Old Mon, Jul-02-2018, 05:50:55 PM   #1
Mindart
Reputation: 0 Mindart is on a distinguished road
Default CSB preload?
installed drive shaft in car last night....
When i broke the dive shaft down I reference marked it near the splines as I know it is balanced
I did not reference the final drive or transmission output flange to the drive shaft ... which is fine right?
Lastly, the pre load.... I just moved the CSB towards the front of the vehicle about a .25 inch and then tightened it down. I made my best effort to be sure all seemed to be centered in the tunnel. I don't think its perfect but pretty close.
every time i went to tighten the CSB down it seems to suck it slightly more to one side that the other... maybe its a 1/8inch- off at most?
thanks!
Jump to top Mindart is offline   Reply With Quote
Old Tue, Jul-03-2018, 02:17:22 PM   #2
Mindart
Default Re: CSB preload- just double checking
Bump
Anyone?
Old Tue, Jul-03-2018, 04:05:21 PM   #3
BMWManiac
Turbo 97 M3
BMWManiac's Avatar
Reputation: 0 BMWManiac is on a distinguished road
Default Re: CSB preload?
thanks!
You don't need to reference the transmission or diff flanges for the driveshaft, just the driveshaft halves themselves. Yes, all you have to do to preload is just like you did. Make sure both sides are installed to the trans/diff (proper length, it shouldn't slide out from either trans/diff) and then loosely bolt CSB to chassis. slide the CSB as far forward as possible and bolt it down. .25" sounds about right.
I wouldn't worry about it, sounds like you did it right. When you drive, do you notice any new issues or vibrations?
1997 Artic Silver M3
CES Stage IV - 651rwhp/615rwtq@ 24 psi
Jump to top BMWManiac is offline   Reply With Quote
Old Tue, Jul-03-2018, 04:19:52 PM   #4
Mindart
I figured it was fine.... I haven't driven it yet because I am slow to put it back together... that's all i had time to do the other day
my sequence was bolting the guibo end up, then the final drive end up and lastly i preloaded the bearing
everything seems to rotate smoothly and be aligned as good as i can get it
I had referenced marked my old CSB before i took it out so the new one pretty much sits where the old one was
Discussing CSB preload- just double checking in the E36 M3 (1992-1999) Forum - {Euro - S50 B32 321hp @ 7400 rpm} {U.S. - S52 B32 240 hp @ 6000 rpm}
