Old Wed, Jul-04-2018, 06:12:14 PM   #11
tripitz
Reputation: 0 tripitz is on a distinguished road
Default Re: M50 Manifold Swap TB gasket question
Originally Posted by Mindart View Post
and from what I hear his instructions are second to none.... Turners doesn't FULLY tell you everything you'll run into
His directions are just like most of the aftermarket stuff out there. Unclear and skips a whole bunch of stuff. The bracket question... run 1, 2, front, rear, both? Can you use the OBD1 brackets? What if you no longer have SAP? Where do some of the vacuum lines go? You have to have a good idea of how things actually work and adapt to your situation. I ended up going with my gut and it all works fine. My buddy and I literally spent 1-2 hours discussing the brackets and how to best orient everything. I would not recommend for a beginner... (we already did an engine swap, OBD1 conversion, plus a full car's worth of changes...)
Jump to top tripitz is offline   Reply With Quote
Discussing M50 Manifold Swap TB gasket question in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
