Old Mon, Jul-09-2018, 08:00:25 PM   #1
inferno493
Reputation: 0 inferno493 is on a distinguished road
Default Converting side strakes to real vents
Does anyone know if there is information floating around out there about how you might go about opening up the side vents to the engine bay? I have a supercharger which causes overheat issues on hot days / high altitudes and I don't really want to go the vented hood route. The left side vent looks like it would be difficult but the right side seems open enough to run some ducting from the vent, through the corner chamber and right into the heart of the engine bay. It seems like there's not really anyplace for incoming air to leave and that opening those vents could really reduce air temps in there.
Jump to top inferno493 is offline   Reply With Quote
Old Mon, Jul-09-2018, 08:13:43 PM   #2
///M3 MD
Reputation: 0 ///M3 MD is on a distinguished road
Default Re: Converting side strakes to real vents
From what I recall the ducts were originally designed to be functional but didnít result in any measurable increase in airflow. That being said, this was with the stock motor and temps, not sure if anyone has revisited this. Maybe some of the more seasoned pros can chime in?
2002 Carbon Black/Black 6MT ///M3
Mods: (Mike Miller Maintenance schedule) - Euro Headers - Resonated Section 1 - Dinan Section 3
TTFS Custom Tune
Autosolutions 30% SSK - RE Poly Trans mounts - AKG Poly diff bushings, RTABs and FCABs
Dinan 'Stage 1' Suspension
Jump to top ///M3 MD is offline   Reply With Quote
Old Mon, Jul-09-2018, 08:39:25 PM   #3
twentyseven
@itsmejonnyv
twentyseven's Avatar
Originally Posted by ///M3 MD View Post
From what I recall the ducts were originally designed to be functional but didn’t result in any measurable increase in airflow. That being said, this was with the stock motor and temps, not sure if anyone has revisited this. Maybe some of the more seasoned pros can chime in?
They were originally intended to be functional, but were not needed. Corporate liked the look so they were left in place as visual design cues.
Would take some crafty fab work to make them functional vents; just not sure if there is a low pressure zone there to extract the heat since there is nothing is ducted around the SC..
V-CSL, BBS CH, ÷hlins R&T, Supersprint, Brembo GT, custom Z4M seats, AVIN, G5R projector swap
Jump to top twentyseven is offline   Reply With Quote
Old Mon, Jul-09-2018, 11:23:38 PM   #4
inferno493
What I figure is that if the car is moving the increase in velocity over the vent will create a decrease in pressure in relation to the engine bay, especially considering the pressure created by air flowing through the grill, radiator and intercooler while in motion. That should allow greater airflow and increased effectiveness of the cooling system while retaining a stock exterior.
Old Tue, Jul-10-2018, 10:55:11 PM   #5
M3 dude
i've thought about this also. given the location of the vents is not conducive to extracting engine bay air (the 2 compartments are in the way of that), the best use for the side vents would be to extract air in the wheel arch area. that is comparatively easy to fab (a pair of 3d printed guides would do the trick).
Old Wed, Jul-11-2018, 12:45:38 AM   #6
rpearl555
So Shiny So Chrome
Other than a vented hood, what are some effective ways to get rid of the heat?
Old Wed, Jul-11-2018, 03:19:19 AM   #7
icecream
Registered Apples
icecream's Avatar
Remove the cabin air filter housing on track days??
Unless its overheating in general.
Old Wed, Jul-11-2018, 03:58:49 AM   #8
M3 dude
wouldnt think that would work. that is an intake - its in a high pressure area
Old Thu, Jul-12-2018, 03:52:02 AM   #9
dcsax
Reputation: 0 dcsax is on a distinguished road
That's not a bad idea. Especially for a guys like me with the SGT CSL bumper. I don't track the M3 but for those that do, the wheel arch to vent idea is not bad!
Jump to top dcsax is offline   Reply With Quote
Old Sun, Aug-26-2018, 07:51:56 AM   #10
bosundave
Reputation: 0 bosundave is on a distinguished road
Overheating because of a parasitic supercharger is a very common problem on our cars. Forget about a vented hood and go for a better radiator and a more efficient water pump. There are lots of options. The most expensive but the best options are found on this website.
http://www.zionsvilleautosport.com/
I wouldn't worry about getting a bigger oil cooler especially if you get one of their radiators. I suggest going whole-hog and getting their radiator and Reservoir combo.
Our plastic reservoirs are known to fail. You will probably never have to replace their radiators, reservoir, or electric fan for the the life of the car.
While you have everything apart considered buying and installing a uZionsville water pump which is actually much cheaper than the BMW version. It is supposed to move considerably more water then the water pump that you have right now.
Companies that sell us Superchargers don't mention you got to spend another couple grand in cooling modifications.
You can spend less but I think you'll get less. Go for the Zionsville. Go for the best.
For the best do-it-yourself print out the DIY for the cooling system refurbishing at the thebuildjournal.Com
Print it in color. It comes out to about 32 Pages as I recall. One of the best do-it-yourself instructions I've ever seen for our cars.
but a DIY shows you everything except the actual removal of the radiator. I figured out how to do that just by looking at it. Without disconnecting anything drop the oil cooler which is attached to the bottom of the radiator then remove the radiator hoses which are quick release. Then it's just a matter of a few screws in the whole radiator will come right out. It was a much easier job than I thought.
Most of the time is spent taking the darn intake system off. And once the intake system is out of the way your whole cooling system and serpentine belt system is just right there in front of you.
The special wrench set that you need to remove the fan and fan clutch cost $17 on eBay. It works perfectly. That's where I bought mine.
I wasn't speeding...I was QUALIFYING!
Agency Power muffler , Ebay midpipe, Magnaflow resonators BREMBO GT BBK, Endless Racing brake pads , TC Kline SA Coilover (front) Swift 448lb springs, BC Racing coilover rears (for now), TMS front(30mm) and rear(25m) adjustable anti sway bars, AKG FCABS, TMS limiters on AKG RTABs, and powerflex subframe bushings, HPF AND TMS weld in Subframe kit, 10 hours of additional subframe Stitch welding above and beyond what's usually called for, CF trim interior and exterior clear coated by my guy with heavy duty UV protection, Vorsteiner CF rear diffuser, Strassentech type CF lip, Aurora Angel Eyes, DRL,HID Fogs 6k, Headlights HID 6k, D-Force racing wheels sandblasted and powder-coated semi-gloss black, Square set up 265/35-18, built-in Passport Escort 9500CI .. custom mount of controls in ash tray, , rareQuatro CF shock tower brace, Pioneer Avic Z3, BSW stg 1speakers, BSW sub
Jump to top bosundave is offline   Reply With Quote
Discussing Converting side strakes to real vents in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
