Old Tue, Jul-10-2018, 04:38:55 PM   #21
Default Re: Coolant Drain Plug Block Removal Troubles :
Originally Posted by mrgizmo04 View Post
I think it can be short and act as a spout for next time you have to drain the block.
Ah I see, clever!
_
Old Tue, Jul-10-2018, 04:52:57 PM   #22
mrgizmo04
mrgizmo04's Avatar
Jae is bringing us daily drivers the best of his tinkering collection at the track .
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Tue, Jul-10-2018, 04:55:47 PM   #23
Like all of those car commercials: "Engineering derived from racing heritage"
_
Old Wed, Jul-11-2018, 02:35:07 AM   #24
LightlyToasted
Reputation: 0 LightlyToasted is on a distinguished road
Originally Posted by bigjae1976 View Post
I would recommend installing a banjo bolt with a stainless steel line and a plug. Makes life easier and much less messier
If you're going this route, I think Mishimoto makes valves which replace the block drain plug. Press on a hose, open the valve, and there you go.
Jump to top LightlyToasted is offline   Reply With Quote
Old Wed, Jul-11-2018, 02:41:19 AM   #25
bigjae1976
How much does Mishimoto want for their eBay parts? $200?
2013 F30 328i - Melbourne Red
2004 E46 M3 - Imola Red
Old Wed, Jul-11-2018, 02:50:28 AM   #26
LightlyToasted
Not sure what you're gettin at. All I was saying is that I've seen aftermarket petcock valves for oil pans and block coolant drain plugs. Me - I prefer the simple pleasure of raining coolant all over hell's half acre.
Edit - maybe I was thinking of Fumoto, not Mishimoto.
Old Wed, Jul-11-2018, 03:33:27 AM   #27
WOLFN8TR
/// MONEY \\\
WOLFN8TR's Avatar
I have one of these on my 2500HD for draining the engine oil, works great!
Fumoto Drain Valves
Old Wed, Jul-11-2018, 06:02:35 AM   #28
He's just making a joke as Mishimoto is a bit of a joke.
_
Old Wed, Jul-11-2018, 07:29:19 AM   #29
mrgizmo04
mrgizmo04's Avatar
They are a very pricey joke
'05 M3 6MT coupe
Old Wed, Jul-11-2018, 02:11:01 PM   #30
LightlyToasted
Ah, gotcha. Will remember this next time I need to troll someone on the forum
Discussing Coolant Drain Plug Block Removal Troubles : in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
