Old Thu, Jul-05-2018, 03:48:43 AM   #1
michaeltoan
Reputation: 0 michaeltoan is on a distinguished road
Default Help with Yellow washeser!
Was refreshing my rouge ssk
This kit uses 2 metal washers (under shift lever )and 2 yellow factory washers @the selector rod joint
Anyways. After putting in new selector rod bushing I can no longer use the yellow washers the retaining clip won’t fit
Any of you guys run your shifters without them? Or is something wrong on my end? Maybe this new selector joint has different tolerances than the last ?
Thx
Jump to top michaeltoan is offline   Reply With Quote
Old Thu, Jul-05-2018, 04:00:14 AM   #2
Default Re: Help with Yellow washeser!
If you ordered the updated aluminum shift rod joint, it does not use the yellow washers. This is stated right in the notes.
Old Thu, Jul-05-2018, 04:02:32 AM   #3
bluptgm3
Washers in this stack-up?
https://www.realoem.com/bmw/enUS/sho...diagId=25_0577
Discussing Help with Yellow washeser! in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
