Old Sun, Jul-08-2018, 11:00:29 PM   #11
NolliM3
NolliM3's Avatar
Default Re: Chasing down fault codes
How is the hose from the ICV to the elbow? A slight crack in the hose by the tip at the elbow can cause havoc and misleading diagnoses.
Old Mon, Jul-09-2018, 12:15:17 AM   #12
JitteryJoe
Should be ok. Every hose, hose clamp, seal, gasket of any kind is new. Damn hard to see the IVC however.
Old Mon, Jul-09-2018, 03:44:19 AM   #13
JitteryJoe
Keep us updated on the results of the sim removal.
I'm pretty sure the problem is the tune and the O2 sensor setup. I made a mistake when ordering the tune (quite some time ago now). I should have had the post cat O2 sensors deleted. The SuperSprint setup is catless and the rear O2 sensors sit ahead of the midpipe resonator. My guess is that is causing all the O2 sensor fault codes. I've reached out to Epic Motorsports to confirm and to see about an updated tune. I'll have them delete the SAP as well and remove the SIM.
The good news is that the second engine start, the engine ran smoother. But definitely more angry than the stock setup.
Old Mon, Jul-23-2018, 07:03:44 PM   #14
JitteryJoe
All the issues are worked out. I fixed a small vacuum leak and that fixed the last issue. No more fault codes.
And, off it goes to the shop for the final alignment.
Old Thu, Jul-26-2018, 10:57:45 PM   #15
motorsports_3
Reputation: 0 motorsports_3 is on a distinguished road
Congrats!
What caused the rest of the issues?
Jump to top motorsports_3 is offline   Reply With Quote
Old Fri, Jul-27-2018, 02:23:44 AM   #16
JitteryJoe
Originally Posted by motorsports_3 View Post
Congrats!
I replaced all the O2 sensors. Also the wiring plug into the ICV has not snapped in fully so that plus the leak was likely the root of the problems.
Everything is now OK.
Discussing Chasing down fault codes in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
