Old Thu, Jul-05-2018, 02:29:16 PM   #1
quattrofrank
Reputation: 0 quattrofrank is on a distinguished road
Default Car starts then stalls
Hi
This has happened to me a couple of times now. The car would work just fine then parked and started maybe 15min later. It will then start fine but die out.
First time it did this I cleared the adaptions and it started right away.
Now it just happened again and I only had my mobile with Carly innstalled.
Found a fault code: vanos b09 and I cleared that and it started right away again.
To me this seems like a electrical error since its fixed with clearing of adaptions / fault codes. But it seems very strange, I have searched and couldnt find any one with the same issue.
No engine light, the car has carbon airbox and alpha n ess tune.
Any suggestions?
Jump to top quattrofrank is offline   Reply With Quote
Old Thu, Jul-05-2018, 04:48:17 PM   #2
mrgizmo04
mrgizmo04's Avatar
Default Re: Car starts then stalls
Have you done any vanos related work recently?
This code can be caused by many vanos related items - broken hub tab, exhaust cam sensor, incorrect timing, solenoid...
Do some research on code 185.
'85 528e 164k miles (sold)
'05 M3 6MT coupe
Old Thu, Jul-05-2018, 05:52:30 PM   #3
quattrofrank
Thanks for the tip, I will do some searching.
No I have not done anything with regards to the vanos but do you think those two are related (vanos fault code and the stalling?)
Old Thu, Jul-05-2018, 05:56:48 PM   #4
mrgizmo04
mrgizmo04's Avatar
Absolutely
'05 M3 6MT coupe
Old Thu, Jul-05-2018, 10:23:08 PM   #5
jackzasiewski
jackzasiewski's Avatar
Reputation: 0 jackzasiewski is on a distinguished road
Hi
Any suggestions?
I don't think vanos problem - unless severe - would cause stalling.
I suspect mass airflow sensor or a crankshaft sensor. MAF will generate fault codes - probably - crankshaft can cause stalling with no codes
Sent from my LG-H933 using Tapatalk
Jump to top jackzasiewski is offline   Reply With Quote
Old Thu, Jul-05-2018, 10:36:04 PM   #6
quattrofrank
I have alpha n so no air mass sensor.
But cam sensor is a good tip
Old Thu, Jul-05-2018, 11:43:45 PM   #7
mrgizmo04
mrgizmo04's Avatar
Code b09 is a specific vanos code for exhaust side (it is also decimal code 185).
In post 2 I list some of the items that could be causing it, one of which is the exhaust side cam sensor. If the dme doesn't know what position the cam is in, it can cause it to run poorly and stall.
Vanos is more than just solenoid or hub tabs or cam bolts taken in isolation, there is a lot more at play that the system relies on for proper signal.
'05 M3 6MT coupe
Old Fri, Jul-06-2018, 11:29:41 AM   #8
quattrofrank
I did some more fault finding.
The b9 code shows up immideatly when idling.
According to beisian procedure this could be either the exhaust hub tabs for the pump or the solenoid.
Took of the cam cover and inspected, the tabs are fine.
Then its safe to assume:
1. exhaust cam sensor or
2. solenoid
Have I understand correctly?
Old Thu, Jul-12-2018, 01:17:37 PM   #9
quattrofrank
So today I have changed:
exhaust cam sensor (new oem)
Solenoid (new oem)
Cleared fault code and the b9 code immideatly shows up when car is idling.
what could be the issue now?
Old Thu, Jul-12-2018, 01:23:53 PM   #10
WuBai
Five Spiced and Lovin' It
WuBai's Avatar
Very far from the area you are looking at currently, but it’s worth an ask: how old is your fuel pump? They tend to fail intermittently and allow the car to start then stall quickly afterwards if they are on their last leg.
Discussing Car starts then stalls in the E46 M3 (2001-2006) Forum - Engine: S54 - Max Hp: 333 hp at 7,900 rpm / 262 lb/ft at 4,900 rpm
