Old Fri, Jul-06-2018, 06:41:50 AM   #1
Exclusivs
Exclusivs's Avatar
Reputation: 0 Exclusivs is on a distinguished road
Default Coolant Drain Plug Block Removal Troubles :
Midway through system flush / and block drain plug given tough time. Anyone else experience this? Have 6 extension on it now but as you know little room to work with. Do not want to force.
TIA!
Jump to top Exclusivs is offline   Reply With Quote
Old Fri, Jul-06-2018, 07:17:54 AM   #2
mrgizmo04
mrgizmo04's Avatar
Default Re: Coolant Drain Plug Block Removal Troubles :
As long as you have proper size socket on it, use a breaker bar from the bottom. Mine was crusted on there a bit too. You can try to spray with wd40 or pblaster to soak for a bit. That area gets hot from headers, so it could be a bit tough to get out.
TIA!
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Fri, Jul-06-2018, 07:24:28 AM   #3
Exclusivs
Exclusivs's Avatar
Thanks for confirming, absolutely accurate. No room in there either to even give quick shock to head of ratchet. Leverage is the enemy right now. Will hit it with PB and grab a 1/2 ratchet tomorrow if I can. Id use my breaker bar but dont have 1/2 to 3/8 adapter. Plus not sure how various ext and adapters play in effectiveness of bolt removal. Appreciate your response.
Old Fri, Jul-06-2018, 07:32:02 AM   #4
The fewer, the better. Tloser to 90 degrees from bolt/nut, the better. Pb blaster will help. You can swing a hammer/mallet at the end of the breaker or socket handle to shock it loose a bit.
_
Old Fri, Jul-06-2018, 08:02:41 AM   #5
Exclusivs
Exclusivs's Avatar
Hit it with PB - will again tomorrow after Im able to get a larger 1/2 ratchet. FYI ; have not move the Accumulator canister from its place. Dont see need to as drain plug bolt is accessible. Does require a 6 extension on ratchet head to clear if it. Am sure my problem is coming from what Giz hit on - in combination with lack of leverage from 3/8 ratchet.
Old Fri, Jul-06-2018, 03:14:36 PM   #6
Al Soobie Guy
Reputation: 0 Al Soobie Guy is on a distinguished road
Its a bit overkill. Dont make your life harder than it has to be. Drain the radiator and you'll be fine. Or if youre that ocd run it and drain it again.
Jump to top Al Soobie Guy is offline   Reply With Quote
Old Fri, Jul-06-2018, 05:37:27 PM   #7
Exclusivs
Exclusivs's Avatar
Rad is drained off the car and new one on. Water pump & thermostat after. If refreshing entirely - why not get all old fluid out possible?
Old Fri, Jul-06-2018, 07:44:52 PM   #8
mrgizmo04
mrgizmo04's Avatar
Def good to get the block flushed out.
'05 M3 6MT coupe
Old Fri, Jul-06-2018, 09:20:36 PM   #9
GeorgeH
BMW Fan
Reputation: 0 GeorgeH is on a distinguished road
Im in Texas and we don't have corrosion issues like northern cars, but down here they always "stick." I take a 13mm swivel socket on a 2 or 3' extension and bust it loose, usually requiring quite a bit of wind up on the long extension. Once it cracks loose it'll soon out by hand. Just my experience.
Current BMW stable: '00 R1100S, '09 HP2S, '12 R1200GSA, '00 323iT (S54 Swapped), '00 332iT (stock), '03 325iT (stock), '04 ZHP Imola/6MT (basic suspension mods)
Jump to top GeorgeH is offline   Reply With Quote
Old Fri, Jul-06-2018, 11:42:15 PM   #10
Exclusivs
Exclusivs's Avatar
West Coast, and west coast based car - not a corrosion issue here per say more awkward no space and by feel. Swivel is possibly best option with bolt sitting slightly below the accumulator. Unfortunately in such tight space & working on your back no real such thing as wind up lol.
Discussing Coolant Drain Plug Block Removal Troubles : in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
