Old Mon, Jul-09-2018, 09:06:05 PM   #11
mpwr92
Reputation: 0 mpwr92 is on a distinguished road
Default Re: Right oil for built Engine?
Did you go overbore on the pistons? Did you run a running in oil?
Jump to top mpwr92 is online now   Reply With Quote
Old Mon, Jul-09-2018, 11:09:25 PM   #12
bigjae1976
That sounds like a lot of oil consumption. Wouldnít the spark plugs give you an indication if itís burning an excessive amount of oil in the combustion chamber?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Tue, Jul-10-2018, 05:53:38 AM   #13
maestro416
Reputation: 0 maestro416 is on a distinguished road
No overbore, and no run in oil. But I also drove very lightly first 5k kms
Jump to top maestro416 is offline   Reply With Quote
Old Tue, Jul-10-2018, 05:54:49 AM   #14
maestro416
plugs do look like there's oil in the chamber but again im being told it's because it's too rich. I will do a fresh change now that AFR is sorted out and see how the plugs are afterward.
What I'm trying to really understand is whether or not running rich could cause that kind of consumption.
Old Tue, Jul-10-2018, 11:48:29 AM   #15
///M3 MD
Reputation: 0 ///M3 MD is on a distinguished road
I'm not an expert, but from my own experience I know that a rich tune allows gas to essentially wash the oil off the cylinder walls, the lack of oil causes smoothing of the cylinder walls and loss of seal between ring and cylinder wall. The loss of this seal leads to oil consumption b/c you get oil in the combustion chamber.
2002 Carbon Black/Black 6MT ///M3
Mods: (Mike Miller Maintenance schedule) - Euro Headers - Resonated Section 1 - Dinan Section 3
TTFS Custom Tune
Autosolutions 30% SSK - RE Poly Trans mounts - AKG Poly diff bushings, RTABs and FCABs
Dinan 'Stage 1' Suspension
Jump to top ///M3 MD is online now   Reply With Quote
Old Tue, Jul-10-2018, 11:59:45 AM   #16
ClevoCapri
Reputation: 0 ClevoCapri is on a distinguished road
If its glazed the bores from running rich. Which it sounds like you have. You will need to pull the engine apart to give the bores a light hone and re-ring. It will always burn oil until you do.
Jump to top ClevoCapri is offline   Reply With Quote
Old Tue, Jul-10-2018, 12:32:39 PM   #17
bigjae1976
Youíll get a range of opinions on this but Iíve heard that you need to vary RPMs and generate some vacuum so the rings seal when breaking it in. I had 2 M54s rebuilt by a less than competent mechanic and amongst the many issues I had...I never consumed enough oil to force me to add a qt.
Old Tue, Jul-10-2018, 01:01:54 PM   #18
Jonnie86
Reputation: 0 Jonnie86 is on a distinguished road
Sounds like you ran too rich of a tune to break the engine in, you probably washed out the walls like stated above.
Jump to top Jonnie86 is offline   Reply With Quote
Old Tue, Jul-10-2018, 10:10:45 PM   #19
mpwr92
Always run A running in oil!
Old Wed, Jul-11-2018, 12:26:21 PM   #20
Feffman
Grand Poobah
Feffman's Avatar
Reputation: 0 Feffman is on a distinguished road
Agree, give that man a cigar.
MVP Track Time
Jump to top Feffman is offline   Reply With Quote
Discussing Right oil for built Engine? in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
