Old Tue, Jul-10-2018, 11:50:42 PM   #1
Engrmikl
Reputation: 0 Engrmikl is on a distinguished road
Default Luqui Moly engine oil
I am running the Luqui Moly GT1 10w60. I am using a lot of oil and was asked by the engine builder what oil I am running. Any opinions on if this oil is known for burning oil. It doesn't smoke at start up or idle.
Jump to top Engrmikl is offline   Reply With Quote
Old Wed, Jul-11-2018, 12:14:47 AM   #2
mrgizmo04
mrgizmo04's Avatar
Default Re: Luqui Moly engine oil
Not that I know of. I just started using this, have not noticed anything.
You have a fresh engine or an old one that just started going through oil? What is your situation?
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Wed, Jul-11-2018, 12:37:47 AM   #3
foolio
40oz. to Freedom
Reputation: 0 foolio is on a distinguished road
I use it sometimes. Dedicated track car. No burning of the oil.
______________________________________________
1981 BMW 320is - 5MT - Polaris/Black
2001 BMW 325xiT - 5MT - TiAg/Grey Leather - ZPP, ZSP, ZCW, NAV, PDC
2002 BMW M3 - SMG - TiAg/Black Leather - KWV3
2003 BMW M3 - SMG - Laguna Seca Blue - Track car, track stuff
Jump to top foolio is offline   Reply With Quote
Old Wed, Jul-11-2018, 12:41:33 AM   #4
Engrmikl
It's a fresh build from an 85k engine. Fresh head, all new bearings but original crank, rods, pistons with new ring set. It was built for a race series that requires all stock engines.
Old Wed, Jul-11-2018, 12:43:01 AM   #5
Engrmikl
I put it in for occasional track car weekend runner.
Old Wed, Jul-11-2018, 01:43:28 AM   #6
STAATS
STAATS's Avatar
Hmn thats the second engine in the last week or so that has been rebuilt and started running LM and had issues burning oil. Others that use this oil on engines that are already run-in don't seem to have issues... so making a vast extrapolation based on the small number of data points it at least seems to indicate that maybe this isn't a good oil to run-in a rebuilt engine... or the two users have not run the engine in very well...
It's weird as in povo Youtube grade tests the LM showed more wear than other oils which would make you think it was actually better for running in and engine and helping seat the piston rings but the opposite seems true.
STAATS
Old Wed, Jul-11-2018, 01:57:48 AM   #7
MrVond
The Phanto///M
Reputation: 0 MrVond is on a distinguished road
been running liquimolly for at least 35k miles the last 2 years, never had to top off in between 7.5k oil changes
[2006 E46 M3 | Competition Package | Interlagos Blue | Black | AFE Intake | Enkei MT1 | SMG ---> 6MT | Fortune Auto 500 ]
[2011 E90 M3 | Competition Package | Jet Black | Extended Fox Red | AFE Intake| AFE Exhaust | DCT GTS]
Jump to top MrVond is offline   Reply With Quote
Old Wed, Jul-11-2018, 03:31:24 AM   #8
mpwr92
Reputation: 0 mpwr92 is on a distinguished road
How much are you actully using can not stress this point enough on rebuilt engines to run a running oil for a 1000km from build!
Jump to top mpwr92 is offline   Reply With Quote
Old Wed, Jul-11-2018, 03:47:44 AM   #9
M3_Pilot
Pretty sure that's just a coincidence.
2004 Jet Black/Cinnamon 6MT
@jet.m3
Old Wed, Jul-11-2018, 04:17:41 AM   #10
Yar1
Yar1's Avatar
Reputation: 0 Yar1 is on a distinguished road
Not known for burning oil that I know of.. Liqui Moly makes great stuff. I run 10W-60 in the M3 & M5. No issues.
2004 ///M3 SMG II Coupe Silbergrau OEM+
Garage partner:
2006 ///M5 V10
Jump to top Yar1 is offline   Reply With Quote
Discussing Luqui Moly engine oil in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
