scan for codes (they do it for free). Even without cel there can be codes.
It could be a myriad of things - going fuel pump, bad maf, vanos, bad o2 sensor, etc.
See what the codes say and that could guide you.
Report back here with results.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Wed, Jul-11-2018, 07:22:36 AM   #4
HassanEido
HassanEido's Avatar
Lebanon
Start with ur maf
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
368.4 whp 289.1 wtq
Old Wed, Jul-11-2018, 01:27:35 PM   #5
Ramp1
Ramp1's Avatar
Reputation: 0 Ramp1 is on a distinguished road
Do you have an aftermarket intake? Sounds like a dirty MAF combined with a missing MAF screen
Jump to top Ramp1 is online now   Reply With Quote
Old Wed, Jul-11-2018, 01:46:10 PM   #6
BTB
BTB's Avatar
Sluggish performance at low rpm - sounds like you've got yourself an M3!
No but what the others said; sounds like it could be VANOS related (whole bunch of sensors that could affect that), or ignition, fueling, airflow reading etc
My Journal
Old Wed, Jul-11-2018, 01:59:53 PM   #7
HassanEido
HassanEido's Avatar
Lebanon
Vanos would throw codes.
Maf can get bad and not throw any. You symptoms are maf related u believe
Mods:
-Custom CF airbox
-Cat Cams 280 272.
-Custom dyno tune
368.4 whp 289.1 wtq
Old Wed, Jul-11-2018, 03:54:32 PM   #8
walid.m3
walid.m3's Avatar
Originally Posted by M3AZ View Post
Thanks for the page. I'm going to start on other things such as MAF Sensors, Ignition Coils, etc before getting into vanos issues.
You may be right cause I have 105k miles.
Old Wed, Jul-11-2018, 04:00:46 PM   #9
walid.m3
walid.m3's Avatar
I do have one, It's a gruppe M intake. I have an extra new MAF sensor on my other e46 m3 at my house, and will swap it. My other m3 was throwing MAF codes, so I added a new one.
Thanks again guys, I will keep you posted on this issue. I will let you know if it may be ignition coils. I'm hoping its something small like that. None of the ignition coils have been replaced, but my spark plugs were replaced at 87k miles.
Old Wed, Jul-11-2018, 04:21:13 PM   #10
ebmw21
Reputation: 0 ebmw21 is on a distinguished road
My Vanos was well overdue for an overhaul (I was down a good amount of power...will have before and after dynos soon.) and NEVER threw a Vanos code.
BBS LM | ST suspention | B-Line Intake | AP V1 | Rouge Sec2 | CPI Rasp Terminator | Headers | CSL SMG Coding |
CSL Bumper | Beisan Vanos Rebuild |
Insta: @Js_imola
Vancouver BC area ECUWORX coding avalable.
Jump to top ebmw21 is offline   Reply With Quote
Discussing Sluggish Performance at low rpm in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
