Old Tue, Jul-03-2018, 03:22:16 AM   #1
derek2079
derek2079's Avatar
Reputation: 0 derek2079 is on a distinguished road
Default To install or not to install a fan controller, that is the question
I am installing two electric fans and I would like to know if I need to install an fan controller or not? TIA
Jump to top derek2079 is offline   Reply With Quote
Old Tue, Jul-03-2018, 03:52:57 AM   #2
NolliM3
NolliM3's Avatar
Default Re: To install or not to install a fan controller, that is the question
What were your plans...were you just let them run continually? You could let the DME/ thermoswitch to trigger the relay that comes with the fan.
Old Tue, Jul-03-2018, 08:13:05 AM   #3
derek2079
derek2079's Avatar
How would I wire the dme/thermoswitch to come on? Is there something I need to buy for that?
Old Tue, Jul-03-2018, 08:41:32 AM   #4
M_Parallel
Mr. OEM
M_Parallel's Avatar
Netherlands
Because maybe too much cooling?
They only need to come on if coolant temp reaches its threshold temp.
Otherwise you might as well ditch your stat.
Old Tue, Jul-03-2018, 11:24:43 AM   #5
You would either use the factory aux fan switch to trigger your new fans or buy a controller. There is more adjustability with a controller. Some are better than others. You can even find PWM units. But beware controllers may be designed for a certain sender and you have to install it in coolant. Most factory senses are in the head but the block can also work so you would have to find one with the right thread size and pitch to fit a stock hole or be adapted to it. You might also be able to drill your T Stat housing for one.
Few go this far although I think it’s the best way. Most just run off the aux fan wiring, which is sufficient for one fan but maybe not two. Some use a lower temp switch from a 318i.
Discussing To install or not to install a fan controller, that is the question in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
